2010 SES Squeak and Shimmy - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-29-2013, 10:39 AM   #1
5characters
No Mo Fo Fo
5characters's Avatar
Fan#: 78897
What I Drive: 2012 M2 Touring
FF Reputation: 2 5characters Good Standing Member
My car makes this terrible noise every time I hit 50+ miles per hour as well as shimming bad, to the extent that the images in the mirrors become distorted, I just turned over 50,000miles in it.
The sound: Itís a squeak that is stressed whenever I hit a bump. I have narrowed it down to the rear driver side tire. I was thinking it was a blown strut, I did the Ďbounceí test and my car springs up steadily on both sides front and back. I got under the car and looked around and didnít see anything that looked to out of whack. Then I looked and tried to move any nuts or Ďmoveableí items everything was tight. All bushings and rubber was intact and none of them looked to be corroded.
So before I take it to the mechanic anyone have any insight on what Iím missing. Secondly I donít know if this is connected but when ever I get above 50 miles per hour the car seems to shimmy violently, like mentioned earlier the mirrors shake badly and the interior pieces rattle, my change will actually jump in the cup holder. I donít know if these two are related or if my car is starting to die.
Just bring me coffee!
5characters is offline
Old 03-29-2013, 01:06 PM   #2
A7xschecter6661
A7xschecter6661's Avatar
Fan#: 98263
What I Drive: 2011 Focus SEL
FF Reputation: 2 A7xschecter6661 Good Standing Member
sway bar bushing bracket is attached? I forgot to tighten mine once after I did drop springs. squeaked and made a weird noise and could also cause vibration
A7xschecter6661 is offline
Old 03-29-2013, 02:57 PM   #3
Miller88
Fan#: 73790
What I Drive: 2011 Focus SE 5 Speed
Points 1,735, Level 24
Points: 1,735, Level: 24 Points: 1,735, Level: 24 Points: 1,735, Level: 24
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
FF Reputation: 5 Miller88 Good Standing Member
The shimmying is probably a tire out of balance or a tire with a bad belt.
2011 Focus SE 5 Speed 36k - Blue Flame Metallic - Added Rear Swaybar
2000 Jeep Cherokee Sport 115k - Lifted with mud tires.
Miller88 is offline
Old 03-29-2013, 04:04 PM   #4
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,030, Level 74
Points: 13,030, Level: 74 Points: 13,030, Level: 74 Points: 13,030, Level: 74
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
Forum Activity 34%
Activity: 34% Activity: 34% Activity: 34%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (45)
Moved to "Wheels, Tires, Brakes & Suspension" as it seems you might get better answers there.
zetecDon is offline
Old 03-29-2013, 07:46 PM   #5
Red Jay 918
Red Jay 918's Avatar
Fan#: 79277
What I Drive: 2010 Focus SE
Points 9,338, Level 64
Points: 9,338, Level: 64 Points: 9,338, Level: 64 Points: 9,338, Level: 64
Level Up 96% Completed
FF Reputation: 7 Red Jay 918 Good Standing Member
have you checked to see if your tires have any abnormal wear on them? could be that and a separated tire... drove a Mustang w/ both... it was HORRIBLE!
Red Jay 918 is offline
Old 03-29-2013, 08:05 PM   #6
5characters
No Mo Fo Fo
Fan#: 78897
The tires all look normal, I have two snow tires in the front and street tires in the back. Ran this set up last year no problem, gonna order my new street tires soon, having them look at it and see what they say.
Old 03-30-2013, 09:04 AM   #7
gtferrari
gtferrari's Avatar
Fan#: 88110
Location: Grand Rapids/Big Rapids/Bangor/South Haven, MI
What I Drive: 2008 Vista Blue SES Coupe
Points 969, Level 16
Level Up 69% Completed
FF Reputation: 4 gtferrari Good Standing Member
My car would do the harlem shake and nobody knew why. Multiple alignments and balances but no improvement. The shake was so bad in the car it looked like i was drinking and driving. I wasnt to confident in winter driving because the car would start to skate around. When i put on the frpp suspensikn i found out there was no bushing in the control arm where it mounts to the nuckle. There was no way of telling as you couldnt wiggle the wheel but with the forces on a wheel as you drive what little movement there was.... unfortunately you cannot replace the bushing and have to replace the whole arm. You may be able to undo the bolt at the arm and using a jack ease the arm down. It will be under pressure from the spring. Then stick the bolt back in the bushing and try to wiggle around. There shouldnt be any movt.
Now when i undid my bolt it seized in place and i had to sawzall it out which is not fun. Its a $10 bolt from ford. The arm $140 is attached to the center of the car with an eccentric bolt to adjust the camber and that also seized on me and had to be cut out. $15 also only available from ford. they are both hardened bolts and access was poor. You could only get a inch or so of blade on them so i used 10 or so metal blades which took several hours to do. It might have gone quicker on a hoist instead of the low clearance of jack stands
2008 Vista Blue SES Coupe 5spd FRPP Zx3B Suspension
5000K D2S Retrofit
130,000+ miles and still on factory brakes and clutch!
Rep Points dont add themselves
gtferrari is offline
Old 03-30-2013, 11:25 AM   #8
Miller88
Fan#: 73790
My snow tires have bad belts (somehow ... after two winters) and that was causing the car to shake above 50 and pull very bad to the left. I thought the pulling and off center wheel were from alignment - apparently it was just caused by the bad alignment!
Miller88 is offline
