Rear Motor Mount - Page 16 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-31-2013, 02:52 PM   #151
amoosenamedhank
Fan#: 96374
What I Drive: 2012 SE Hatch
Points 880, Level 15
Points: 880, Level: 15 Points: 880, Level: 15 Points: 880, Level: 15
Level Up 80% Completed
FF Reputation: 3 amoosenamedhank Good Standing Member
Originally Posted by suss6052 View Post
Guys are already at that point with just an intake and exhaust, well at least the 5MT guys were.
The stock mounts are a hinderance even at stock power levels on the N/A on anything other than smooth roads with the tcs turned off. The side mount might not be as necessary with 160 hp (necessary to replace it that is), however doing so would greatly restrict engine movement.
to add to this point... have any of you NA guys ever grabbed your engine and rocked it back and forth and watched the flex in the PMM? You can literally see the deflection in the rubber as you're pulling it by hand.
What's that?? You'd like an eco-tune...
amoosenamedhank is offline
Old 05-31-2013, 05:21 PM   #152
ChalupaJones
ChalupaJones's Avatar
Fan#: 110818
What I Drive: 2012, Sonic Blue, Focus S
Points 3,566, Level 37
Points: 3,566, Level: 37 Points: 3,566, Level: 37 Points: 3,566, Level: 37
Level Up 44% Completed
Forum Activity 60%
Activity: 60% Activity: 60% Activity: 60%
FF Reputation: 2 ChalupaJones Good Standing Member
The rmm is still a huge must on my to do list. I'm on the fence about the side mount. I don't think I'll really need something like that unless I were to go beyond what I have right now.
2012 Focus S Sedan, Sonic Blue, E-RMM, K&N drop in filter, Snorkel Delete, Steeda blue shift knob and STS, blue HVAC knobs, Trunk Lid Liner
- more to come
Military crew, Blue Focus Crew, Chalupa Crew #1
ChalupaJones is offline
Old 06-01-2013, 02:21 PM   #153
FocusTi
FocusTi's Avatar
Fan#: 102567
What I Drive: Black 2012 Ford Focus Titanium
FF Reputation: 1 FocusTi Good Standing Member
Just installed my focus electric rear motor mount. As soon as I left my driveway, I noticed the difference. More of the engines power is making to the ground and when the DCT shifts, it is a lot more direct in a way because the engine is not rocking back and forth like it was with the stock mount. I highly recommend this mount, especially for the price.
As for vibration in the cabin, none that I can feel. This mount is total win.
Current Mods: Snorkel Delete with ITG Filter and newmission intake, Rear Sway-Bar, Magnaflow Exhaust, RMM and Hitch
Future Mods: Coilovers, End-Links, Tune, and Brakes
FocusTi is offline
Old 06-01-2013, 11:45 PM   #154
DerrekForreal
DerrekForreal's Avatar
Fan#: 53921
What I Drive: 2010 Ford Flex - Cinnamon Metallic
Points 983, Level 16
Points: 983, Level: 16 Points: 983, Level: 16 Points: 983, Level: 16
Level Up 83% Completed
Level up: 83% Level up: 83% Level up: 83%
FF Reputation: 1 DerrekForreal Good Standing Member
^DITTO!
Just put the E- Focus RMM in my car this afternoon. I could tell the difference in the first three shifts! (5-speed) Amazing difference!!
Without a doubt more power getting to the wheels quicker. I notice a bit of vibration in the steering column at idle, but thinking that will dissipate once broken in. (The difference is so awesome the slight vibration is worth it)!
DerrekForreal is offline
Old 06-02-2013, 12:34 AM   #155
Joeywhat
Strichmädchen & Koks
Joeywhat's Avatar
Fan#: 85247
What I Drive: 2014 Mustang 3.7L SGM
Points 8,138, Level 60
Points: 8,138, Level: 60 Points: 8,138, Level: 60 Points: 8,138, Level: 60
Level Up 94% Completed
Forum Activity 7%
FF Reputation: 11 Joeywhat Great Standing Member
Are these instructions more or less good for doing the e-Focus mount?
I have to imagine it's pretty straight forward...but figured I'd make sure. What should everything be torqued to?
Hatch Nation #29
Joeywhat is offline
Old 06-02-2013, 12:46 AM   #156
DerrekForreal
Fan#: 53921
I used no instructions. Just put the car up and started removing bolts on the RMM. Ran into a snag - watched 3 min YouTube video of RMM change on the Focus ST; this made me realize I had missed one bolt. Removed that, and all was well. I torqued the bolts to what my arm felt was the same they were when I broke them loose (as I do not have a torque wrench).
Old 06-02-2013, 02:06 AM   #157
darkangelism
Sonic Crew #04
darkangelism's Avatar
Fan#: 85425
What I Drive: 2012 Focus Titanium Hatch
Points 4,358, Level 42
Points: 4,358, Level: 42 Points: 4,358, Level: 42 Points: 4,358, Level: 42
Level Up 4% Completed
Forum Activity 5%
FF Reputation: 9 darkangelism Good Standing Member
From what I have read 80 ft lbs
darkangelism is offline
Old 06-02-2013, 10:43 PM   #158
FocusTi
FocusTi's Avatar
Fan#: 102567
I got hung up on the same bolt. It is the one above the bracket connected to the transmission. Could not see it at first and was scratching my head for a little bit until I found it. Best 50 bucks spent.
FocusTi is offline
Old 06-02-2013, 10:57 PM   #159
DerrekForreal
Fan#: 53921
Without a doubt best $45-50 I spent!!
Old 06-03-2013, 08:23 AM   #160
cheekedave
Fan#: 103448
What I Drive: 2012 Focus SEL Silver
FF Reputation: 1 cheekedave Good Standing Member
My only worry is the engine would drop or something? Is this an issue? I have a ramp I use for changing my oil I assume this is good enough.. Are there any extra tricks to it or just lift, unbolt and throw the new one in its place? I didn't think it would be that simple.
cheekedave is offline
