Rear Motor Mount - Page 18 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-13-2013, 08:50 AM   #171
ChalupaJones
ChalupaJones's Avatar
Fan#: 110818
What I Drive: 2012, Sonic Blue, Focus S
Points 3,068, Level 34
Points: 3,068, Level: 34 Points: 3,068, Level: 34 Points: 3,068, Level: 34
Level Up 12% Completed
Forum Activity 74%
Activity: 74% Activity: 74% Activity: 74%
FF Reputation: 2 ChalupaJones Good Standing Member
Looks good. Let us now how much nvh there is.
2012 Focus S Sedan, Sonic Blue, E-RMM, K&N drop in filter, Snorkel Delete, Steeda blue shift knob and STS, blue HVAC knobs, Trunk Lid Liner
- more to come
Military crew, Blue Focus Crew, Chalupa Crew #1
ChalupaJones is online now
Old 06-13-2013, 09:37 AM   #172
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
Originally Posted by mishka View Post
is the rmm a thing that can be installed by someone who doesnt really know what they are doing as long as I follow the instructions? I heard it is really expensive, labor wise, to get installed
Basically, if you can turn a wrench, you can do the RMM swap. There are 5 bolts--two to attach the RMM itself, and three on the bracket that connects the RMM to the engine block. You can't swap the RMM without detaching the bracket.
If you need instructions, you will need to buy an RMM from an aftermarket company such as Cobb, Steeda, etc. RMMs purchased from Ford or Mazda will not come with instructions. It's pretty self-explanatory, but I suppose you may require instructions depending on your skill level. If it hasn't been done already, an FF member should do a brief write-up on the swap so that less-experienced owners feel more confident installing the Ford and Mazda parts.
With that said, IMO, the Ford and Mazda parts have much higher value for the money spent--"bang for the buck", if you will--because they don't have the "bling" that the aftermarket parts have, such as anodized or powder-coated finishes and laser-etched logos. I've never quite understood why people want that "bling" on a part that can only be seen while working under the car, but to each his own. Higher-durometer (stiffer) bushings can be had with the aftermarket offerings of course, but the FFE RMM is plenty stiff for a daily driver, IMO.
Hatch Nation #90
TboneZX3 is offline
Old 06-13-2013, 11:04 AM   #173
mishka
mishka's Avatar
Fan#: 107408
What I Drive: 13' TB SE Sport Sedan DCT 201A pack
Points 2,308, Level 29
Points: 2,308, Level: 29 Points: 2,308, Level: 29 Points: 2,308, Level: 29
Level Up 6% Completed
FF Reputation: 1 mishka Good Standing Member
i've been wondering... is there a reason the ffe rmm is stiffer than non-electric foci? you would think comfort would be the idea with the ffe.
i am daily driver of my focus, but I like to race now and then.
the ffe rmm will help enough but still not introduce NVH?
~ Shadowfax ~ 169.5 whp; 156.5 torque
mishka is offline
Old 06-13-2013, 11:14 AM   #174
DerrekForreal
DerrekForreal's Avatar
Fan#: 53921
What I Drive: 2010 Ford Flex - Cinnamon Metallic
Points 978, Level 16
Points: 978, Level: 16 Points: 978, Level: 16 Points: 978, Level: 16
Level Up 78% Completed
FF Reputation: 1 DerrekForreal Good Standing Member
I have the FFE RMM installed...Could you define "NVH" for me?
DerrekForreal is offline
Old 06-13-2013, 11:25 AM   #175
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,042, Level 66
Points: 10,042, Level: 66 Points: 10,042, Level: 66 Points: 10,042, Level: 66
Level Up 98% Completed
Forum Activity 24%
The RMM is stiffer on the Electric Focus due to the higher torque and lower vibrations generated by the electric traction motor. Now why the ST didn't come from the factory with this or an even stiffer mount rather than the paper mache n/a mount is beyond me. I can literally compress it with just one or two fingers and 5-10 lb of effort, so imagine the pummeling it takes with just 148 lb-ft of torque, then amplify that to over 270 lb-ft of torque in the ST.
Of course there is now a service bulletin for the ST, but the parts are on national back order with no ETA for the transmission mount that's also to be replaced.
NVH= Noise Vibration and Harshness, i.e. increased vibrations into the cabin through reduced engine movement may cause an increase in NVH felt by the occupants, but not really with the Focus Electric mount as it's not going to increase vibrations all that much over stock if at all.
suss6052 is online now
Old 06-13-2013, 11:30 AM   #176
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 25,182, Level 95
Points: 25,182, Level: 95 Points: 25,182, Level: 95 Points: 25,182, Level: 95
Level Up 84% Completed
Forum Activity 4%
It isn't just the torque, it's also the fact that it's an electric motor that doesn't have the vibration a reciprocating engine has to begin with.
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is offline
Old 06-13-2013, 11:31 AM   #177
ProjectCommuter
ProjectCommuter's Avatar
Fan#: 105046
What I Drive: 2012 Oxford White Focus SE 5MT
Points 589, Level 11
Points: 589, Level: 11 Points: 589, Level: 11 Points: 589, Level: 11
Forum Activity 4%
FF Reputation: 2 ProjectCommuter Good Standing Member
I just did the swap. In my opinion it is a MUST DO! No difference in vibration but a lot in drivability, especially with a manual.
ProjectCommuter is offline
Old 06-13-2013, 11:53 AM   #178
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
IMO, yes. The benefits that the FFE RMM offers for hard launches, power transfer and improved drivetrain "feel" far outweigh the very slight (nearly imperceptible) increase in NVH over the stock RMM. You really can't go wrong with this upgrade for the $45-50 you'll spend.
Hatch Nation #90
TboneZX3 is offline
Old 06-13-2013, 11:59 AM   #179
DerrekForreal
Fan#: 53921
Thank you for definition!
Agreed! And to be honest, the "slight" NVH I noticed mostly went away within a few days of driving. I now notice it only at cold start..if then. The 'pros' -fun factor, far outweighs and 'con' -vibration.
Old 06-13-2013, 12:05 PM   #180
Borski
Borski's Avatar
Fan#: 100013
What I Drive: 2012 Focus - Black - SE
Points 1,260, Level 19
Points: 1,260, Level: 19 Points: 1,260, Level: 19 Points: 1,260, Level: 19
Level Up 60% Completed
FF Reputation: 1 Borski Good Standing Member
How are we sure this isn't the classic "mod placebo" effect? Is it really THAT noticeable on the manuals.
Sent from my HTC One X using FF Mobile
| 2012 BLACK SE | DD & AutoX |
| 5 SPEED | SPORT PACKAGE |
| EIBACH SPORTLINE SPRINGS | SUMMER RUBBER: BF GOODRICH SPORT-COMP 2. ALL SEASON RUBBER: KUMHO ECSTA 4X |
Borski is offline
