AC oil Spray - Focus Fanatics
Old 04-01-2013, 12:15 PM   #1
FreeFocus
FreeFocus's Avatar
Fan#: 112674
What I Drive: 2002 Red Focus Se
FF Reputation: 1 FreeFocus Good Standing Member
AC oil Spray
I have a 2002 Focus Se and recently I have noticed some oil spray under the hood. It appears to be coming from the AC compressor, not sure though. Do I have a seal going bad or is it something bigger and badder?
I know a lot about cars. I can look at any cars headlight and tell you which way its going
FreeFocus is offline
Old 04-03-2013, 03:03 AM   #2
amc49
Fan#: 96610
FF Reputation: 19 amc49 Great Standing Member
An a/c compressor seal leaking IS big and bad.......................
amc49 is offline
Old 04-03-2013, 05:22 AM   #3
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
What I Drive: 05 ZXW; 02 Windstar; 13 C-Max SEL
FF Reputation: 267 whynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Member
Green oil?
You need a new compressor, and a recharge. If you have to replace the compressor, do not do this without replacing the orifice tube, and IMO you should replace all the O-rings in the system which will take a novice about 2 more hours.
The orifice tube is the filter for the AC system, and it can only be replaced when the system is discharged.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is online now
Old 04-03-2013, 09:42 AM   #4
FreeFocus
FreeFocus's Avatar
Fan#: 112674
I wouldn't call the oil under the hood green. Is there anything else that would spray oil on the hood? It is a real fine spray. The car only has 39000 miles on it and is taken care of extremely well.
Old 04-03-2013, 05:01 PM   #5
whynotthinkwhynot
Captain TMI
Fan#: 18416
It doesn't have to be green, but most of the time dye is added to the oil, and it's usually green. If it is the AC system, then you won't have an AC charge for very much longer, so the AC should stop working.
If the oil is coming from the engine, then you should start to see that oil level dropping, so monitor it if you can't figure out where the oil is coming from.
Be eclectic.
Old 04-03-2013, 05:58 PM   #6
FreeFocus
FreeFocus's Avatar
Fan#: 112674
I check the oil about once or twice a week and it doesn't seem to be dropping. I wiped the hood off today so I will see what happens with it, and see if it leaks when I am driving.
What is an AC charge?
Will keep posted till I figure out what the problem is. Thanks
Old 04-03-2013, 08:54 PM   #7
amc49
Fan#: 96610
It's a/c oil, the only oil that can fine spray like fog when blown out.
amc49 is offline
Old 04-03-2013, 09:01 PM   #8
FreeFocus
FreeFocus's Avatar
Fan#: 112674
I guess that is a problem that I will need to get fixed then. I rarely use it anyway but it could mess something else up. Any ideas on what that would cost?
Old 04-04-2013, 12:08 AM   #9
amc49
Fan#: 96610
The question is impossible to answer as you don't even know where the leak is, that will complicate everything. At this point in time your bill is an hourly rate until some intangibles become known.
amc49 is offline
Old 04-04-2013, 05:07 AM   #10
whynotthinkwhynot
Captain TMI
Fan#: 18416
New compressor
New refrigerant/oil charge
New orifice tube
I'd say about $1k at a shop. If you did it yourself, then it would be about half that. You might be able to get it done cheaper. Make sure that they change the orifice tube though. It's like a filter for the system, and should be changed any time the system is discharged.
Be eclectic.
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Acura TLX. You can find all Ford Focus related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
