Sedan owners, watch for this. Potential wire failure in trunk. - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-31-2013, 02:54 AM   #11
estoyloco
Fan#: 85580
What I Drive: 2013 Dart Limited
Points 2,844, Level 32
Points: 2,844, Level: 32 Points: 2,844, Level: 32 Points: 2,844, Level: 32
Level Up 63% Completed
FF Reputation: 1 estoyloco Good Standing Member
Originally Posted by Some Guy From NY View Post
Ford making a poor design choice?
Ya dude its called the Focus 2012 new design.
EX-Owner of:
Ford Focus 2012 Sedan 303A SEL w/ Winter package
Sterling Grey Metallic - Medium Light Stone Leather
estoyloco is offline
Old 08-08-2013, 02:20 PM   #12
CunFFS13
CunFFS13's Avatar
Fan#: 117411
What I Drive: 2013 Sterling Gray Ford Focus S MT
Points 2,400, Level 29
Points: 2,400, Level: 29 Points: 2,400, Level: 29 Points: 2,400, Level: 29
Level Up 67% Completed
FF Reputation: 6 CunFFS13 Good Standing Member
I'll be checking mine as soon as stops raining
CunFFS13 is offline
Old 08-08-2013, 04:01 PM   #13
Seminoles
Seminoles's Avatar
Fan#: 98405
What I Drive: 2012 SGM SE Sedan
Points 969, Level 16
Level Up 69% Completed
Forum Activity 2%
FF Reputation: 1 Seminoles Good Standing Member
Deleted
Seminoles is offline
Old 04-03-2014, 09:56 AM   #14
drag-t
drag-t's Avatar
Fan#: 103525
What I Drive: 2012, Silver SE Sport
FF Reputation: 1 drag-t Good Standing Member
Originally Posted by Twenty View Post
Saturday I was out running some errands with my mother. We got back to the Focus, put our things in the trunk, hopped in, and went to drive off. Suddenly, the TRUNK AJAR warning came on, so I got back out to open and close the lid again, thinking it was just mistaken somehow. It wouldn't open. The key fob wouldn't open it, nor would the button on the trunk lid itself. I released it using the emergency release inside (by crawling in through the back seat opening) and shut it. Driving off, the warning came back on.
Upon getting home, the trunk still wouldn't open and the car was still convinced the trunk was ajar. After an inspection I found the culprit:
Cut wire. Notice how there's no loom or protection of any kind there? While it doesn't pass through metal (though it looks like it in the picture), it appears that over time the moving and folding of the wires as the trunk lid is opened and closed caused the wire to weaken, and it finally broke in half.
Today I drove it in to work to let a coworker who does electrical reconnect it - thus documenting the problem and avoiding any potential future warranty issues (thanks to Mike for fixing it, by the way!). As I was backing up into the bay though, he called out to say my reverse lights started flickering - and then they cut out entirely.
Following a repair of the wire, it and the rest were then taped up and covered in a section of wire loom, as they should have been from the factory. The reverse lights work again, the trunk opens as it should, and the warnings are gone from the cluster.
The rest of the wires were still in good shape but that one had had enough and split in two. So sedan owners, check to see if your wires are covered, and if not note that you could have a problem if one weakens like this one did.
Hi Twenty,
I'm having the same issue with my trunk lid not opening. Thought it was the fuse or the key fob battery, but no luck there... Took it to my dealer and they couldn't find the problem...
Can't view the links to your photos that you posted (blocked at work), but I'll try viewing them when I get home.
And I'll start looking at the wiring as well...
Thanks,
Dave
drag-t is offline
Old 04-06-2014, 07:01 PM   #15
drag-t
drag-t's Avatar
Fan#: 103525
Thanks to Twenty I inspected the trunk wiring and found a broken wire as well. The wiring is not protected other than electrical tape. Routing of the wiring is mediocre at best. How and where the wires are mounted puts undo stress on them every time the trunk is opened and closed. Poor design...
drag-t is offline
Old 05-24-2014, 01:32 PM   #16
CunFFS13
CunFFS13's Avatar
Fan#: 117411
@drag-t
It should be covered under warranty!
CunFFS13 is offline
