rear wing removal step by step instrux - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus SVT > Focus SVT
Focus SVT The place to chat about general questions, window tinting, exterior body, interior and lighting upgrades for the MK1 2002-2004 Focus SVT.
Old 04-11-2013, 05:27 PM   #11
Sniperx
Sniperx's Avatar
Fan#: 99628
What I Drive: 2004 White ZX3, 1985 BMW M535 Dinan
FF Reputation: 2 Sniperx Good Standing Member
Wow, the studs shouldn't be facing down. I have only seen three wings removed but everyone of them had the studs pointing straight in and not bent down. Basically the studs are only used for alignment and shouldn't be bent at all. If you have one that is bent that means something is seriously wrong with it.
I do mean with the hatch open, this IS a 3 door hatch SVT....So when I say facing down, I mean with the hatch open.
Hatch Nation Member #165
Resistance is not Futile, it is voltage divided by current.
Sniperx is offline
Old 04-17-2013, 05:17 PM   #12
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,001, Level 74
Points: 13,001, Level: 74 Points: 13,001, Level: 74 Points: 13,001, Level: 74
Level Up 38% Completed
Forum Activity 33%
Activity: 33% Activity: 33% Activity: 33%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (45)
Ohhh ok, I took out the bolts with the hatch up. Then had it closed when I was removing the wing. But as I said, that double sided tape is probably the most pain in the ass part of the removal.
zetecDon is offline
Old 04-17-2013, 05:23 PM   #13
Sniperx
Sniperx's Avatar
Fan#: 99628
I have a great method for getting things off that are held on with double stick tape. Get a guitar string, the thinnest one. Tie each end on to a dowell rod about in inch in diameter and about 4in long. Slide the guitar string in the slot between the item that it stuck on to the car, and the car, hold each dowell rod in each hand with the string in between your two middle fingers and just slide the string between the item and the car. The tape slices right thru and the item releases right away.
Sniperx is offline
