New (used) Instrument Cluster Question(s) - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-30-2013, 10:36 PM   #1
PLRX
PLRX's Avatar
Fan#: 16768
What I Drive: 2003 - ZX5 - 5 Spd - 2.3 Duratec
Points 1,402, Level 21
Points: 1,402, Level: 21 Points: 1,402, Level: 21 Points: 1,402, Level: 21
Level Up 2% Completed
FF Reputation: 1 PLRX Good Standing Member
Finally after almost two years I fixed the damn engine light. There were no codes, but it would stay on (50%) at all times. Even with the car off, and key off the ignition.
http://www.focusfanatics.com/forum/showthread.php?t=263995
I bought an used cluster, it is working fine. It is the same part number so no programming was needed.
This cluster has 118,000 less miles than the Focus' original cluster. I'm not planning on selling the car, and likely it has no street value with 224,000 miles.
I live in California, and I have to SMOG this year. The mileage is recorded, and it will be easily noticeable.
Will this be an issue with DMV?
Can the new odometer be programmed to display the old mileage?
2003 ZX5 HID Lights, Interior Carbon Fiber, Poly Bushings, SVT Suspension, Upper Strut Bar, Euro SVT Wheels,
SVT Brakes, Steel Braided Brake Lines, Drilled Rotors, K&N FIPK Generation 2 and Magnaflow Cat-Back
PLRX is offline
Old 03-30-2013, 10:52 PM   #2
gondorian
gondorian's Avatar
Fan#: 105695
What I Drive: 2002 wgn (Selling) 2004 2.3 wgn 5sp
Points 1,547, Level 22
Points: 1,547, Level: 22 Points: 1,547, Level: 22 Points: 1,547, Level: 22
Level Up 47% Completed
FF Reputation: 7 gondorian Good Standing Member
Some ford dealers will program it for you and others will not. Sometimes they want you to buy a cluster from them in order to program it. If the no code is being thrown and it is just the light on the dash you could try removing the light bulb for the CEL when you go through smog and use your old cluster.
gondorian is offline
Old 03-30-2013, 10:57 PM   #3
PLRX
PLRX's Avatar
Fan#: 16768
The "new" one is installed. Those bulbs are LED, hey can not be removed. I feel better now, that thing drove me nuts.
PLRX is offline
Old 03-30-2013, 11:01 PM   #4
Alptbird
Alptbird's Avatar
Fan#: 109943
What I Drive: 2008 focus sedan
FF Reputation: 1 Alptbird Good Standing Member
Not sure in California but in Texas, yes it will be an issue a big one. Like gondorian said the dealer will program it with the proper mileage but they will want the old one in the car for proper milage so they can install the new gauge and program it with the proper mileage.
Alptbird is offline
Old 03-31-2013, 08:26 PM   #5
PLRX
PLRX's Avatar
Fan#: 16768
I'm going to gamble on this. If DMV calls me, I've documented the old and new mileage. I don't intent to sell this car. It has more value to me than any book or lemon lot. It has 224K miles, turns 10 years in two weeks, and I'm the original on only owner.
I went to a dealer to see a new ST. The car has 250 HP, great looking, but the interiors are uncomfortable. I think those RECARO seats are for 125 pounders.
I can buy a rem engine for $2,000, and perhaps it would last 10 more years. LOL
PLRX is offline
Old 03-31-2013, 10:36 PM   #6
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
Google 'instrument cluster repair' or 'airbag module repair'. You will find individuals that repair/reprogram/and set odometer mileage for replacement clusters.
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
Old 03-31-2013, 11:13 PM   #7
PLRX
PLRX's Avatar
Fan#: 16768
I may do that. Thanks
PLRX is offline
Old 04-01-2013, 01:26 AM   #8
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,329, Level 75
Points: 13,329, Level: 75 Points: 13,329, Level: 75 Points: 13,329, Level: 75
Level Up 20% Completed
Forum Activity 99%
In the mechanical speedo days, a replacement speedo came with a sticker to note the mileage from the one that was removed to be added to the new speedo's in order to determine total mileage.....
"Revealing" the actual mileage in such a manner should cover your butt. Just record the difference as if that was the mileage when the "new" one was installed and it'll be easy to figure the current actual miles....
sailor is online now
Old 04-02-2013, 12:31 PM   #9
PLRX
PLRX's Avatar
Fan#: 16768
Thats what I did
PLRX is offline
Old 04-02-2013, 02:05 PM   #10
KCaudill
Fan#: 46826
What I Drive: 2006 Tredour Red ZX3 SE
Points 334, Level 6
Points: 334, Level: 6 Points: 334, Level: 6 Points: 334, Level: 6
Level Up 68% Completed
FF Reputation: 1 KCaudill Good Standing Member
You may want to get the milage more closer than 118k in difference. If you have a minor fender bender, it could be the difference of total and not total. Here in Ohio there is lots of red tape concerning odometer tampering. I switched out my cluster with on that had a tach, found a place online talked to them and only cost my $200 with next day shipping cluster to them, resetting milage, and next day shipping back. It was well worth it.
KCaudill is offline
