Mk3 Wheel Spacer Information - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Tech Discussions > Wheels & Tires - Sponsored By Tire Rack
Wheels & Tires - Sponsored By Tire Rack The place to go for answers on wheel types, tire sizes, offset, wheel patterns and more.
Sponsored By:
Tire Rack
Old 07-11-2013, 06:24 PM   #11
Vince
Vince's Avatar
Fan#: 115058
What I Drive: 2012, Black Tit X
FF Reputation: 1 Vince Good Standing Member
Awesome, lowering my car on vmaxx coilovers and want to space my 18x8 allpys out
Regards,
Vince
Vince is offline
Old 08-15-2013, 12:38 PM   #12
twinbiker11
twinbiker11's Avatar
Fan#: 108461
What I Drive: 2013 white Focus se, sport package
Points 383, Level 7
Points: 383, Level: 7 Points: 383, Level: 7 Points: 383, Level: 7
Level Up 66% Completed
FF Reputation: 1 twinbiker11 Good Standing Member
so i have a 13 se sport hatch and looking at spacers. i have the 17x7 stock rims with 215/50r17 with stock height. i measured it out and 25mm would be flush. so if i ran 15mm all around i would be fine without any rubbing issues correct?
2013 oxford white se + sport package
FS WERKS! race exhaust and itg filter.
new mission mod + ram air, 94 octane
15.22 sec @ 94mph 1/4m time
twinbiker11 is offline
Old 08-15-2013, 01:07 PM   #13
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 24,644, Level 95
Points: 24,644, Level: 95 Points: 24,644, Level: 95 Points: 24,644, Level: 95
Level Up 30% Completed
Forum Activity 9%
FF Reputation: 49 dyn085 Great Standing Member
That is correct, but to run 15mm up front you will either have your hubs pressed off to replace the studs or you will have to make alterations to your OEM studs and/or wheels in order to fit C30 DRM's. I would recommend 20mm instead.
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is online now
Old 08-15-2013, 02:52 PM   #14
twinbiker11
Fan#: 108461
Points 383, Level 7
what kind of alterations are we talking about? H&R spacers come with studs so i would have to get them pressed out anyways.
Old 08-15-2013, 04:25 PM   #15
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
Forum Activity 9%
I had to cut about 1.5 threads off along with opening the pockets in my 18's in order to fit the 15mm Volvo C30 DRM's. If you use the 20mm Focus DRM's, no modifications are necessary.
I don't know what tools you have available to you, but it's a bit of work to do the front studs and is why I usually recommend using DRM spacers. The rears, otoh, are quite easy and quick and can accept the longer studs that come with the 15mm spacers.
September '13 ROTM
2014 FiST-
Old 08-15-2013, 04:30 PM   #16
twinbiker11
Fan#: 108461
Points 383, Level 7
i had to cut about 1.5 threads off along with opening the pockets in my 18's in order to fit the 15mm volvo c30 drm's. If you use the 20mm focus drm's, no modifications are necessary.
I don't know what tools you have available to you, but it's a bit of work to do the front studs and is why i usually recommend using drm spacers. The rears, otoh, are quite easy and quick and can accept the longer studs that come with the 15mm spacers.
drm?
Old 08-15-2013, 05:22 PM   #17
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
Forum Activity 9%
drm?
Correct. Take a look at Trakplus.com and you'll see what I'm talking about. They are adapters-spacers that bolt on over your OEM lugs.
September '13 ROTM
2014 FiST-
Old 04-22-2014, 12:48 AM   #18
GR34TWHI73N0RTH
GR34TWHI73N0RTH's Avatar
Fan#: 96598
What I Drive: 2012 Black SE Sport 5 Spd
Points 1,953, Level 26
Points: 1,953, Level: 26 Points: 1,953, Level: 26 Points: 1,953, Level: 26
Level Up 53% Completed
FF Reputation: 1 GR34TWHI73N0RTH Good Standing Member
Just want to check before i purchase, i don't think i will run into problems but will i be ok with a:
Front: 10mm Rear: 15mm
w/
Offset: 45mm
Tire: 235/40/18
Springs: Sportline's
Thank you
Rally Revolution #333
GR34TWHI73N0RTH is offline
Old 04-22-2014, 05:00 AM   #19
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
Forum Activity 9%
w/
Offset: 45mm
Tire: 235/40/18
Thank you
I ran a 10/15 setup for a while with no issues. My only recommendation is to ensure you use a torque wrench and do a 10/100/500 mile torque-check because the 10mm spacer is actually 2mm thicker than the 'maximum' spacing available on the OEM lugs up front.
September '13 ROTM
2014 FiST-
Old 04-22-2014, 09:29 AM   #20
mishka
mishka's Avatar
Fan#: 107408
What I Drive: 13' TB SE Sport Sedan DCT 201A pack
Points 2,280, Level 28
Points: 2,280, Level: 28 Points: 2,280, Level: 28 Points: 2,280, Level: 28
Level Up 87% Completed
Level up: 87% Level up: 87% Level up: 87%
Forum Activity 2%
FF Reputation: 1 mishka Good Standing Member
hey all! still no problems here after installing H&R 20/25mm spacers on Sportline springs and 215/50/R17 tire. props to dyn085 again for helping me out with the fitment. This guy know his stuff lol.
I'm wondering if when I buy new tires, if I can upgrade to 235/40/R17 without messing up the fitment...
~ Shadowfax ~
mishka is offline
