Cv joing problems after changing please help :( - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-05-2013, 02:41 PM   #1
jayarkle
Fan#: 113033
What I Drive: 2001 1.8 16v green
FF Reputation: 1 jayarkle Good Standing Member
Hi everyone, ive had a problem with a clicky cv joint when steering, i changed it last night and on the way home from work noticed that theres slight vibration when driving at 40 - 50 then it goes when i speed up, anyone got any ideas what could be causing this would appreciate the help
Thanks
jay
jayarkle is offline
Old 04-05-2013, 02:53 PM   #2
Mr.Bergner
coffee, have some
Mr.Bergner's Avatar
Fan#: 32799
What I Drive: 2004 TW Blue ZX3
Points 6,353, Level 52
Points: 6,353, Level: 52 Points: 6,353, Level: 52 Points: 6,353, Level: 52
Level Up 2% Completed
FF Reputation: 53 Mr.Bergner Excellent Standing Member
Buy-Sell-Trade Rating: (12)
It could be the wheel bearing got a bit damaged during the removal of the shaft from the spindle. I had that happen to me, and I experienced very similar issues. If you jack up the front and take the wheels off, try rotating the disc manually and listen and feel for any sort of grinding or such.
2004 ZX3 MTX - Twighlight Blue_____________________________________________________________________________ _ _ _ _ _ _
Mr.Bergner is offline
Old 04-05-2013, 03:00 PM   #3
jayarkle
Fan#: 113033
ah ok thats possible because i had to tap the cv out of the hub il try that thank you for your time :)
jayarkle is offline
Old 04-05-2013, 07:13 PM   #4
jayarkle
Fan#: 113033
just went to check everything and it looked fine the bearing felt fine everything was tight took it for another test drive problem still there im wondering if the tracking is out after i disconnected the track rod end? or the wishbone bush at the bottom??
jayarkle is offline
Old 04-05-2013, 07:24 PM   #5
DarwinSays
DarwinSays's Avatar
Fan#: 35941
What I Drive: 2004 SVT Silver / EAP / CWP
Points 1,382, Level 20
Points: 1,382, Level: 20 Points: 1,382, Level: 20 Points: 1,382, Level: 20
Level Up 82% Completed
FF Reputation: 2 DarwinSays Good Standing Member
you wouldn't necessarily be able to tell by manipulating or looking at the bearing on or off the car. minor imperfections can have larger effects at speed.
Another possibility that no one has mentioned yet is that you nay have unknowingly purchased a re-manufactured part that wasn't re-manufactured correctly. I can't count how many times over the years I've encountered issues similar to this resulting from such parts, which is why I try to avoid re-mans anywhere I can, especially when it comes to major components (CV's, Pumps, calipers, etc.)
User Gallery
#include 'brain.h'
DarwinSays is offline
Old 04-05-2013, 07:30 PM   #6
jayarkle
Fan#: 113033
yea i thought the same thinking of going to the breakers yard and getting a whole shaft and replacing that to see if its any better, just a thought if i pulled the shaft out of the gear box am I going too loose all of the fluid inside?
jayarkle is offline
Old 04-06-2013, 11:54 PM   #7
amc49
Fan#: 96610
Points 3,359, Level 36
Points: 3,359, Level: 36 Points: 3,359, Level: 36 Points: 3,359, Level: 36
Level Up 6% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
Sounds like we're talking about the CV axle here right? Did you tighten the outer nut ALL THE WAY up to the full torque? Simply just getting it 'good and tight' will not suffice there, the nut starts backing off and the bearing then self destructs.
amc49 is offline
Old 04-07-2013, 12:02 AM   #8
02svtf300
02svtf300's Avatar
Fan#: 83769
What I Drive: 2002 sonic blue SVT(moded)
FF Reputation: 2 02svtf300 Good Standing Member
^^^ I did this... Was in a rush to get the driver side together and only made it about 40 miles before the rotor was contacting the caliper.
Sent from my HTC6435LVW using FF Mobile
02 sonic blue svtf...< modified addiction < DD
88 bronco II (x2)... < the twins
00 yamaha banshee... <will be the end of me
02svtf300 is offline
Old 04-08-2013, 08:27 PM   #9
jayarkle
Fan#: 113033
how much tourque should it be? 300ft/lb?? i didnt use a tourque wrench just did it up as tight as i could
jayarkle is offline
Old 04-08-2013, 08:36 PM   #10
jayarkle
Fan#: 113033
300nm rather??
jayarkle is offline
