Wheel Spacers - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-08-2013, 03:21 AM   #1
MatthewA
Fan#: 113181
What I Drive: 2008 Red S Focus
FF Reputation: 1 MatthewA Good Standing Member
Exclamation Wheel Spacers
I have a 2008 ford focus and i bought 15x7 diamond steelies for them. Since they are deep dish they hit the calipers in the front and i was wondering if i buy wheel spacers if they will have any effect on them. Plus im going to lower it soon so which is a good spring height so they wont rub and i wont have to roll my fenders?
MatthewA is offline
Old 04-08-2013, 04:18 AM   #2
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,708, Level 94
Points: 23,708, Level: 94 Points: 23,708, Level: 94 Points: 23,708, Level: 94
Level Up 36% Completed
Forum Activity 14%
check to make sure they're legal in your area, don't buy cheap, and make sure you have enough threads on your lug studs... otherwise they will need to replaced with longer length ones.
As for fitment, what tire size are you going with?
mikebontoft is online now
Old 04-09-2013, 02:34 AM   #3
thenorm
thenorm's Avatar
Fan#: 14947
What I Drive: '04 liquid grey ZX3, built for FSP
Points 5,663, Level 48
Points: 5,663, Level: 48 Points: 5,663, Level: 48 Points: 5,663, Level: 48
Level Up 57% Completed
Level up: 57% Level up: 57% Level up: 57%
Forum Activity 2%
FF Reputation: 36 thenorm Great Standing Member
5mm was enough to clear the caliper on an 04 focus. u might just have to grind a touch. I had teh same problem on my diamonds. heres where i ground
what back spacing did u get? once we know that we can comment on whether it would rub or not.
May 2014 ROTM
for auto-x: '04 Liquid Grey ZX3
for street: '02 Infrared SVT
thenorm is offline
Old 04-15-2013, 03:21 AM   #4
MatthewA
Fan#: 113181
I bought 15x7 diamond steelies with a 0 offset or 4 inches of backspacing.
MatthewA is offline
Old 04-17-2013, 06:12 PM   #5
Nickgt40
Wheel King, Bow Down
Nickgt40's Avatar
Fan#: 40924
Location: Annoying the Liberals, California, United States
What I Drive: 01 Black ZX3, 09 FSWerks SEMA Coupe
FF Reputation: 19 Nickgt40 Great Standing Member
Your brake calipers are also quite a bit bigger than the ones on thenorm's car. The benefit is because the disks are larger the calipers also sit out further from the hub center so you might be able to get away with a smaller spacer.
The cheapest way to test what size you will need is by simply using washers on your studs and once the wheel sits flush against the washers without hitting the caliper you know how thick your spacer needs to be.
*THIS IS ONLY FOR MEASUREMENT PURPOSES*
I know it's obvious, but do NOT drive on a wheel attached to your hub with any kind of washer being used as a spacer. You will need to buy a quality spacer from H&R that comes with properly matched extended studs.
Feb 2011 Ride of the Month ~ 2011 Hatch Nation Hatch of the Year ~ 2011 Focus Fanatics Ride of the Year!
Hatch Nation #2
Nickgt40 is offline
