Sluggish when cold. - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-02-2013, 03:00 PM   #11
Bowesmobile
Fan#: 111678
What I Drive: 2000, Cloud 9 ZTS
Points 139, Level 2
Points: 139, Level: 2 Points: 139, Level: 2 Points: 139, Level: 2
Level Up 78% Completed
FF Reputation: 1 Bowesmobile Good Standing Member
Originally Posted by SVTisRight4me View Post
cars are sluggish when the engine is cold. u should not rev it or have the RPMs go high before it gets warmed up. its bad for the engine. when cold, the oil is thicker and its hard to run through the engine.
Okay, thank you.
Bowesmobile is offline
Old 04-02-2013, 03:39 PM   #12
Bowesmobile
Fan#: 111678
Points 139, Level 2
So it was eating me up and I went back and checked. The IPS is hooked up. On the diagram I pulled from Fordparts.com they show only four vacuum ports. But my intake has five. The red dot is the location of the fifth. What does this go to? It had a hose connection of some type.
Old 04-02-2013, 07:50 PM   #13
Joboo
Fan#: 99593
What I Drive: 2003 Focus SE
FF Reputation: 1 Joboo Good Standing Member
EGR valve actuator? Just guessing based on the intake diagram I have...
Joboo is offline
Old 04-02-2013, 08:04 PM   #14
Bowesmobile
Fan#: 111678
Points 139, Level 2
Actually the PO or someone he had work on the car connected the PCV to a plastic post on the intake and not a vacuum port. SOOOOO we'll see how it runs in the morning when its cold.
Old 04-03-2013, 12:55 PM   #15
Bowesmobile
Fan#: 111678
Points 139, Level 2
It ran better this morning. My drive in was smoother. So tonight, hopefully, I'll clean out the CAT and reset the computer. Then see where I'm at.
Old 04-11-2013, 01:42 PM   #16
Bowesmobile
Fan#: 111678
Points 139, Level 2
So to wrap this thread up. When the coil pack went, it jumped time. So my timing is off causing low vacuum and poor running issues. I have the belt on order and next weekend I will be changing it.
Old 04-20-2013, 06:39 PM   #17
Bowesmobile
Fan#: 111678
Points 139, Level 2
Here's my final post for this thread. Replaced the timing belt. The original was missing 16 teeth. Someone broke some thing off in the TDC pin hole. So I watched the valves and knew that after the intake on number one actuated TDC was when the keyway on the crankshaft was vertical. I buttoned everything back up. Started it and let it run for 10 minutes. Then checked the timing with my Torque app. amd it was running between 10-13 BTDC. Which is perfect! Took it for a drive and man what a difference! Not bad for 5 hours work.
