Issue Mounting Mach Headlights - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus First Generation > MK1 Focus
Old 03-27-2013, 11:59 PM   #1
Red01Focus
Fan#: 40437
What I Drive: 2001 Infa Red SE
FF Reputation: 10 Red01Focus Great Standing Member
Buy-Sell-Trade Rating: (56)
Posted this in my build thread but got no answer so i figured i would try here
Went to install machs and there seems to be an issue with that black tube on the passenger side getting in the way of the ballast any ideas how to fix that?
here's the pic
SEDAN REVOLUTION #13
Red01Focus is offline
Old 03-28-2013, 12:16 AM   #2
calebstubstad
Chef Boyardee
calebstubstad's Avatar
Fan#: 103240
What I Drive: 2000 Atlantic Blue LX
FF Reputation: 4 calebstubstad Good Standing Member
I just put mine in, and had no problem with that. does the tube move out of the way at all? probably a stupid question on my part. i'm sure it would atleast move enough to be out of the way, because the Mach's should have a relatively similar "footprint" to the stock halogens.
Rally Revolution #43
[HOONIGAN]
Originally Posted by matmatician View Post
Not the bear the zoo deserves, but the bear the zoo needs.
calebstubstad is offline
Old 03-28-2013, 12:30 AM   #3
Red01Focus
Fan#: 40437
Doesn't have much wiggle room honestly.The stock headlights always mounted fine but like i said the ballast and tube don't want to work together lol. I think i will try removing the fender so i can get a better view and try to get pics tomorrow
Old 03-28-2013, 06:44 AM   #4
02fordsvt
Meh.
02fordsvt's Avatar
Fan#: 84654
What I Drive: 2002 SVT, 2001 SE (Rusty)
FF Reputation: 49 02fordsvt Great Standing Member
Buy-Sell-Trade Rating: (11)
Mine has to go in just right before it fits. Does the pipe have just enough wiggle room to fit in the little cutout in the frame about an inch forward of it? I'm assuming that's where it's supposed to be and should give you enough room for the headlight.
Hatch Nation #13 : Rally Revolution #13 : ROTM Jan '13
It's Bryan, not Brian
RSVT-170 Build in Progress
Derusting Rusty Build in Progress
02fordsvt is offline
Old 03-28-2013, 10:47 AM   #5
jinstall
Deutsche Arsche
jinstall's Avatar
Fan#: 9730
What I Drive: 01 ZX3RACECAR/04 ST170/13 FST2
FF Reputation: 4 jinstall Good Standing Member
Those lines should fit in thoss notches.
2001 Focus ZX3 Race Car in Germany-Ours
2010 Renault Clio 1.2 16V in Germany-Hers
2004 SVTF EAP/ST170-Mine
2013 Focus ST2 TS NAV SUNROOF-Hers
jinstall is offline
Old 03-28-2013, 11:27 AM   #6
hurtinfocus
hurtinfocus's Avatar
Fan#: 835
What I Drive: 03 SVT (RS conversion)
FF Reputation: 4 hurtinfocus Good Standing Member
Buy-Sell-Trade Rating: (23)
the rubber portion on that line you're speaking of looks "kinked" to me....as if that tube needs to be bent backwards a bit top relieve the kink in the rubber tube portion, and coincidentally possibly clear the ballast
My majorly huge hand-made Focus RS replica build: http://www.focusfanatics.com/forum/showthread.php?t=289061
hurtinfocus is online now
Old 03-28-2013, 02:07 PM   #7
Red01Focus
Fan#: 40437
Ok great,will try to get it in the notches and fix the kink,just wanted to double check before doing something wrong
Old 03-29-2013, 04:45 AM   #8
Red01Focus
Fan#: 40437
well the tubing wouldn't fit in the notches,the wiring in the loom below it interferes. i had to push the hose back a bit to fit in the mach not perfect but it will have to do
Old 03-29-2013, 06:30 AM   #9
02fordsvt
Meh.
02fordsvt's Avatar
Fan#: 84654
Grab the loom and pull it out from underneath if it's still a problem. It's supposed to be above the hoses by the looks of it.
