Dried Fish Eyed Paint on my SVT - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus SVT > Focus SVT
Focus SVT The place to chat about general questions, window tinting, exterior body, interior and lighting upgrades for the MK1 2002-2004 Focus SVT.
Old 04-07-2013, 06:30 AM   #1
jimstix66
Fan#: 113125
What I Drive: Red 2003 SVT Focus
Points 56, Level 1
Points: 56, Level: 1 Points: 56, Level: 1 Points: 56, Level: 1
Level Up 12% Completed
FF Reputation: 1 jimstix66 Good Standing Member
I needed a new car on a budget and although I really wanted an SVT it just wasn't in the budget. That was until I came across the 2003 Red ZX5 SVT I bought cheap because the cars paint is pretty bad.
It's all fish eyed, orange peeled and if the paint isn't bad enough there's places where the paint ran under the masking take on some of the black plastic pieces like at the base of the windshield.
I LOVE the car and I knew what I was getting but is there anything that can be done to improve the look of the paint without repainting the car? It's simply not in the budget and I can live with it as it is if needs be.
I've found a bunch of info on fish eyes and the other problems but the information is almost all on when the paint is wet.
Any suggestions would be greatly appreciated!
Thanks!
Jim
jimstix66 is offline
Old 04-07-2013, 07:41 AM   #2
Supernaut
Fan#: 85958
What I Drive: '99 Kawasaki Ninja EX500
FF Reputation: 1 Supernaut Good Standing Member
If you want to go really cheap, there are some people that have done wonders with plasti-dip. I never saw the outcome but I think a user here said he was going to plasti dip his whole car.
Supernaut is offline
Old 04-07-2013, 07:47 AM   #3
02fordsvt
Meh.
02fordsvt's Avatar
Fan#: 84654
What I Drive: 2002 SVT, 2001 SE (Rusty)
Points 58,328, Level 100
Points: 58,328, Level: 100 Points: 58,328, Level: 100 Points: 58,328, Level: 100
Level Up 0% Completed
Forum Activity 14%
FF Reputation: 49 02fordsvt Great Standing Member
Buy-Sell-Trade Rating: (11)
Do you have any pictures of how bad it is?
One suggestion is taking some 1000 and/or 2000 grit sandpaper and try sanding the clear coat down follow by a good polish.
Another suggestion is getting a rattle can of clear coat and try spraying over a small portion of the car (such as one fender) and seeing how it turns out. Afterwords, you can do the sand/polish on that section for an OEM shine.
Hatch Nation #13 : Rally Revolution #13 : ROTM Jan '13
It's Bryan, not Brian
RSVT-170 Build in Progress
Derusting Rusty Build in Progress
02fordsvt is online now
Old 04-07-2013, 08:48 AM   #4
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,521, Level 100
Points: 140,521, Level: 100 Points: 140,521, Level: 100 Points: 140,521, Level: 100
Forum Activity 55%
FF Reputation: 50 sleepyboy Excellent Standing Member
Welcome to the forum
Personally I'd worry about the important maintenance issues that the SVT requires like t-belt for instance before worrying about the paint. I saw thread the other day where someones idler pulley failed. The SVT is a interference motor so it will bend the valves and possibly the pistons or cylinder walls which depending on which event could determine the cost. Check the valve cover gasket for leaks, which tend to make the thermostat housing leak. New spark plugs, wires, fuel filter, and maybe the air filter which I would go K&N with the stock setup. Also why was it repainted? Was it in a wreck? Get the important things out the way to ensure that you have a reliable SVT before you have a pretty one. That's what I'm doing with mine.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 04-07-2013, 10:37 AM   #5
dodgeguy
dodgeguy's Avatar
Fan#: 85952
What I Drive: 2014 White Focus ST2
Points 578, Level 11
Points: 578, Level: 11 Points: 578, Level: 11 Points: 578, Level: 11
Level Up 56% Completed
FF Reputation: 1 dodgeguy Good Standing Member
Even though body work comes easier for me than mechanic work does - I second this idea. It doesn't matter how good or bad your paint looks if your car is stuck in the garage because it doesn't run.
K&N Air filter, uh - thats it, NO CAI, NO FSWerks, NO Exhaust, NO Coilovers, NO Tune, Nothing
dodgeguy is offline
Old 04-08-2013, 09:40 PM   #6
jimstix66
Fan#: 113125
Points 56, Level 1
I agree with the posts which is why the entire car has been gone through mechanically. First thing I did when I bought it was take it to my mechanic and tell him to take care of everything. Fortunately the timing belt had just been done as were the shocks and struts. Wheel bearings, breaks, water pump, synthetic fluids and a stereo install.
I'd post pictures but I haven't been able to figure that out yet. Thanks for the maintenance advice from everyone.
Old 04-08-2013, 09:47 PM   #7
ToreadorFocus
ToreadorFocus's Avatar
Fan#: 100350
What I Drive: 2006 Dark Toreador Red ZX3
FF Reputation: 1 ToreadorFocus Good Standing Member
02fordsvt has the right idea but make sure its a wet sand... and b sure to keep it wet.. u can never use to much water
ToreadorFocus is offline
Old 04-08-2013, 09:58 PM   #8
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 55%
In that case then like it was said before, wet sand and polish and see how it turns out. You may want to look for more info on wet sanding and polishing. I'm sure there are lots of video's on the subject.
Moderator for
Technical Chat
Old 04-09-2013, 07:11 AM   #9
02fordsvt
Meh.
02fordsvt's Avatar
Fan#: 84654
Forum Activity 14%
This is true. All the sanding should be wet sanding. Sorry for not clarifying that.
Old 04-09-2013, 06:59 PM   #10
jimstix66
Fan#: 113125
Points 56, Level 1
I'm going to give it a shot if I ever have a day off and nice weather here in MA. I'll see if I can figure out how to upload pics and put up some before and afters.
Thanks again for the advice!!!!
