fixing broken tabs - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-31-2013, 11:58 PM   #1
calebstubstad
Chef Boyardee
calebstubstad's Avatar
Fan#: 103240
What I Drive: 2000 Atlantic Blue LX
Points 2,716, Level 31
Points: 2,716, Level: 31 Points: 2,716, Level: 31 Points: 2,716, Level: 31
Level Up 78% Completed
FF Reputation: 4 calebstubstad Good Standing Member
fixing broken tabs
been needing to fix the tabs on my headlights for awhile, and after a recent accident (minor fender bender), i was left with only 1 tab holding my driver side headlight in (the one under the headlight). so, I plan to fix both top ones, the way top one into the fender i have the exact piece that snapped, still screwed in, and then the middle one, I am gonna use my old headlights to make a tab. what way to bond the two pieces together do you think would work best? looked at plastic welding, jb weld, superglue and toilet paper layers, etc, all with mixed reviews. anyone done this?
Rally Revolution #43
[HOONIGAN]
Originally Posted by matmatician View Post
Not the bear the zoo deserves, but the bear the zoo needs.
calebstubstad is offline
Old 04-01-2013, 01:31 AM   #2
amc49
Fan#: 96610
Points 3,279, Level 35
Points: 3,279, Level: 35 Points: 3,279, Level: 35 Points: 3,279, Level: 35
Level Up 53% Completed
Forum Activity 13%
I would not glue at all, that type plastic will seem to glue but the joint will have no strength and give pretty quickly.
I'd be looking at screws or pop rivets into plastic with a metal made tab of some sort. Improvise, I've done it and the resulting parts are still going after years of use, it's actually stronger than the original tab. I have a broken up Focus radiator shroud like that and still quite solid when pulling it out after 5 years, it was in a wreck and patched back together from like 5 separate pieces. Or if any tab length left, drill small hole in it and thread some mechanics wire in and around the head of a bolt in proper place. Done clean it doesn't look too obtrusive and again lasts forever. Got two Contour headlights like that for 13+ years now, no way was I paying $180 each for those headlight assemblies.
amc49 is offline
Old 04-01-2013, 07:44 AM   #3
02fordsvt
Meh.
02fordsvt's Avatar
Fan#: 84654
What I Drive: 2002 SVT, 2001 SE (Rusty)
Points 57,573, Level 100
Points: 57,573, Level: 100 Points: 57,573, Level: 100 Points: 57,573, Level: 100
Level Up 0% Completed
Forum Activity 17%
Activity: 17% Activity: 17% Activity: 17%
FF Reputation: 49 02fordsvt Great Standing Member
Buy-Sell-Trade Rating: (11)
Just as an FYI, one of my tabs is broken, one is stripped, and the other one behind the bumper I never use so my PS headlight isn't even hooked in securely right now. However, because of the ballast bellow and the hood above, the headlight cannot move at all when the hood is closed. Some people will probably take issue with how I have it, but it works for me and the headlight doesn't move so it's not blinding any other drivers on the road. You just have to watch your aiming.
Hatch Nation #13 : Rally Revolution #13 : ROTM Jan '13
It's Bryan, not Brian
RSVT-170 Build in Progress
Derusting Rusty Build in Progress
02fordsvt is offline
