Timing tool stuck! - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-14-2013, 11:35 PM   #41
Deus Machina
Fan#: 100167
What I Drive: 2000 black ZX3
FF Reputation: 1 Deus Machina Good Standing Member
Originally Posted by bringler26 View Post
I used the starter to break it free and the concrete floor. It worked very well.
So the motor normally turns clockwise? I'll need to know when setting the belt in, at least.
Deus Machina is offline
Old 04-14-2013, 11:46 PM   #42
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
What I Drive: 03 ZX3 & 07 Impreza 2.5i
Points 9,384, Level 65
Points: 9,384, Level: 65 Points: 9,384, Level: 65 Points: 9,384, Level: 65
Level Up 12% Completed
Forum Activity 6%
TBH I don't remember the details but I'm 99% positive that is how we broke the crank nut free.
2007 Subaru Impreza 2.5i - current DD
I always moderate naked!
bringler26 is offline
Old 04-15-2013, 12:12 AM   #43
Chris_HT
Chris_HT's Avatar
Fan#: 86229
What I Drive: Blue SVT 2002
Points 1,543, Level 22
Points: 1,543, Level: 22 Points: 1,543, Level: 22 Points: 1,543, Level: 22
Level Up 44% Completed
FF Reputation: 4 Chris_HT Good Standing Member
you did that on crank pulley, not on cam pulleys :)
and ye, engine turns clockwise, afaik...
Blue SVT 2002
Our Lady of blessed acceleration
Originally Posted by Black&Tan View Post
But.... why read facts and investigate a claim when it supports your ideology?
...that should be written as 'The First Law of Internet Forums'
Chris_HT is offline
Old 04-24-2013, 01:11 AM   #44
kawasakiklx
Fan#: 113911
What I Drive: 2000 Ford Focus
FF Reputation: 1 kawasakiklx Good Standing Member
I just made this mistake! Literally tonight, I forgot the tool was there and bent it. I assumed I would be able to access it via oil pan, pulled it off to find that I can only access it through a small hole.
Is my only option to remove the upper pan? I really hope there is an easier way. I have the tools/knowledge to do it, but would not like the labor. I hate messing with the exhaust. OP, how did you remove the hot air fitting connected to the cat?
I'll try to snap some pics tomorrow, I'm done for the night. Simple timing belt turns into a s@!t-show. :(
kawasakiklx is offline
Old 04-24-2013, 11:04 AM   #45
Deus Machina
Fan#: 100167
I haven't, yet. >.<
Between school (finals!), work, and my limited available time because I'm in an apartment and can't work on it at night, it's still sitting.
Even my narrow hacksaw can't get a blade at it.
I did fabricate a tool to with a hook on the end, and am hoping it works. I'll be trying to test it tonight or Friday, and will put up pictures if it does.
Old 04-24-2013, 09:46 PM   #46
kawasakiklx
Fan#: 113911
a long jigsaw would be perfect, maybe I'll have to create something of my own! lol
I was really upset about it last night...today, I've come to terms with it. I'll get it fixed.
Old 04-24-2013, 09:50 PM   #47
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
Forum Activity 6%
He was trying to do the crank pulley
Old 04-25-2013, 02:59 PM   #48
kawasakiklx
Fan#: 113911
Originally Posted by Deus Machina View Post
I haven't, yet. >.<
What are you hoping to do with a hook? Bend it back? I would think you risk screwing up the threads if you did this. That is a lot of horizontal pressure.
Here is my refined idea: buy a long skinny hacksaw blade (pictured). Weld/attach onto it a round, or thin flat, piece of steel. Bend it, if needed, to fit into view hole. Go to town on it! Have you tried something like this?
Old 04-26-2013, 01:07 AM   #49
kawasakiklx
Fan#: 113911
Use these actions wisely!!!!
Update: So I managed to get the tool out. Here's how:
The tool was bent at about a 45. Probably the same as many since that is the angle the crankshaft forced upon it. I noticed that if I backed the crank onto it, it would hit it at the opposite side, reverse to the bend.
I used a socket on the crank to give the tool a couple sharp smacks and it bent back and cracked at the vertex. I bent it a little more and the long piece fell through the bottom. The crank bolt loosened up a time or two but I just gave it a little impact love and it seemed to give me a couple extra swings.
I put the original bolt back in and it threaded in nicely, even when torqued.
I will say, this method may not be recommended since it means reversing the rotation of the crank, but it was better than other options. The system is all timed up now and running as it should. I only ended up having to remove the oil pan.
Hope this helps someone, maybe even the OP!
Old 04-27-2013, 11:58 AM   #50
150mphzetec
Fan#: 77175
What I Drive: 00 yellow zetec
Points 389, Level 7
Points: 389, Level: 7 Points: 389, Level: 7 Points: 389, Level: 7
Level Up 78% Completed
FF Reputation: 2 150mphzetec Good Standing Member
congress should ban these crank locking tools
150mphzetec is offline
