Rebuilding options for SVT Focus? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-27-2013, 02:00 PM   #1
pdavison9241
Fan#: 97643
What I Drive: 2003, Black, SVT
Points 134, Level 2
Points: 134, Level: 2 Points: 134, Level: 2 Points: 134, Level: 2
Level Up 68% Completed
FF Reputation: 1 pdavison9241 Good Standing Member
Exclamation Rebuilding options for SVT Focus?
Greetings fellow Focus Fanatics! This is my first post and it couldn't have come at a better time. The timing belt idler pulley on my '03 SVT Focus let go while I was sitting at a traffic light and smoked all of the valves in the head. The engine and car have 174k and because I have to take the engine apart and have machine work done anyways, I wanted to take as much advantage of the situation as I can. What would the community recommend I do to the block and head while I have this opportunity? I do not care about crazy mods and outrageous cams and setting it up for boost or anything like that, I just want to improve on it from the factory and wake it up a little while maintaining optimum driveability. I was considering doing a port/polish and angled valve job while keeping the block relatively stock (maybe balance the crank). Looking for about 160-170 to the wheels if I can get it with bolt-ons and tuning. The basic question is this: what machine work can I do and not compromise the car's driveability? Thank you for any insights and advice from the community. I'm counting on you guys!
pdavison9241 is offline
Old 03-27-2013, 04:54 PM   #2
ViperThreat
Dat boxer rumble
ViperThreat's Avatar
Fan#: 66026
What I Drive: '06 WRX Wagon 285whp/292wtq
Points 7,819, Level 59
Points: 7,819, Level: 59 Points: 7,819, Level: 59 Points: 7,819, Level: 59
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
Forum Activity 13%
FF Reputation: 9 ViperThreat Good Standing Member
Welcome to the forums!
While there are gains to be had from what you have stated, getting 160-170 to the wheels will take full bolt-ons and a tune on top of the port/polish/balancing you mentioned. But from what it looks like, you prettymuch have a good plan laid out for some added power.
Moderator For: Socal Fanatics | SVT Focus | Mk1 Focus | Audio & Electronics | General Chat
"Ford Focus ST - the official car of message-board circle-jerks"
-Regular Car Reviews
ViperThreat is offline
Old 03-27-2013, 06:07 PM   #3
pdavison9241
Fan#: 97643
Points 134, Level 2
Hey brother, thanks for the quick response. This is my daily driver and so I need to get it back on the road ASAP. I've lurked on these forums long enough to know that the ST170 is pretty much tapped out from the factory n/a with a restrictive factory tune. I am not so much concerned, like I've said, about overall power as I am responsiveness and driveability. Are there any references with more information? I know that "Tom" is a big-wig in these here parts; what would he say? Thanks!
Old 03-27-2013, 10:14 PM   #4
pdavison9241
Fan#: 97643
Points 134, Level 2
I'd like to be a little more detailed with the information that I am looking for; I gather that the bottom end doesn't need to be messed with short of balancing the crank (if necessary). Using a thinner head gasket (with proper tune) could probably yield some minor results. The real question that I have is when the machine shop works the head, what should I tell them to do? What would be the right amount of material to take off without compromising performance? Has anyone done any head/valve work like this? Other planned bolt-ons include c-f-m throttle body (anyone had fitting problems with stock airbox?), drop-in filter, ORP/HFC (which one? I want to keep the noise civil, but I'd like to gain as much as possible here), lower engine mount, possibly ignition wires, clutch/flywheel (recommendations?), tune. Any other ideas would be welcome.
Old 03-27-2013, 11:01 PM   #5
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,526, Level 100
Points: 52,526, Level: 100 Points: 52,526, Level: 100 Points: 52,526, Level: 100
Level Up 0% Completed
Forum Activity 63%
Activity: 63% Activity: 63% Activity: 63%
Buy-Sell-Trade Rating: (28)
I wouldnt do anything to raise the compression on 93 octane fuel , If your going to run 98/100 octane all the time then raise the compression
Why are you having to do a rebuild ?
Things that help the SVT
3 inch Exh
ORP
TB
Drop in filter
Tune (which I can help you with)
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 03-28-2013, 12:15 AM   #6
pdavison9241
Fan#: 97643
Points 134, Level 2
3 inch Exh
ORP
TB
Drop in filter
Hey Tom, you're just the man I was hoping to run into. I've seen and heard good things about your work. As far as why I have to do a rebuild, the timing belt idler pulley failed and wrecked the valves. The engine has 174k on it with history of overheating with a previouse owner. Since I don't own any receipts and generally have no idea what the car has really been through, I figured tearing the whole thing down, measurements and a rebuild would insure another 100k of fun daily driving. Since I am on a budget and don't have huge power gains in mind, I want to make the most out of having to do machine work anyways. I don't have access to better fuel, so raising compression is out. What should I look out for and replace during my rebuild so I don't have another failure? Thanks for your help!
Old 03-28-2013, 10:42 AM   #7
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 63%
Your limited on what you can do with a rebuild , just use good parts , change out the idlers with the timing belt , the mods listed above and unless your willing to spend about 1000.00 on cams and about 750.00 on an intake manifold thats about all you can do
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 03-28-2013, 11:01 AM   #8
pdavison9241
Fan#: 97643
Points 134, Level 2
Cool, thanks for the information. Anything to keep in mind when machining the head? Also would it be worth it to replace the clutch/flywheel with a lighter unit for an extra $4-500 or should I just stay with a stock replacement unit form Luk?
Old 03-28-2013, 01:10 PM   #9
macdiesel
I used to drive this
macdiesel's Avatar
Fan#: 31579
What I Drive: 2010 red mazdaspeed3 w/tech package
Points 4,234, Level 41
Points: 4,234, Level: 41 Points: 4,234, Level: 41 Points: 4,234, Level: 41
Level Up 43% Completed
Forum Activity 4%
FF Reputation: 22 macdiesel Great Standing Member
Buy-Sell-Trade Rating: (17)
I'd go with a lwfw. I'd imagine you would want a good machine shop so they don't mess it up.
I now drive a Japanese Ford.
macdiesel is offline
Old 03-28-2013, 04:32 PM   #10
ukfan50
ukfan50's Avatar
Fan#: 91208
What I Drive: 2003 VW Golf GTI 20th AE #2485/4000
FF Reputation: 1 ukfan50 Good Standing Member
If I were in your shoes and you said you need to get it back on the road quickly, then just look for/source a motor from here on the forum or start searching the interwed. There are sites that 1000's of junkyards all across the US that upload all their parts to 1 website. When the tranny went on my SVT Contour I thought I was screwed bc you can't find the parts new to rebuild (or at least I couldn't). So I found a site with a SVTC tranny with 6K miles but it was in Alaska. I cleaned the guy up asking all sorts of questions, van the VIN from the car it was from & his story matched up. After some hardball negotiation I got it for $900 or $950 shipped. Dropped the old one out and installed the new one, after obviously cleaning it up and running several bottles of fluid through it to clean the inside. Just do some research, you might be surprised at the deal you could get.
2003 BMP VW Golf GTI 20th AE #2845 of #4000 (Purchased 3/2014)
2002 Sonic Blue SVT Focus #1200 (Sold 2/2014)
2000 T-Red SVT Contour #1089 of #2150 (Sold 10/2011)
1998 BDP Subaru Impreza 2.5RS #1595 of #1695 (Sold 1/2010)
ukfan50 is offline
