Installed Sportlines car, not sitting level!!!! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-30-2013, 01:16 AM   #1
RallyWerks
RallyWerks's Avatar
Fan#: 54867
What I Drive: 2003 2.3 Twilight Blue ZX3
Points 2,800, Level 32
Points: 2,800, Level: 32 Points: 2,800, Level: 32 Points: 2,800, Level: 32
Level Up 34% Completed
FF Reputation: 1 RallyWerks Good Standing Member
Buy-Sell-Trade Rating: (4)
So I installed a set of used Eibach Sportlines on my SVT. All was just fine until I noticed that the passenger rear sits about a half inch or more higher that the opposing side. The fronts seem fine and look the same.
I checked to make sure I installed them right side up.
I took the spring out tonight and then reinstalled it, making sure I did everything perfect.
It still sits the same, noticeably higher than the other side.
The only thing I can think of now is to take take the other spring out and swap sides to see if its a spring issue.
Also, I DID reuse the factory rubber piece that goes on the top of the spring.
So if this has happened to anyone else or if anyone has any suggestions as to how I can make adjustments, your help would be greatly appreciated.
Thanks guys,
Chris
It's stock, don't worry about it.
SoCal Crew#13
RallyWerks is offline
Old 03-30-2013, 01:29 AM   #2
sam fisher
I hate dents!
sam fisher's Avatar
Fan#: 103137
What I Drive: 2006 silver zx4 ses
Points 4,176, Level 41
Points: 4,176, Level: 41 Points: 4,176, Level: 41 Points: 4,176, Level: 41
Level Up 13% Completed
FF Reputation: 3 sam fisher Good Standing Member
Thats funky , got a pic?
Sent from my LG-LG730
sam fisher is offline
Old 03-30-2013, 01:52 AM   #3
Blue5ive
R.I.P Kona
Blue5ive's Avatar
Fan#: 83941
What I Drive: 2003 TW Blue ZX5
Points 7,602, Level 58
Points: 7,602, Level: 58 Points: 7,602, Level: 58 Points: 7,602, Level: 58
Level Up 26% Completed
Forum Activity 29%
Activity: 29% Activity: 29% Activity: 29%
FF Reputation: 10 Blue5ive Great Standing Member
Buy-Sell-Trade Rating: (8)
That is weird. Were both of the rear springs the same height b4 you installed them?
Team Focalize
Hatch Nation #9
"2 by 2 Hands of Blue."
Blue5ive is online now
Old 03-30-2013, 01:55 AM   #4
RallyWerks
RallyWerks's Avatar
Fan#: 54867
Yes they were! Totally weird. I'll snap pic tomorrow (dark outside now). It's driving me nuts!
SoCal Crew#13
Old 03-30-2013, 08:06 PM   #5
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,164, Level 74
Points: 13,164, Level: 74 Points: 13,164, Level: 74 Points: 13,164, Level: 74
Level Up 79% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (46)
Moved to "Wheels, Tires, Brakes & Suspension".
zetecDon is offline
Old 03-30-2013, 09:44 PM   #6
RallyWerks
RallyWerks's Avatar
Fan#: 54867
Thank you!
SoCal Crew#13
Old 03-31-2013, 08:22 PM   #7
Tyler T
Tyler T's Avatar
Fan#: 42066
What I Drive: two '02 SVT's
Points 974, Level 16
Points: 974, Level: 16 Points: 974, Level: 16 Points: 974, Level: 16
Level Up 74% Completed
FF Reputation: 2 Tyler T Good Standing Member
Did you remove both rear springs and compare them? Since they're used there could be an irregularity with one of them. But it is unlikely.
Since you used the rubber isolator on the upper spring perch I'd recommend double checking that the top of the spring is seated properly in the isolator. I'm sure you noticed that there is a notch for the end of the coil to fit into.
Also, roughly what is the overall spring length? Some sport springs are short enough that at full droop they can fall out of place and then when the car settles back on its wheels the spring will be out of place. Something along these lines could be your problem.
tyturnbull.com
understeering? visit FealSuspension.com
for quality repairs and modifications in the LA area: StevesAutoClinic.com
Tyler T is offline
Old 04-01-2013, 02:29 PM   #8
Buickboy
br/o/stang
Buickboy's Avatar
Fan#: 28542
What I Drive: 72 Skylark, '12 Mustang
Points 28,322, Level 98
Points: 28,322, Level: 98 Points: 28,322, Level: 98 Points: 28,322, Level: 98
Level Up 98% Completed
FF Reputation: 39 Buickboy Great Standing Member
Buy-Sell-Trade Rating: (29)
mine were always a little higher on that corner too.
==2012 Kona Blue Mustang V6==
==1995 Light Iris Neon Coupe==
==1972 Skylark==
Buickboy is offline
Old 04-01-2013, 04:59 PM   #9
1hotfocus
1hotfocus's Avatar
Fan#: 82813
What I Drive: 00' sedan
FF Reputation: 7 1hotfocus Good Standing Member
Buy-Sell-Trade Rating: (21)
dammit, happened to me too when i installed DOMS lower control arms in the rear, with the sportlines i already had installed. the passenger rear is about .5" higher. bothers me to hell too!
Give rep if youve been helped :)
1hotfocus is offline
Old 04-01-2013, 05:01 PM   #10
jinstall
Deutsche Arsche
jinstall's Avatar
Fan#: 9730
What I Drive: 01 ZX3RACECAR/04 ST170/13 FST2
Points 2,829, Level 32
Points: 2,829, Level: 32 Points: 2,829, Level: 32 Points: 2,829, Level: 32
Level Up 53% Completed
Forum Activity 9%
FF Reputation: 4 jinstall Good Standing Member
And the spring is sitting properly in its detent position?
2001 Focus ZX3-Ours FREED & DELIVERY ON FRIDAY!
2010 Renault Clio 1.2 16V in Germany-Hers FOR SALE
2004 SVTF EAP/ST170-Mine
2013 Focus ST2 TS NAV SUNROOF-Hers
jinstall is online now
