For all my guru peeps... I haz issues... - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-31-2013, 12:52 AM   #11
Mother Focus
Mother Focus's Avatar
Fan#: 73292
What I Drive: 2001 Money Pit
Points 4,667, Level 43
Points: 4,667, Level: 43 Points: 4,667, Level: 43 Points: 4,667, Level: 43
Level Up 59% Completed
FF Reputation: 13 Mother Focus Great Standing Member
Buy-Sell-Trade Rating: (9)
While cold it maintains higher rpm's until it gets hot, when hot IAC can still adjust but is not enough vacuum to maintain it running. IAC if it gets stucked, gets way higher rpm than that...vac leak, vac leak, vac leak...are the brakes or the clutch acting weird sometimes?
PTE 6262CEA
Pump Gas 385whp 319wtq
Race Gas 551whp 439wtq
Tuned by Fernando@RacingPartsSolution.com
Mother Focus is offline
Old 03-31-2013, 12:53 AM   #12
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2007 mazda 3 I sport, TURBO ZX3
Points 50,882, Level 100
Points: 50,882, Level: 100 Points: 50,882, Level: 100 Points: 50,882, Level: 100
Level Up 0% Completed
Forum Activity 4%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
its the little filter that sits outside of the tank of the fuel pump canister. getting fuel cut off is a good sign. it almost sunds like that's what you are getting. all thou only time ive gotten fuel cut off was when I tried 18psi on stock pump, and during boost it will JOLT real hard
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 03-31-2013, 12:56 AM   #13
LouBomb
It was all a DREAM!
LouBomb's Avatar
Fan#: 32545
What I Drive: A magical pony by the name of Sally
Points 11,179, Level 69
Points: 11,179, Level: 69 Points: 11,179, Level: 69 Points: 11,179, Level: 69
Level Up 83% Completed
Level up: 83% Level up: 83% Level up: 83%
Forum Activity 3%
FF Reputation: 9 LouBomb Good Standing Member
Weird you say that..
Brakes aren't working.. I have to slam the pedal in order for some stopping.. I was told it could be the master cylinder.. I was planning to address that when I get it running..
Sent from my JailBroken iPhone.
2000 Turbo Zx3
2003 Pitch Black SVT
2000 SPI 220k miles all original THE UNICORN
Focus Revolution Club
Formely IMPORTKILLA35
LouBomb is offline
Old 03-31-2013, 12:57 AM   #14
LouBomb
It was all a DREAM!
LouBomb's Avatar
Fan#: 32545
Forum Activity 3%
So fuel cut off would make the car act like that at warm temp? And not cold?
2000 Turbo Zx3
LouBomb is offline
Old 03-31-2013, 06:58 AM   #15
Mother Focus
Fan#: 73292
Is due to the vac leak, nothing wrong with the brakes they are designed to work with a vac pressure you are not getting to, again is a leak and pretty big too.
Edit: if you overwork the booster by pumping the brakes, you'll have idle and brakes for a very short time.
PTE 6262CEA
Old 03-31-2013, 01:03 PM   #16
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 4%
bottom of the intake manifold is the brake booster. trace it when the car is cold and do what italo has told me to do, spray brake cleaner on the line and see if the rpm changed
FF MODERATOR
RIFF CREW
Old 03-31-2013, 01:13 PM   #17
Mother Focus
Fan#: 73292
He needs to check everywhere, weird acting brakes is a symptom of a bigger leak not that there is something bad, can always start the engine and inspect the booster hose to see if it is collapsing, but leak can be anywhere.
PTE 6262CEA
Old 04-01-2013, 12:06 PM   #18
LouBomb
It was all a DREAM!
LouBomb's Avatar
Fan#: 32545
Forum Activity 3%
I was looking for leaks and I couldn't find any... :(( My question still remains tho.. Would the brakes really have to do much with my car bogging down and dying only at warm temp? Wouldn't it affect it all the time, at all temps?
2000 Turbo Zx3
LouBomb is offline
Old 04-01-2013, 12:17 PM   #19
Mother Focus
Fan#: 73292
Like I said before, brakes acting weird is a symptom of a leak, your engine produces a vacuum brakes and clutch need to work, when you have a leak the needed vacuum would not be there and brakes or clutch can act funny.
You won't see a leak, need to test for it, I explain to Sean what I do and he found a write up I like.
http://www.focusfanatics.com/forum/r...er-5-02-a.html
PTE 6262CEA
Old 04-09-2013, 04:21 PM   #20
LouBomb
It was all a DREAM!
LouBomb's Avatar
Fan#: 32545
Forum Activity 3%
I have a quick question, I have the diablo chip can I use a diablo tuner to datalog?
2000 Turbo Zx3
LouBomb is offline
