2014 changes - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-04-2013, 05:05 PM   #21
Roadworthy
Fan#: 109039
What I Drive: 2012 SGM MK3 Titanium
FF Reputation: 1 Roadworthy Good Standing Member
Originally Posted by pozi240 View Post
Yeah, because that has worked SO well for Mazda. Yes, it improved performance and mileage very marginally over the previous 2.0L and 2.5L, but, read the Mazda forums and blogs.... not enough of an increase for the added cost and issues they`re seeing now. Our current GDI 2.0L has a 12:1 CR which is quite high (motorcycle territory) and without the `magic`Skyactiv crap.
Mazda didn't use their fancy 4-2-1 header that would allow the higher compressions in North America. Engine configuration didn't allow the room. The 'newer' 2 and 2.5 DI engines are still on the lower spec compression ratios.
You do realize that their Skyactiv engines are, would you believe, almost identical aside from bore/stroke? So yeah, the current batch of Skyactive engines aren't that wow people expected because they aren't fully utilizing all of the Skyactive specs (body structure and transmission aside).
2012 SGM Ti DCT Stock and loving it
OEM multispoke 17" with stock rubber summer-X-ice 3's on stuck rims = awesomesauce
Roadworthy is offline
Old 04-04-2013, 05:25 PM   #22
flyboyike
Fan#: 98206
What I Drive: 2012 Race Red SE sedan
Points 335, Level 6
Points: 335, Level: 6 Points: 335, Level: 6 Points: 335, Level: 6
Level Up 70% Completed
Forum Activity 7%
FF Reputation: 3 flyboyike Good Standing Member
Originally Posted by dan50 View Post
Finally, do we really want the complexity of a turbo engineered by the same bunch that did the DCT? Just sayin...
Honeywell doesn't engineer transmissions, but carry on.
flyboyike is offline
Old 04-04-2013, 05:52 PM   #23
dan50
Fan#: 91789
What I Drive: 2012 SEL White Platinum 5 Dr 302A
Points 3,070, Level 34
Points: 3,070, Level: 34 Points: 3,070, Level: 34 Points: 3,070, Level: 34
Level Up 14% Completed
Forum Activity 2%
FF Reputation: 12 dan50 Great Standing Member
Yes there are lots of component manufacturers, like Honeywell and Getrag. But Ford has the overall engineering responsibility for choosing, specifying and integrating components. Given the "fail" on the DCT, we should be confident the EcoBoost effort will have a different outcome? This was the engine with 2 recalls, including a "do not drive" caution. And it's still early.
dan50 is offline
Old 04-04-2013, 06:03 PM   #24
flyboyike
Fan#: 98206
Points 335, Level 6
Forum Activity 7%
I agree, ever since my Blaupunkt radio failed, I quit buying Bilsteins. I mean, we just can't be sure.
Old 04-04-2013, 07:03 PM   #25
MisterH
Fan#: 89103
What I Drive: 2012 Sterling Gray Metallic SE
Points 122, Level 2
Points: 122, Level: 2 Points: 122, Level: 2 Points: 122, Level: 2
Level Up 44% Completed
FF Reputation: 2 MisterH Good Standing Member
Originally Posted by suss6052 View Post
Unless the dealer specifically ordered one for inventory Ford had said essentially that the 6MT 1.6L EcoBoost Fusion would be customer order only and they didn't expect that the dealers would actually stock them.
So customers can't test one before ordering/buying? Makes plenty of sense.
2012 Ford Focus SE Sedan, 5 Speed, 203A, Sterling Gray Metallic
MisterH is offline
Old 04-04-2013, 07:25 PM   #26
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,220, Level 67
Points: 10,220, Level: 67 Points: 10,220, Level: 67 Points: 10,220, Level: 67
Level Up 43% Completed
Forum Activity 32%
Activity: 32% Activity: 32% Activity: 32%
FF Reputation: 26 suss6052 Great Standing Member
Per the 2013 Ford Fusion order guide yes unless you're committed to buying one you can't get one built. You could always back out later, but if you do you'd better have a damned good reason especially if it was ordered on a/z/d/x plans.
Dealers cannot order one for stock, it has to be a retail order i.e. one with a named or intended buyer or they won't build it.
suss6052 is online now
Old 04-04-2013, 07:35 PM   #27
flyboyike
Fan#: 98206
Points 335, Level 6
Forum Activity 7%
Isn't an O/T 2 also a retail order? By non-retail, don't they mean O/T 5?
Old 04-04-2013, 07:39 PM   #28
suss6052
suss6052's Avatar
Fan#: 95752
Forum Activity 32%
Huh? I don't work for a dealer so I don't know the codes, but the order priorities went from 10-99 and a 99 was a do not schedule ever, 10 was the highest priority a dealer could assign without intervention from Ford, which I found out when I'd ordered mine.
Ordering for dealer stock is a non retail order.
an OT (order type) 1 = Retail sold unit, WILL get built faster than an OT 2 = Dealer Stock.
http://www.fordraptorforum.com/f4/20...vs-retail-668/
No an order type 2 is a dealer stock order, aka not a retail sold order.
Old 04-04-2013, 07:40 PM   #29
flyboyike
Fan#: 98206
Points 335, Level 6
Forum Activity 7%
Says who?
Old 04-04-2013, 07:41 PM   #30
flyboyike
Fan#: 98206
Points 335, Level 6
Forum Activity 7%
I'm not talking about priorities, I'm talking about order types, which appears to be the issue here.
