How To setup my Automatic Ford Focus for Autocross - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Autocross Racing
Autocross Racing The place to discuss information about autocross stats, tips and events. Track sanctioned events only.
Old 04-07-2013, 02:16 PM   #1
ronan_zabala
Fan#: 113147
What I Drive: 2008 Sky
FF Reputation: 1 ronan_zabala Good Standing Member
Hi,
Is it possible to setup my automatic ford focus for autocross?
details
-year: 2008
-automatic transmission w/ option for manual shifting (sequential)
-1.8 petrol
I just want to have fun but somehow be a little bit competitive.
Thanks!
ronan_zabala is offline
Old 04-07-2013, 02:23 PM   #2
badazz2010focus
Fan#: 78166
What I Drive: 2010 ingot silver 2 dr 5 speed
Points 19,226, Level 87
Points: 19,226, Level: 87 Points: 19,226, Level: 87 Points: 19,226, Level: 87
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
Forum Activity 9%
FF Reputation: 7 badazz2010focus Good Standing Member
Are you saying you have an "autostick" or are you asking can you get it? because I've never seen a fofo with an "autostick"option.
badazz2010focus is online now
Old 04-07-2013, 02:43 PM   #3
ronan_zabala
Fan#: 113147
what i meant is.. it's an automatic shift.. w/ the P, N, R and D.. but you can switch it to the right and it has the + and - sign..
Old 04-07-2013, 03:27 PM   #4
badazz2010focus
Fan#: 78166
Forum Activity 9%
wow is this an us built focus?
Old 04-07-2013, 03:29 PM   #5
LouBomb
It was all a DREAM!
LouBomb's Avatar
Fan#: 32545
What I Drive: A magical pony by the name of Sally
Points 11,236, Level 69
Points: 11,236, Level: 69 Points: 11,236, Level: 69 Points: 11,236, Level: 69
Level Up 97% Completed
Level up: 97% Level up: 97% Level up: 97%
Forum Activity 4%
FF Reputation: 9 LouBomb Good Standing Member
He said 1.8 engine... So he must have the UK version
Sent from my JailBroken iPhone.
2000 Turbo Zx3
2003 Pitch Black SVT
2000 SPI 220k miles all original THE UNICORN
Focus Revolution Club
Formely IMPORTKILLA35
LouBomb is offline
Old 04-07-2013, 03:36 PM   #6
badazz2010focus
Fan#: 78166
Forum Activity 9%
ah ok DER LOL
Old 04-07-2013, 08:25 PM   #7
soundFocus
soundFocus's Avatar
Fan#: 97713
What I Drive: 2011 Sangria Red SES
Points 451, Level 9
Points: 451, Level: 9 Points: 451, Level: 9 Points: 451, Level: 9
Level Up 2% Completed
FF Reputation: 1 soundFocus Good Standing Member
Run your tire pressures on the high side... around 40psi, more if your tires can safely take it. Also marked the sidewall around to the tread with white shoe polish to see how it's contacting the surface, allowing you to make adjustments to the pressure. Remove EVERYTHING from the car; spare tire, jack, cover, floor mats. Obviously loose objects (including floor mats) must be removed from the passenger compartment, but in the trunk if you pull out the spare tire and jack you save a little weight. Just don't pull anything bolted down (like the rear seat) as this will probably bump you up a class. If you can do it and stay in the stock class, use a drop in reusable air filter like a K&N. I would also run it with a quarter to a half tank of fuel; again, it saves a little weight. Superstition says to do an oil change before hand, though I doubt it will make a difference.
More serious stuff depends on the regulations; some might let you run modified exhausts as long as the header and cat are stock, others might not. I think you can generally upgrade the brake pads but you can't run slotted rotors in most stock classes. The Focus is a nice car for auto cross though; when setup right cars like the American SES model handle really well, it's just trying to get more power from them.
soundFocus is offline
Old 04-07-2013, 09:10 PM   #8
Miller88
Fan#: 73790
What I Drive: 2011 Focus SE 5 Speed
Points 1,764, Level 24
Points: 1,764, Level: 24 Points: 1,764, Level: 24 Points: 1,764, Level: 24
Level Up 64% Completed
Forum Activity 3%
FF Reputation: 5 Miller88 Good Standing Member
Is it a dual clutch transmission? If it's a regular torque converter automatic, I'd put on a transmission cooler ... especially for autocrossing.
2011 Focus SE 5 Speed 36k - Blue Flame Metallic - Added Rear Swaybar
2000 Jeep Cherokee Sport 115k - Lifted with mud tires.
Miller88 is offline
Old 04-08-2013, 01:36 PM   #9
ronan_zabala
Fan#: 113147
It is a DCT..
Is it okay if i don't put in a transmission cooler? is it going to be bad for my transmission? how much would it cost? thanks!
Old 04-08-2013, 03:24 PM   #10
mac.mogul
mac.mogul's Avatar
Fan#: 90409
What I Drive: 2011 Sterling Grey SES Sedan
Points 3,995, Level 40
Points: 3,995, Level: 40 Points: 3,995, Level: 40 Points: 3,995, Level: 40
Level Up 23% Completed
FF Reputation: 14 mac.mogul Great Standing Member
I would ensure that your stock cooling system is functioning properly and has fresh coolant.
The transmission fluid, especially, should be checked if you have more than 30k miles on the most recent fluid change.
I'm not certain on the EU models, but if you have hydraulic power steering, it would be best to change to fresh power steering fluid.
Make sure your brake fluid is fresh and clean and that all four brakes are clear of any air bubbles
Front tires should be set around 38-40 pounds and the rear tires should be at least 2 pounds more than the fronts. This will help you rotate the rear of the car for tight corners and helps to induce some lift-off oversteer for faster corners.
I also recommend you leave the spare tire and tools in and make sure they are secured down. Some people prefer to remove them for weight savings, but they forget about weight balance. You will need that weight over the rear wheels for better balance.
If your rear seats fold flat, I would say to fold them flat and secure them down. This brings some weight down for a lower center of gravity.
All of this won't do much. It'll still drive like your car, but you'll be able to have a little more fun at the limit with this kind of prep.
2011 SES 5spd #006 >> SR #213
What other people think of me is none of my business.
mac.mogul is offline
