Ideas please, fuel filter bracket bolt stuck and stripped - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-30-2013, 10:05 AM   #1
gondorian
gondorian's Avatar
Fan#: 105695
What I Drive: 2002 wgn (Selling) 2004 2.3 wgn 5sp
Points 1,500, Level 21
Points: 1,500, Level: 21 Points: 1,500, Level: 21 Points: 1,500, Level: 21
Level Up 50% Completed
FF Reputation: 7 gondorian Good Standing Member
Edit: Problem is now fixed
So I was trying to change my fuel filter today and got everything all depressurized and took of one of the lines from the fuel filter. I saw that the bolt was all rusty so I sprayed it with lube and waited for a bit. I tried using an 8mm socket but I could feel it was loose so I used a 5/16 (slightly smaller). Then I totally stripped it. I need to get the bracket off so I can change the filter, and my first thought was just to grind it off. However, grinding makes sparks and I'm not sure that would be a prudent course of action.
Here is what it looks like:
gondorian is offline
Old 03-30-2013, 11:21 AM   #2
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
I believe that bolt is 7mm.
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
Old 03-30-2013, 12:54 PM   #3
TommyTooHi
TommyTooHi's Avatar
Fan#: 90859
What I Drive: 2004 Red Focus SVT
FF Reputation: 1 TommyTooHi Good Standing Member
ick... and it's recessed, so not easy to get to!
Damn midwest salted roads, too!
As long as there's no fuel leaking, and if you haven't popped the clamps off/removed the filter, there will LIKELY be no concern, as there is no fuel to ignite.
Maybe a few whacks with a center punch to the middle of the bolt head to create a divot, then drill into it (long bit required, obviously) then an easy-out in a socket/extension and very carefully twist it out.
Or, increase the size of the drill bits gradually until the bold head spins off, then pop the bracket off the nub.
Or (I've never bought one) a stepped drill bit - it has a gradually increasing diameter, which MIGHT just cure it, once you can get it to 'bite' into the bolt head. And, if it FITS next to the filter/hose bits.
May require a trip to the tool store, but anything you buy will be handy to have for the NEXT fiasco!
Good luck!
-T_T
Aw, heck - you mean what I know...
Mods: Caffeinated nut behind the steering wheel
TommyTooHi is offline
Old 03-30-2013, 01:50 PM   #4
Oblivion
Fan#: 92148
What I Drive: 2001 Blue ZX3
FF Reputation: 3 Oblivion Good Standing Member
It is actually a 5/16 (~8mm).
That would make me extremely nervous. If a single spark ignites any fuel (hope there aren't any vapors in the air): He will not only kill himself, but make a mess for anyone who finds what's left.
The first thing that comes to my mind is: Can you use an EZ out to drill out the existing screw?
If not: Could you possibly sacrifice the entire metal clamp, and simply cut it with something (pair of bolt cutters perhaps)?
Those are my only ideas. The actual screw isn't very deep. It's just enough to keep the filter from bouncing around too much.
Maybe after you install it back, or replace it: You should make a custom-made plate to keep the road's salt from hitting it and rusting it again.
Oblivion is offline
Old 03-30-2013, 03:09 PM   #5
a_2000_se
a_2000_se's Avatar
Fan#: 62964
Forum Activity 5%
I guessed I never messed with that bolt but instead loosened the fuel hose clamp on the filter end going to the tank then loosened the 7mm bolt on the filter bracket that holds the filter, slid the filter out of the bracket to replace the filter.
60k+ miles.
Old 03-30-2013, 03:17 PM   #6
macdiesel
I used to drive this
macdiesel's Avatar
Fan#: 31579
What I Drive: 2010 mazdaspeed3
Points 4,174, Level 41
Points: 4,174, Level: 41 Points: 4,174, Level: 41 Points: 4,174, Level: 41
Level Up 12% Completed
FF Reputation: 22 macdiesel Great Standing Member
Buy-Sell-Trade Rating: (17)
Yeah if you could loosen the filter enough to slide out. Shouldnt have to mess with bolt
I now drive a Japanese Ford.
macdiesel is offline
Old 03-30-2013, 03:25 PM   #7
a_2000_se
a_2000_se's Avatar
Fan#: 62964
Forum Activity 5%
Or - if the 7mm is rusted too, use a short piece of a hack saw blade to split the filter bracket - VERY CAREFULLY. Then zip tie the bracket after replacing the filter.
60k+ miles.
Old 03-30-2013, 03:41 PM   #8
Milton
Fan#: 89715
What I Drive: 2007 Black Focus SES 2.0 L4 4 Door
Points 326, Level 6
Points: 326, Level: 6 Points: 326, Level: 6 Points: 326, Level: 6
Level Up 52% Completed
Forum Activity 6%
FF Reputation: 8 Milton Good Standing Member
If you drill it out use reverse drills.
Where you using six point sockets? That's all I use unless forced otherwise.
Milton is offline
Old 03-30-2013, 05:21 PM   #9
macdiesel
macdiesel's Avatar
Fan#: 31579
Maybe hammer on a smaller socket?
Old 03-30-2013, 05:52 PM   #10
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,863, Level 74
Points: 12,863, Level: 74 Points: 12,863, Level: 74 Points: 12,863, Level: 74
Level Up 4% Completed
Forum Activity 99%
Yeah, hammer on a smaller six point B4 trying anything else, you MIGHT get Lucky!
sailor is online now
