It happened again !!!! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-02-2013, 12:09 AM   #1
Mylittleredfocus
Fan#: 74445
What I Drive: 2001 red se
FF Reputation: 1 Mylittleredfocus Good Standing Member
I posted a few days ago a no start on 2001 Focus SE.Everbody who responded and agreed that maybe my Positive cable was bad.I fixed that problem and moved on. Tonight it wouldn't start again.It started ran ruogh and died.So squirted some starting fluid ito the intake.She started and ran 3 seconds. I started the car this 4 times before she kept running,I am know thinking fuel problems. How do I check the fuel pressure and with what tool. I have a scan tool for use on the car.What other ideas and checks can I make for fuel delivery and fuel pressure.what tools will I need and is there a link to a site to see how to do this. Thanks !!!!!!
Mylittleredfocus is offline
Old 04-02-2013, 05:32 AM   #2
TheGlassMaker
REVOLT.BUILD.RISE
TheGlassMaker's Avatar
Fan#: 69510
Points 35,430, Level 100
Points: 35,430, Level: 100 Points: 35,430, Level: 100 Points: 35,430, Level: 100
Level Up 0% Completed
Forum Activity 5%
I'm sorry I missed the last thread. What engine do you have?
Sent from 34.0764 N, 118.4296 W
TheGlassMaker is online now
Old 04-02-2013, 06:27 AM   #3
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,736, Level 98
Level Up 39% Completed
Forum Activity 5%
Right- what engine is in your car? I would think that since it is running on starting fluid, the problem is likely to be fuel. Have you done the generic fuel pump test? Key off, turn key on and listen. You should hear a fuel pump buzz for about 3 seconds. If you don't hear the fuel pump, then that's one sign of a bad pump or something else bad.
Let us know if you can do this simple test. BTW, this test can be done on any EFI car. So you might want to get in another car that is running and listen for it's pump.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 04-02-2013, 06:39 AM   #4
Milton
Fan#: 89715
What I Drive: 2007 Black Focus SES 2.0 L4 4 Door
Points 324, Level 6
Points: 324, Level: 6 Points: 324, Level: 6 Points: 324, Level: 6
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
Forum Activity 10%
FF Reputation: 8 Milton Good Standing Member
So you have an intermittent fuel issue? The fuel pump relay can be a source of intermittent failures. Just replaced mine for $7.
Good luck
Milton is offline
Old 04-02-2013, 09:29 AM   #5
Mylittleredfocus
Fan#: 74445
1valve dual overhead cam 16 valve 2.0 or 1.6 engine ?I will check tonight but the problem seems to be intermittent
Old 04-02-2013, 08:23 PM   #6
TheGlassMaker
REVOLT.BUILD.RISE
Fan#: 69510
Forum Activity 5%
Well you can't have the 1.6 it wasn't avaliable here. So you most likly have either the 2.0 zetec dohc or the 2.0 SPI sohc.
