P1131, '04 SVT, making Tommy Sad - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-29-2013, 01:52 PM   #1
TommyTooHi
TommyTooHi's Avatar
Fan#: 90859
What I Drive: 2004 Red Focus SVT
FF Reputation: 1 TommyTooHi Good Standing Member
4/2: Edit -
Fixed it.
I should have paid more attention to the first code thrown - Cylinder #2 misfire.
Yup, the mani hose clamp right at the cylinder head came loose, sucking air. Couldn't see it.
A local Ford dealer (Sound, in Renton) had a "Talk To A Tech" email system set up - Brandt checked the VIN, and sent me a service bulletin on how to isolate vacuum leaks. That required a datalogger, but I read into it and started clamping/capping off vac lines, etc, which is when I saw the loose clamp.
Farkle me, glad that's over. Thanks for the board members input, too!
-T_T
Need assistance from the guru's in here~~
Dang it!
'04 SVT won't idle for squat, plugs are DRY, Tommy is disappointed.
Saw a brief P0171 the other day (cleared that, ran fine), then when the stumble started, saw a #2 cylinder misfire code (cleared that), but the full monty appears now as
P1131.
Car ran fine, I parked it for two days, but when I started it up yesterday it stumbled at idle. I have to keep revs up @ stops, but it actually sorta runs OK once rolling; lots of popping on decel, though.
At work yesterday, I found the vacuum hose elbow at the sensor on the passenger side (at the end of the fuel rail) hanging loose - plugged it back in, no change. I blame the guy that R+R'd the alternator for knocking that loose.
Last night I popped the wee vacuum tubes off, (behind the intake mani) and found no issues.
PCV hose appears OK
I replaced the dang fuel filter last night (+ changed oil while I was under there).
Stock air filter box is dry.
There is a newish (20k ago) Bosch front O2 sensor that I replaced at 100k for 'good luck'.
As well, I replaced the PCV valve at that time.
It sure FEELS like a fuel starvation or a classic vacuum leak, but I can't ID any leak(s). Fuel filter contents showed it wasn't a wasted effort.
Any verifiable info would be appreciated, thanks!
-T_T
Aw, heck - you mean what I know...
Mods: Caffeinated nut behind the steering wheel
TommyTooHi is offline
Old 03-29-2013, 06:49 PM   #2
HilloNative
HilloNative's Avatar
Fan#: 43548
What I Drive: '04 EAP Sonic Blue SVT, '04 Ranger
Points 2,404, Level 29
Points: 2,404, Level: 29 Points: 2,404, Level: 29 Points: 2,404, Level: 29
Level Up 70% Completed
FF Reputation: 4 HilloNative Good Standing Member
Buy-Sell-Trade Rating: (4)
It should be a good a idea to replace spark plugs, spark plug wires and the best o2 sensor are the oem(motorcraft) ones.
Nacidos Ford... Nacidos Fuerte...
2004 Sonic Blue SVT ZX3 EAP # 187, 1 of 74. Few mods done, more to come
HilloNative is offline
Old 03-29-2013, 08:37 PM   #3
duc450
duc450's Avatar
Fan#: 10651
What I Drive: 2004 Ford Focus SVT CD Silver
FF Reputation: 4 duc450 Good Standing Member
Check your wiring at your O2 make sure its connected well and check to make sure wiring isn't burned through anywhere. Look at your voltage on your scanner for your O2 and see what its reporting.
"If you ain't moving fast enough your costing me money and if your costing me money you ain't moving fast enough." -"The Machine"-
duc450 is offline
Old 03-30-2013, 02:20 PM   #4
TommyTooHi
TommyTooHi's Avatar
Fan#: 90859
hmmm... unplugged the 02 while the engine is running, no change.
Searching locally for a Motorcraft - Ford Parts at the chain stores - FAIL. O'Reilly wanted $140, next Wednesday delivery.
BUT!
A local Ford dealer actually has the best price (and it's in stock!!) at $67.04
Part # 9F472(DY-850) is superseded by 9F472(DY1040)
Ready to fire up the 'scooter' and head down there. Stay tuned, as they say...
-Quick
Old 03-31-2013, 10:55 AM   #5
TommyTooHi
TommyTooHi's Avatar
Fan#: 90859
Exclamation More data, and a FAIL
Well, it wasn't the O2. Hate throwing parts in needlessly.
Here's the latest freeze frame data:
Load: 61.1
STFT Bank 1 0.7%
LTFT 1 0%
Fuel 0.0 PSI 9
Um,,, fuel pressure, maybe?
I DID replace the fuel filter, but...
Ideas? Ways to continue diagnosing, please?
Thanks~
-T_T
Old 03-31-2013, 02:33 PM   #6
TommyTooHi
TommyTooHi's Avatar
Fan#: 90859
nobody?
Old 03-31-2013, 04:31 PM   #7
jetrinka
jetrinka's Avatar
Fan#: 45622
What I Drive: 88 5-speed XR4TI
FF Reputation: 180 jetrinka Excellent Standing Member jetrinka Excellent Standing Member
Buy-Sell-Trade Rating: (6)
If that fuel pressure reading is correct, 9PSI is not enough to run the car. I'd be verifying that reading with a mechanical gauge and if it reflects that data, replacing the fuel pump.
jetrinka is offline
Old 03-31-2013, 05:05 PM   #8
TommyTooHi
TommyTooHi's Avatar
Fan#: 90859
right...
Thanks, I've been searching for that manual gauge testing procedure too.
Edit:
http://www.focusfanatics.com/forum/showthread.php?t=210921
Q: "Fuel Pressure test gauge hook-up
I have a 2003 2.3 zx3. Where do I hook up a fuel pressure test gauge?"
A: "You don't.
You need a scan tool that can read PID's."
From what I can tell by my rather basic OBDII readout and other posts, that 9PSI reading is rather bogus, as in, it's not telling the whole story.
I think.
-T_T
Old 04-01-2013, 08:55 PM   #9
TommyTooHi
TommyTooHi's Avatar
Fan#: 90859
Still looking for good diag steps. Any help would be appreciated.
-Towing it to a Ferd dealer gives me the willies just thinking about it...
Thanks,
-T_T
Old 04-01-2013, 08:57 PM   #10
thenorm
thenorm's Avatar
Fan#: 14947
What I Drive: '04 liquid grey ZX3, built for FSP
Points 5,532, Level 47
Points: 5,532, Level: 47 Points: 5,532, Level: 47 Points: 5,532, Level: 47
Level Up 91% Completed
Forum Activity 10%
FF Reputation: 35 thenorm Great Standing Member
there is a big engine harness connector above the alternator. i had it once pinch the rubber gasket inside it leading to poor connections. it wouldnt be a bad idea to make all connections in that area are good and solids.
May 2014 ROTM
for auto-x: '04 Liquid Grey ZX3
for street: '02 Infrared SVT
thenorm is online now
