HELP! Fog bulbs,HID H11 instalation,Focus mk2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-02-2013, 03:58 PM   #1
dzonifocus
Fan#: 112865
What I Drive: 2006,blue,Ford Focus
FF Reputation: 1 dzonifocus Good Standing Member
Exclamation HELP! Fog bulbs,HID H11 instalation,Focus mk2
Want to replace H8 35w Halogen bulb for fog lights with H11 HID kit 55w on My Focus 1.6 TDci 2006, will that work? and will i damage something? I was looking on net what bulbs my car use so i dont need to take them off,and most of them say H11 ,just open the fog lights and i saw H8,problem is that because i bought already H11 ones so im asking,can i install them without harming something ?And wanna know difference between H8 and H11 Please help...Thanks
dzonifocus is offline
Old 04-02-2013, 11:49 PM   #2
calebstubstad
Chef Boyardee
calebstubstad's Avatar
Fan#: 103240
What I Drive: 2000 Atlantic Blue LX
Points 2,716, Level 31
Points: 2,716, Level: 31 Points: 2,716, Level: 31 Points: 2,716, Level: 31
Level Up 78% Completed
FF Reputation: 4 calebstubstad Good Standing Member
double post
Rally Revolution #43
[HOONIGAN]
Originally Posted by matmatician View Post
Not the bear the zoo deserves, but the bear the zoo needs.
calebstubstad is offline
Old 04-03-2013, 09:01 AM   #3
gtferrari
gtferrari's Avatar
Fan#: 88110
Location: Grand Rapids/Big Rapids/Bangor/South Haven, MI
What I Drive: 2008 Vista Blue SES Coupe
Points 969, Level 16
Level Up 69% Completed
FF Reputation: 4 gtferrari Good Standing Member
No you will bit hurt anything. Supposedly there is a slight difference in the base of the bulb that may or may not need to be filed down to get it to lock into the light housing
2008 Vista Blue SES Coupe 5spd FRPP Zx3B Suspension
5000K D2S Retrofit
130,000+ miles and still on factory brakes and clutch!
Rep Points dont add themselves
gtferrari is offline
Old 04-03-2013, 09:53 AM   #4
dzonifocus
Fan#: 112865
So is kind a safe to replace it? i know the HID's bulb is 50% cooler then halogen bulb so no danger of overheat i don't know only will the fuse blows?
Old 04-03-2013, 11:17 AM   #5
gtferrari
gtferrari's Avatar
Fan#: 88110
safe for the housing and safe for the wires. there is a slight bit more amperage at start up but then it drops. you will get better results if you use a relay harness as you will be bypassing the cars harness and will be using larger wires and will be connected to the battery and not a computer board. your factory wires plug into a relay and control the lights that way. the relay only takes a fraction of the power the stock bulbs did. you can find the relay harnesses on ebay for next to nothing.
i am running 55watt hid lights off of my factory harness no problem and have been for 3 years
5000K D2S Retrofit
Old 04-03-2013, 12:11 PM   #6
dzonifocus
Fan#: 112865
Was wrong Its actually 35w Hid which is better i think because the same like halogen was , :) i think will be not a problem then,only i hope the bulb will easy lock up in housing, and i think is easy to install H11 HID,was watching some videos about it ,and i got a relay in the package. :) Thanks.
Old 04-04-2013, 11:09 AM   #7
dzonifocus
Fan#: 112865
Just installed H11 HID 35w on my H8 fogs work grate,they got in easy in housing :)
