Rear Motor Mount - Page 6 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-23-2013, 12:49 PM   #51
RedVAhb757
Fan#: 111780
What I Drive: 2013 Oxford white ST
FF Reputation: 1 RedVAhb757 Good Standing Member
Imma get a shop to do it. Only have 1 floor jack & 2 jack stands. Don't wanna risk getting crushed by a car knowing my luck.
Ordered the mount & bolt. Guy in parts showed me the difference & it is obvious between the 2.
RedVAhb757 is offline
Old 04-23-2013, 02:34 PM   #52
amoosenamedhank
Fan#: 96374
What I Drive: 2012 SE Hatch
Points 880, Level 15
Points: 880, Level: 15 Points: 880, Level: 15 Points: 880, Level: 15
Level Up 80% Completed
FF Reputation: 3 amoosenamedhank Good Standing Member
Originally Posted by Darth Obvious View Post
There are little triangle arrows along the side plastic panels near the bottom edge of the car that point to jack spots. If you aren't sure where, it should show you in the owner's manual.
Also, you will have to support the engine with at least one jack near the mount, so that when you remove the mount itself the engine is still being supported.
Yeah... you don't have to support the engine. It's not going anywhere.
You saw it cuz I tapped it
What's that?? You'd like an eco-tune...
amoosenamedhank is offline
Old 04-23-2013, 02:45 PM   #53
rickdarris2004
rickdarris2004's Avatar
Fan#: 108926
What I Drive: 2014 Mazda 6 Touring
FF Reputation: 1 rickdarris2004 Good Standing Member
I did mine on ramps, It was easy.
rickdarris2004 is offline
Old 04-23-2013, 03:16 PM   #54
Darth Obvious
Fan#: 113422
What I Drive: 2013 Focus SE Sedan - Manual
FF Reputation: 1 Darth Obvious Good Standing Member
Good to know.
Darth Obvious is offline
Old 04-23-2013, 03:46 PM   #55
_RED_
Sonic's MK3 Crew #02
_RED_'s Avatar
Fan#: 10712
What I Drive: 2014 Fiesta ST
Points 41,261, Level 100
Points: 41,261, Level: 100 Points: 41,261, Level: 100 Points: 41,261, Level: 100
Level Up 0% Completed
Forum Activity 3%
FF Reputation: 2 _RED_ Good Standing Member
The rear motor mount does not support the engine. Meaning you will be able to pull the stock mount and replace it without needing anything. Just pull the cover under the engine off and go at it :thumbup:
Sent from my Galaxy Note 2
'14 Fiesta ST
234 HP / 274 TQ
SCT Tune & Injen Intake, MBRP Catback
Moderator: Third Generation Ford Focus, DURATEC Ti-VCT GDI Performance Chat & Florida regional section
_RED_ is online now
Old 04-23-2013, 08:58 PM   #56
asting
Fan#: 98342
What I Drive: 2012, Tux Blk Met Focus 5d Sport
Points 509, Level 10
Points: 509, Level: 10 Points: 509, Level: 10 Points: 509, Level: 10
Level Up 18% Completed
FF Reputation: 1 asting Good Standing Member
Yep!
I'm not sure if I did it wrong, but I had to pull both brackets (the rear motor mount and the bracket it connects to). If I tried to just pull the mount without disconnect the arm/bracket it didn't fit from what I could tell.
You'll know what I mean when you're down there.
Quite a simple install, 20minutes if you're fast, an hour if you're slow and take your time.
2012 SE Hatch - 5 Speed - Tuxedo Black
Engine: K&N Typhoon CAI, Magnaflow 2.25 exhaust 15072
Suspension: MS3 Springs, Focus electric RMM.
Audio: LC6i, Polk Audio db6501 front, db651s rear, db1040DVC sub, Rockford R600-5 Prime, Fatmat
asting is offline
Old 04-23-2013, 09:44 PM   #57
_RED_
_RED_'s Avatar
Fan#: 10712
Forum Activity 3%
I forgot about the support bracket, did mine last summer lol.
'14 Fiesta ST
234 HP / 274 TQ
_RED_ is online now
Old 04-24-2013, 12:37 PM   #58
RedVAhb757
Fan#: 111780
Torque specs for both bolts?
Old 05-02-2013, 06:59 PM   #59
_RED_
_RED_'s Avatar
Fan#: 10712
Forum Activity 3%
Just wanted to pop in and say I picked up the Steeda RMM today. I swapped the 77 durometer urethane inserts with the stiffer 88 durometer inserts. There are a lot of vibrations in the car at idle and coming off idle into 1st gear, with a little extra throttle though this solves some of the more severe vibrations, for most I would recommend staying with the 77 durometer inserts.
This is with the 88 inserts in.
Name:	uploadfromFF Mobile1367535563346.jpg
And this is out of the box, with the 77 durometer urethane inserts
Name:	uploadfromFF Mobile1367535597634.jpg
'14 Fiesta ST
234 HP / 274 TQ
_RED_ is online now
Old 05-02-2013, 07:57 PM   #60
amoosenamedhank
Fan#: 96374
What is your idle rpm set to?
