Ideas please, fuel filter bracket bolt stuck and stripped - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-30-2013, 07:49 PM   #11
jetrinka
jetrinka's Avatar
Fan#: 45622
What I Drive: 88 5-speed XR4TI
FF Reputation: 180 jetrinka Excellent Standing Member jetrinka Excellent Standing Member
Buy-Sell-Trade Rating: (6)
I also suggest hammering a socket onto it before trying anything too drastic.
jetrinka is offline
Old 03-30-2013, 09:57 PM   #12
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
The head doesn't really look that bad - at least in the photo. But then the bracket, is it rusted to the filter too?
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
Old 03-31-2013, 12:08 AM   #13
gondorian
gondorian's Avatar
Fan#: 105695
What I Drive: 2002 wgn (Selling) 2004 2.3 wgn 5sp
Points 1,500, Level 21
Points: 1,500, Level: 21 Points: 1,500, Level: 21 Points: 1,500, Level: 21
Level Up 50% Completed
FF Reputation: 7 gondorian Good Standing Member
I tried hammering on a 9/32 and a 7mm and they wouldn't go on. I can't really get any extractors in the bolt because it is too tucked away, and I don't feel like buying long drill bits that I might break. Also can't get any purchase on the clamp with bolt cutters :-(
So I started cutting the bracket with a hacksaw blade to it is too slow. My plan now is to put a little cut off wheel on a dremel at work and slowly cut through the bracket. Then once the filter is out of the way I'll be able to work on the bolt more easily. Or maybe I'll just leave it and hold the new filter with zip ties...
Whoever said changing the fuel filter is easier than changing the oil must have lived in Mexico or something
gondorian is offline
Old 03-31-2013, 09:53 AM   #14
macdiesel
I used to drive this
macdiesel's Avatar
Fan#: 31579
What I Drive: 2010 mazdaspeed3
Points 4,174, Level 41
Points: 4,174, Level: 41 Points: 4,174, Level: 41 Points: 4,174, Level: 41
Level Up 12% Completed
FF Reputation: 22 macdiesel Great Standing Member
Buy-Sell-Trade Rating: (17)
Your filter was probably never ever changed before
I now drive a Japanese Ford.
macdiesel is offline
Old 03-31-2013, 12:50 PM   #15
gondorian
gondorian's Avatar
Fan#: 105695
I don't think one fuel filter could last 200k odd miles and eleven years. But it sure looks like it was never changed before.
Old 03-31-2013, 08:35 PM   #16
Oblivion
Fan#: 92148
What I Drive: 2001 Blue ZX3
FF Reputation: 3 Oblivion Good Standing Member
I bet the fuel inside is stronger, blacker, and leaner than my morning coffee! LOL!
Oblivion is offline
Old 04-01-2013, 10:35 AM   #17
gondorian
gondorian's Avatar
Fan#: 105695
So this morning I disconnected the pump fuse, ran the engine until it was really sputtering, and then CARFULLY cut the fuel filter bracket with a cutting wheel on a dremel.
Ta dah
Then I just took out the filter, cut down the bracket with tin snips, put on the new filter and attached it to the stub of the bracket with wire. Would have been too easy if it weren't for the stupid rust everywhere.
Old 04-01-2013, 11:02 AM   #18
gondorian
gondorian's Avatar
Fan#: 105695
I took it for a quick spin, and changing the fuel filter eliminated the problem I was having with poor fuel delivery, which was causing chugging at low throttle input and low rpm combinations.
Unless your coffee is about as black as straight grounds, then yes, it was.
And that stupid bolt is still there, stuck and stripped. For all I care it will stay there until it gets melted away for scrap along with the body.
Old 04-01-2013, 02:28 PM   #19
Milton
Fan#: 89715
What I Drive: 2007 Black Focus SES 2.0 L4 4 Door
Points 326, Level 6
Points: 326, Level: 6 Points: 326, Level: 6 Points: 326, Level: 6
Level Up 52% Completed
Forum Activity 6%
FF Reputation: 8 Milton Good Standing Member
EXCELLENT!!!!!! Good job. You'll need to check it every oil change to see if its working loose.
Milton is offline
Old 04-01-2013, 04:13 PM   #20
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,826, Level 73
Points: 12,826, Level: 73 Points: 12,826, Level: 73 Points: 12,826, Level: 73
Level Up 94% Completed
Forum Activity 99%
Good choice of wire! That looks like solid copper insulated, which will hold it's tie...
Stranded tends to work loose even when tied in a knot!
sailor is online now
