Starting issues. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-01-2013, 05:11 PM   #1
Mikehinkle
Fan#: 112131
What I Drive: 2005 black focus
FF Reputation: 1 Mikehinkle Good Standing Member
Starting issues.
Have to hold the key turned over for the car to start. Sometimes it stalls. Car runs fine once it finally cranks. Just recently replaced the valve cover gasket as I thought faulty oil covered plugs I found was the culprit. Replaced the plugs, and the vcg. Also changed the oil with Mobil 1 full synthetic 5w-20.
Maybe a clogged fuel injector? Or fuel filter?
Any other ideas? Also where is the fuel filter?
2005 2.0L ford focus zx4 160,000 miles
Mikehinkle is offline
Old 04-01-2013, 05:17 PM   #2
gondorian
gondorian's Avatar
Fan#: 105695
What I Drive: 2002 wgn (Selling) 2004 2.3 wgn 5sp
Points 1,547, Level 22
Points: 1,547, Level: 22 Points: 1,547, Level: 22 Points: 1,547, Level: 22
Level Up 47% Completed
FF Reputation: 7 gondorian Good Standing Member
The fuel filter is just in front of the fuel tank on the passenger side about a foot or two in front of the rear wheel.
gondorian is offline
Old 04-01-2013, 06:24 PM   #3
Mikehinkle
Fan#: 112131
Would that maybe be my problem?
Old 04-02-2013, 04:14 AM   #4
Mikehinkle
Fan#: 112131
Also I gapped the new plugs to .51. Is that's the right gap?
Old 04-02-2013, 04:46 AM   #5
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,710, Level 94
Points: 23,710, Level: 94 Points: 23,710, Level: 94 Points: 23,710, Level: 94
Level Up 36% Completed
Forum Activity 14%
that gap sounds correct. You should definitely give the fuel filter a try if you have no idea when it's been done. Make sure to try and blow through your old filter (in the right direction of course) to see if i was clogged at all.
mikebontoft is online now
Old 04-02-2013, 10:27 AM   #6
VillageT
Fan#: 97061
What I Drive: 2005 Silver ZX3
Points 325, Level 6
Points: 325, Level: 6 Points: 325, Level: 6 Points: 325, Level: 6
Level Up 50% Completed
FF Reputation: 1 VillageT Good Standing Member
This is a well known problem with the 2005. If you look through the threads there is tons of comments on this issue. I also own a 2005 and have lived with it for 160K miles. Best advice is to turn the key on and wait 5 or 6 seconds before you turn it the rest of the way. If it doesn't start right away don't keep cranking as it doesn't help-just try it again.
It sounds like yours may be a little worse and I would recommend changing the fuel filter ( manual says every 30K) and I would also put in a new fuel pump relay.
There was a computer update (not a recall) from Ford and you have to see your dealer about that one.
VillageT is offline
Old 04-02-2013, 12:51 PM   #7
Mikehinkle
Fan#: 112131
Is the computer update free? Also, I'm gonna do the fuel filter today, will see if letting the key in the on position for a few seconds helps.
Old 04-02-2013, 01:59 PM   #8
VillageT
Fan#: 97061
Points 325, Level 6
Don't forget the relay-they are cheap and easy to install (in box behind battery) and your owners manual will tell which one it is. They are a common problem.
VillageT is offline
Old 04-02-2013, 02:11 PM   #9
Mikehinkle
Fan#: 112131
No owners manual. It's the 05 zx4 2.0L sedan. Thanks for the quick replies. Anyone know if the computer update is free?
Old 04-02-2013, 02:26 PM   #10
VillageT
Fan#: 97061
Points 325, Level 6
The fuel pump relay is R7. The location for R7 is identified on the outside cover of the fuse box (next to the battery).
The cost for the upgrade seems to be up to the individual dealer. Before you go to the dealer look through the Focus Fanatic "stickied threads" and someone has posted the TSB number for the upgrade. Having that will make it much easier to talk to the dealer and make them more inclined to be helpful.
VillageT is offline
