turbo flange/manifold setup questions - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-04-2013, 06:00 PM   #1
MrTerryToYou
MrTerryToYou's Avatar
Fan#: 94976
What I Drive: 2001 Pitch Black ZX3
Points 980, Level 16
Points: 980, Level: 16 Points: 980, Level: 16 Points: 980, Level: 16
Level Up 80% Completed
Forum Activity 3%
FF Reputation: 1 MrTerryToYou Good Standing Member
Buy-Sell-Trade Rating: (7)
I wasn't planning on turboing my focus but a friend of mine gave me a used TD04L-13T turbo that he had lying around his house. It's from a 2.0L WRX. I've been seriously contemplating turbo charging my focus ever since. So I've been looking around at what i need to keep this build cheap and reliable and still make some good power. So far i think that the most expensive piece to this is going to be the tuning portion. But i need help to figure out a few things.
Vehicle: 2001 Ford focus zx3 (pitch black), 2.0L Zetec
Power Goal: 230-250Hp (not sure if that's more realistic at the wheels or at the crank?)
Main goal: RELIABLE, cheap (in price not quality(for the most part)), efficient and awesome!
1. What type of flange do i need? I've been looking at the SPA manifold. I found one on ebay for $150ish. But it says it will fit T3 & T3/T4 turbos. WHAT TYPE OF FLANGE IS A TD04L-13T?
2.I already have a Focus Central 2.5" stealth Catback exhaust. down pipe? Er :-\ what size inlet/outlets? Also catalytic converter? How's that work?
3. Intake? Thinking maybe delete everything that's already stock and in there for room and better flow through the engine compartment maybe with a flex pipe similar to the snorkel on the stock airbox?
4. I can't spend money on the fuel system stuff right now as I'm in school and don't make much money. So minimal requirements... Thinking i can do it on stock injectors, fuel lines, fuel rail and pump. until i can afford to start upgrading them.
5. Clutch & Tranny... I have a MYX-75 Trans. My third gear synchro is shot and i have to double clutch to use it. I know that i will eventually have to buy/rebuild my Tranny. I love how fast i am off the line now. I've read that the MTX-75 I'd a closer ratio than the Getrag.here is where I'm torn. I burn through gears now and I'm just NA that will only get worse with the turbo. So should i just add the bigger final drive I've read alittle about if i decide to keep the 5-speed and when rebuild or replace is inevitable or do I go with the Getrag? I need more info on thus and opinions and thoughts? I'm thinking i will probably go with the Getrag eventually. Not till the MTX-75 dies though.
6. Oil and cooling... I've been thinking about rerouting my oil filter strictly because it's a PITA to get to when i have to do an oil change. With that and the turbo added i know i netted oil lines for the cooling of the turbo. Can I do the rerouting and the oil lines for the turbo reliably? Suggestions on pieces needed would be nice.
7. Motor mounts/torsen... I know I'm going to go through mounts if i keep stock OEM mounts, i love massives motor mounts especially their new line (the unbreakable mounts) what are these torsen (bars/mounts) I've seen around a few? They look beefy and awesome! Pros and cons?
That's it for now.
This is not my build thread strictly questions i need answered before i start my build thread.
Thanks everyone in advance for all of your advice and thoughts.
ESQUILAX-The Black Squirrel Of Death-01ZX3-Roush Suspension, 15x7 RotaRBs, SVT EM, ORP, FS FBE, EGR Del, Y2K IM 65mm, 3"MAF Tube, SteedaTB, Iceman Int, FR Wires, Cop Plugs, HP Timing Belt, Fidanza CamGears, Spec Stg2 Clutch, CM Flywheel
MrTerryToYou is offline
Old 04-08-2013, 10:34 AM   #2
MrTerryToYou
Fan#: 94976
Forum Activity 3%
Wow. Really no replies!? Too much information or what? No one want to help. Ok well thanks anyways guys. 96 views and no replies :-(
Old 04-08-2013, 05:24 PM   #3
anarchy0392
Fan#: 102873
What I Drive: 2002, Silver, SE
Points 1,634, Level 23
Points: 1,634, Level: 23 Points: 1,634, Level: 23 Points: 1,634, Level: 23
Level Up 34% Completed
FF Reputation: 2 anarchy0392 Good Standing Member
Buy-Sell-Trade Rating: (9)
Maybe no one knows try sending Tom a pm or someone else. I bet you goggled already but maybe try a little harder. But what might be a better idea is go to a muffler shop and ask a more senior tech.
anarchy0392 is offline
Old 04-08-2013, 05:33 PM   #4
MrTerryToYou
Fan#: 94976
Forum Activity 3%
I actually figured most of it out already. I'll be posting my findings very soon. Maybe it will help someone else.
Old 04-08-2013, 06:25 PM   #5
anarchy0392
Fan#: 102873
Okay that's kool I'd like to know also.
Old 04-08-2013, 06:34 PM   #6
drunkyoda
Hmmmmm
drunkyoda's Avatar
Fan#: 65151
What I Drive: 2003 Pitch Black LX
Points 13,451, Level 75
Points: 13,451, Level: 75 Points: 13,451, Level: 75 Points: 13,451, Level: 75
Level Up 51% Completed
Level up: 51% Level up: 51% Level up: 51%
FF Reputation: 9 drunkyoda Good Standing Member
what are you contemplating the intake for?
the turbo is your intake... you HAVE to get bigger injectors.
2003 Focus Sedan - Sold but not forgotten
2014 Mustang V6 - Current
drunkyoda is offline
Old 04-08-2013, 06:39 PM   #7
MrTerryToYou
Fan#: 94976
Forum Activity 3%
Totes! Will probably get it up tomorrow.
Old 04-08-2013, 06:48 PM   #8
drunkyoda
Hmmmmm
drunkyoda's Avatar
Fan#: 65151
i am also doing a budget build...
SPA turbo kit- 800
MAFia - 140
xcal 2 -100
Tuning - about 300
intercooler setup - prob about 150
injectors - 120
i will prob need some other little bits and pieces
Old 04-23-2013, 12:20 PM   #9
MrTerryToYou
Fan#: 94976
Forum Activity 3%
So I need bigger injectors? Stock zetec are 24# right. So would 30# svt injectors be enough or do I need bigger?
Sent from my SPH-L900 using FF Mobile
Old 04-23-2013, 12:30 PM   #10
MrTerryToYou
Fan#: 94976
Forum Activity 3%
So far this is what I'm thinking.
Have not purchased these but im pricing stuff out right now.
SPA manifold - $159 on ebay. Also will need a block off plate for the built in external wastegate opening. And will probably have to make my own adapter plate for the turbo to manifold.
WRX turbo rebuild kit - $60
Intercooler and piping - $150 on ebay 2.5"
internal Waste gate actuator - $50
Xcal - $375 new but I'll probably buy one off the forums for alot cheaper.
Tune - $300
Downpipe - $? Need more research.
BOV/BPV/Diverter Valve -$? Need more research.
MAFia - $? Need more research.
I did just buy a 3 inch CFM mafe tube. Was thinking about having the intake side be 3 inch. But the intercooler and piping mostly come in 2.5 inch. Need more research.
