Old 11-29-2004, 03:07 PM   #1
Boragon
Guest
Fan#: 15951
What I Drive: 2005, Dark Gray, ZX4 ST
FF Reputation: 1 Boragon Good Standing Member
Question Aftermarket Flywheel.........
I just got my new 2005 Focus ZX4 ST, and I'm thinking of adding an aftermarket flywheel. I do know my around a wrench but I'm not a mechanic. Is changing the flywheel something I could do, or should I let the pro's handle it?
P.S.
How long does one have to wait for aftermarket parts to start showing up? IE (Euro Tail Lights & Body Kit)
Thanks
Boragon is offline
Fan#: 1
Old 11-29-2004, 10:35 PM   #2
Chrspy640
Fan#: 11631
What I Drive: 2005 ST
FF Reputation: 1 Chrspy640 Good Standing Member
From what I understand, this is probably something you should let a professional handle. To change the flywheel, you have to take out the transaxle, which on the Foucs is harder than on many cars. I'm planning on upgrading my flywheel, clutch, and adding a limited slip differential all at once so that they only have to take it apart once.
P.S. Which flywheel are you looking at? The Focus Sport one is listed as fitting the Zetec, but I think it should work because the transmission is the same.
Chrspy640 is offline
Old 12-03-2004, 02:04 PM   #3
Boragon
Guest
Fan#: 15951
Thanks, I was not sure how complicated the process was. As for the Flywheel type, the one on Focus Sport is the one I was looking at.
Boragon is offline
