00 ZX3 Kona Edition love it but need help it dies at idol and i have done many things - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-31-2013, 06:16 PM   #1
lcerny34zx3
Fan#: 112661
What I Drive: 2000 Green ZX3 Kona Edition
FF Reputation: 1 lcerny34zx3 Good Standing Member
Changed IAC ,Plugs, wires, changed pcv with tube what the hell is going on.. It seems to help but i am so frustrated cause there are no trouble codes
lcerny34zx3 is offline
Old 03-31-2013, 10:18 PM   #2
Blackheart43551
Fan#: 94366
What I Drive: 2010 Blue Focus SE Coupe
FF Reputation: 1 Blackheart43551 Good Standing Member
Did you put a CAI on it recently?
Blackheart43551 is offline
Old 03-31-2013, 11:28 PM   #3
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,030, Level 74
Points: 13,030, Level: 74 Points: 13,030, Level: 74 Points: 13,030, Level: 74
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
Forum Activity 34%
Activity: 34% Activity: 34% Activity: 34%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (45)
You might want to inspect your charging system. That means the battery, alternator and anything else involved in that line. It might be your alternator that is falling off on you. Just take it to any auto parts store and they can test your battery and alternator right on the spot with everything still in the car. If it's not that, when was the last time you had your fuel filter changed? Seeing as how you had all the other parts replaced or checked those are the only things I can think of at the moment. I am sure others will chime in to help out and lend their experience as well.
zetecDon is offline
Old 03-31-2013, 11:32 PM   #4
calebstubstad
Chef Boyardee
calebstubstad's Avatar
Fan#: 103240
What I Drive: 2000 Atlantic Blue LX
Points 2,716, Level 31
Points: 2,716, Level: 31 Points: 2,716, Level: 31 Points: 2,716, Level: 31
Level Up 78% Completed
FF Reputation: 4 calebstubstad Good Standing Member
i'd say fuel filter. not alot of places even bother to check it.
Rally Revolution #43
[HOONIGAN]
Originally Posted by matmatician View Post
Not the bear the zoo deserves, but the bear the zoo needs.
calebstubstad is offline
Old 03-31-2013, 11:54 PM   #5
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,832, Level 73
Points: 12,832, Level: 73 Points: 12,832, Level: 73 Points: 12,832, Level: 73
Level Up 96% Completed
Forum Activity 99%
Vacuum leaks, anything in the serpentine belt system & it's driven accessories that's not spinning as freely as it should....
heck, if you told us the brakes don't feel right as well, the brake booster could have failed & caused the vacuum leak.....
Long list of possibilities...
if you give out more symptoms, like just when it dies - whether it runs rough or not - etc.. Then someone might be able to guess closer...
sailor is online now
Old 04-01-2013, 06:06 AM   #6
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,776, Level 98
Points: 27,776, Level: 98 Points: 27,776, Level: 98 Points: 27,776, Level: 98
Level Up 43% Completed
Forum Activity 4%
AT or MT? Need more information. If it is the AT, you might have the TB problem, and need a new TB which also replaces the TPS. The TPS for the MT is available, but the TPS for the AT can only be purchased with the TB.
Have you ever changed the fuel filter?
In order to check your voltage while the vehicle is running, use the electronic odometer trick: key off, press and hold the trip odo reset button, turn key on, continue to hold button until odometer reads [test]. Release button, now each time you press and release the button you'll scroll through one of 30 test functions. You will remain in test mode until you turn the key off. Find the function that looks like this [bat 12.1]. The actual voltage there is typical, and yours could be different. Now, turn the key to start the car without turning the key to off. You can now monitor your voltage while driving. Voltages over 15v or under 13v are not good and the alternator or connections should be inspected or rebuilt as needed.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 04-01-2013, 01:16 PM   #7
lcerny34zx3
Fan#: 112661
My 2000 zx3 Kona Edition
I am going to check charging system than if that isnt the problem i will check the fuel filter i believe its original. Other than that i believe it could be the MAF sensor or something to do with EGR valve being stuck open
Old 04-01-2013, 01:17 PM   #8
lcerny34zx3
Fan#: 112661
Thanks everyone for your helpful hints. Owe by the way its a automatic Zetec motor
Old 04-01-2013, 02:30 PM   #9
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,919, Level 100
Points: 51,919, Level: 100 Points: 51,919, Level: 100 Points: 51,919, Level: 100
Level Up 0% Completed
Forum Activity 32%
Activity: 32% Activity: 32% Activity: 32%
Buy-Sell-Trade Rating: (28)
Do you have any mods added ?
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 04-01-2013, 04:07 PM   #10
miazda
miazda's Avatar
Fan#: 103761
What I Drive: 03 SVT
FF Reputation: 1 miazda Good Standing Member
http://www.reddit.com/r/Justrolledin...g_on_mass_air/
^probably totally unrelated and a long shot. I think that's on an escape. However,might be worth a look to see if the MAF is dirty. My 03 svt stalls, and I've yet to find the cause as well. Will definitely be looking into this myself.
miazda is offline
