Sparks when reconnecting battery - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-07-2013, 03:42 AM   #1
mister_eff
Fan#: 110362
What I Drive: 2012 Ford Focus Hatchback SEL
FF Reputation: 1 mister_eff Good Standing Member
Hello,
I'm getting sparks when reconnecting the battery. I disconnect the battery by disconnecting ground first (at what I believe is called the left front strut tower, ie, not on the battery). Then disconnecting the positive terminal on the battery.
I reconnect by connecting the positive terminal on the battery. Then when I connect the ground terminal with the screw/stud thing, I get sparks. All doors are closed. I don't know what could be causing the sparks.
Am I disconnecting/reconnecting it right?
Also for some reason I'm having trouble tightening the screw/stud all the way. Like it gets stuck halfway through. I'll have to take a closer look in the morning, but I don't recall having any difficulty removing it.
mister_eff is offline
Old 04-07-2013, 05:57 AM   #2
I Bleed Ford Blue
I Bleed Ford Blue's Avatar
Fan#: 94113
What I Drive: 2013 F150 FX4
FF Reputation: 8 I Bleed Ford Blue Good Standing Member
You need to disconnect the neg cable at the post on the battery. By unhooking at the strut tower you still have the ground cable to the block, so when you pull the pos cable you get a spark.
13 Blue Flame F150 FX4 402A on 20's loaded
13 Frosted Glass Escape Ti 401A loaded
13 Performance Blue SE 201A
14 Dark Side Fusion SE 200A
L-CCC #18/HOIA #37
I Bleed Ford Blue is offline
Old 04-07-2013, 07:55 AM   #3
Hodge Podge
Hodge Podge's Avatar
Fan#: 96120
What I Drive: 2012 5-Dr Se Sport Pkg Ingot Silver
FF Reputation: 1 Hodge Podge Good Standing Member
+1 to above.
Disconnecting the negative from the battery is the best way to ensure the battery is no longer supplying any power to the vehicle.
As a side note though, even with everything "Off" on the vehicle, there are systems that continually draw some power from the battery (entertainment, keyless entry, various control modules, etc...). So, while it should not be a shower of sparks, one or two smaller but noticeable sparks when disconnecting the battery is not unusual and pretty common in my experience.
Best way to minimize is to try to maintain a solid connection while securing the clamp/post/bolt/etc...
____________________
Hodge Podge
2012 Se Ingot Silver 5-Door w/ 201A & Se Sport Package
2001 Silverado 1500 RCLB 4x4 4.8L 5-Speed
Hodge Podge is offline
Old 04-08-2013, 01:57 PM   #4
mister_eff
Fan#: 110362
Ah, I see. Thanks for the replies. That worked! I'll disconnect the ground from the battery from now on.
