Mk3 Wheel Spacer Information - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-22-2014, 01:04 PM   #21
GR34TWHI73N0RTH
GR34TWHI73N0RTH's Avatar
Fan#: 96598
What I Drive: 2012 Black SE Sport 5 Spd
Points 2,141, Level 27
Points: 2,141, Level: 27 Points: 2,141, Level: 27 Points: 2,141, Level: 27
Level Up 94% Completed
FF Reputation: 1 GR34TWHI73N0RTH Good Standing Member
Originally Posted by dyn085 View Post
I ran a 10/15 setup for a while with no issues. My only recommendation is to ensure you use a torque wrench and do a 10/100/500 mile torque-check because the 10mm spacer is actually 2mm thicker than the 'maximum' spacing available on the OEM lugs up front.
Much thanks
Rally Revolution #333
GR34TWHI73N0RTH is offline
Old 04-22-2014, 04:41 PM   #22
GR34TWHI73N0RTH
Fan#: 96598
Are you saying i wont need to swap out the front studs with the 10mm?
Old 04-22-2014, 04:59 PM   #23
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 26,119, Level 96
Points: 26,119, Level: 96 Points: 26,119, Level: 96 Points: 26,119, Level: 96
Level Up 77% Completed
Forum Activity 53%
Activity: 53% Activity: 53% Activity: 53%
I'm saying that I didn't swap mine when I had the 10/15 setup, but that I always ensured my wheels were torqued to specifications (not just 'gutentight').
The technically-correct answer is that anything thicker than 8mm should have longer studs installed. If you don't have the funds/time to swap lugs you should at least invest in a torque wrench.
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is online now
Old 04-22-2014, 05:02 PM   #24
GR34TWHI73N0RTH
Fan#: 96598
no i was planing on swapping them(got a torque wrench) but if i dont have to on the front then it saves me some time. Would 10/15 be the max i can get with a 45 offset or can i do more?
Old 04-22-2014, 05:08 PM   #25
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
Forum Activity 53%
Pm me your wheel/tire info (all of the sizing) and I can look it up when I get home or you can use my wheel/tire package as reference though you might want to subtract a couple mm to eliminate rubbing)-
18x8 ET33 with 215/40 General 595ss tires.
September '13 ROTM
2014 FiST-
Old 04-25-2014, 12:20 AM   #26
evilO
evilO's Avatar
Fan#: 118681
What I Drive: 2014 Tuxedo Black Focus SE
Points 1,442, Level 21
Points: 1,442, Level: 21 Points: 1,442, Level: 21 Points: 1,442, Level: 21
Level Up 43% Completed
FF Reputation: 2 evilO Good Standing Member
Originally Posted by mishka View Post
hey all! still no problems here after installing H&R 20/25mm spacers on Sportline springs and 215/50/R17 tire. props to dyn085 again for helping me out with the fitment. This guy know his stuff lol.
I'm wondering if when I buy new tires, if I can upgrade to 235/40/R17 without messing up the fitment...
This is the exact information I was looking for. I have a 2014 SE with 235/40/17s. I want to put on the H&R DRM 20mm spacers (part number 4035633). All my research led me to believe this would work... your post confirms it.
Do you happen to have any pics? I am at stock height, but I would love to see your current fitment. TIA.
evilO is offline
Old 04-25-2014, 01:54 PM   #27
Slo86GT
Slo86GT's Avatar
Fan#: 88885
What I Drive: 2013 Sterling Gray Focus SE
Points 3,231, Level 35
Points: 3,231, Level: 35 Points: 3,231, Level: 35 Points: 3,231, Level: 35
Level Up 21% Completed
FF Reputation: 2 Slo86GT Good Standing Member
Just for a visual reference, here is what the 17x7's look like with 25m spacers all around and the OEM Continental tires.
This is with Sportline springs, and there was only minor rubbing when driving like a human being over good to moderate roads.
Dyn085, I believe the 17x7 owners will have no issues with running a 20mm adapter kit. there are very large pockets between the lug holes.
TL/DR quick specs:
2013 SE Sport package
17x7 "Blackpack" wheels
OEM Tires
Sportline Springs
25mm H&R spacer kit
2013 Focus SE 5M Daily Driver
2003 Mustang GT V8/Auto Wife's Daily
1986 Mustang GT V8/5M Toy
- Jody -
Slo86GT is offline
Old 04-25-2014, 05:09 PM   #28
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
Forum Activity 53%
Dyn085, I believe the 17x7 owners will have no issues with running a 20mm adapter kit. there are very large pockets between the lug pockets.
You are correct, so long as the wheels are OEM or have the same offset as OEM. Most, like Mishka, are running 20/25 f/r setups. You probably have roughly the same rubbing as I do, mine is just worse due to being lower.
September '13 ROTM
2014 FiST-
Old 04-25-2014, 10:36 PM   #29
Slo86GT
Slo86GT's Avatar
Fan#: 88885
I more meant the extra 5mm of factory lug sticking through the spacer will have a place to go without modification, not just the lack of or only moderate tire scrubbing.
- Jody -
Slo86GT is offline
Old 04-27-2014, 10:44 AM   #30
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
Forum Activity 53%
I see now; I think I just misread it.
September '13 ROTM
2014 FiST-
