SRI to cold for cold weather driving - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-27-2013, 06:05 PM   #11
S0C0nFused
S0C0nFused's Avatar
Fan#: 39405
What I Drive: 2007 TorD-Red ZX5 SES
Points 12,348, Level 72
Points: 12,348, Level: 72 Points: 12,348, Level: 72 Points: 12,348, Level: 72
Level Up 75% Completed
FF Reputation: 77 S0C0nFused Excellent Standing Member
Originally Posted by Dukttape View Post
The car was reading 4 outside temp. .
As in 4f, -4f, or typo and you meant -40f. Reason. If your any 'warmer' than -40f, then intake temp is not the issue. You sure you did not 'ingest' a snow cloud? The ice crystals would intrap in the filter, essentially plugging it. (just guessing here).
P.S. Roush made an SRI? Another OP was asking whether there was an SRI other than Steeda. Please confirm. Thanks.
Steeda SRI w/CAI intake. Trubendz SS 2.5" . FR Susp/Struts. Tune by Tom (FocusPower). Rota Grids. SAP rear spoiler. Custom front air dam, rocker panel bits and Rear valance.
Last of the Hatches #28
S0C0nFused is offline
Old 03-27-2013, 07:31 PM   #12
Dukttape
Dukttape's Avatar
Fan#: 94135
What I Drive: 2011 Sangria Red SE Sedan "Fiona"
Points 635, Level 12
Points: 635, Level: 12 Points: 635, Level: 12 Points: 635, Level: 12
Level Up 70% Completed
FF Reputation: 1 Dukttape Good Standing Member
The car said 4 the weather site said -10.
The Roush intake. By design its a SRI.
Roush performance intake, Exedy 12.5 lb flywheel, Massive 76A lower engine mount... more to come with more money.
Dukttape is offline
Old 03-27-2013, 08:45 PM   #13
6SPD_soul
6SPD_soul's Avatar
Fan#: 53637
What I Drive: 2003 Comp Orange EAP SVT
Points 2,489, Level 30
Points: 2,489, Level: 30 Points: 2,489, Level: 30 Points: 2,489, Level: 30
Level Up 26% Completed
FF Reputation: 24 6SPD_soul Great Standing Member
The MAF actually uses a 5ish volt feed to a resistor thats placed in the intake stream of air, as increasing volumes of air flow past the MAF resistor, the cooling effect of the airflow decreases the MAFs resistance line, and the PCM receives a corresponding increased voltage (since it's being cooled by airflow) return and thus more air volume is measured going into the engine.
Cold air didn't cause any problems here, not by itself. If you could magically feed your engine -50F air while ambient temp for fuel and everything else was a more reasonable 35F, it would probably be a very happy engine and car. There would be a point eventually when the fuel trim would be pegged out maximum rich and no longer be able to supply any more extra fuel to match the actual volume of the super dense cold air ingested, and then the engine would just run leaner than the 14.7:1 it was shooting for. It would still run, and probably into -100F given the fuel and the rest of the car were at a magically balmy 35F, it would be dangerously lean and could cause damage, but it would probably still run. If I had to guess, this might happen at maybe -70F, again assuming the rest of the car and fuel were in a magical 35F environment. Even if it weren't a magical 35F everywhere else, who knows when the fuel would start to gel or freeze or stop proper atomization. Probably at colder temps than anyone could expect to reliably survive in.
Were there other cars on the road when yours stumbled? Was your car getting air any colder than the cars around you? Possibly, but it still wasn't any colder than ambient temp and they were probably getting around fine still. Every model of car on this site went through cold weather testing probably between -30 or -40, they may have even tweaked the antifreeze to enable this.
Please don't "bash" peoples valid responses until you fully understand them.
Last edited by 6SPD_soul; 03-27-2013 at 11:18 PM. Reason: I wasn't mean enough yet.
6SPD_soul is offline
Old 03-27-2013, 10:20 PM   #14
jetrinka
jetrinka's Avatar
Fan#: 45622
What I Drive: 88 5-speed XR4TI
FF Reputation: 180 jetrinka Excellent Standing Member jetrinka Excellent Standing Member
Buy-Sell-Trade Rating: (6)
I have the Roush intake not the Steeda so I don't have an insert to put in.
The duratec pulls air from the crack between the hood and the grill with the stock setup as well as being a big plastic box that does allow for some engine heat to leach in where as the Roush intake is a big powder coated steel heat sink just stays cold because of the air flow in and around it.
I put the HID ballast in the heat shield to warm up the shield and air just enough so that the oil coming in from the breather hose doesn't muck with the throttle body when cruze is disengaged with the clutch. Also since the filter is drawing much more O2 dense air than the stock intake the car runs lean at higher RPMs/Speeds. Next winter I'm going to put an arm band around the smaller filter to lessen the air flow a bit to help with lean issue.
Please don't bash something until you fully understand it.
Thus the removing of the stock snorkel and putting a blocker in that slot of the intake heat shield.
It seems you might need some help understanding..
I can guarantee you that the air coming in from the stock intake is colder than the air of a short ram. Have you ever logged IAT's? I doubt it. The only thing the SRI helps with is lessen intake restriction. It certainly doesn't pull in colder air..
The next thing is the colder air IS NOT making your car run lean. The car has the capability to inject the correct amount of fuel for huge amounts of varying conditions including air temp, elevation, load, etc etc. The list goes on and on. If its off, the O2 sensor registers it and the ECU makes a correction one way or another. If your car is running lean or has a lean code i'd start looking at the diameter of that MAF tube of your SRI as the prime suspect, not intake temps...
I also seriously doubt your MAF is freezing... That just isn't how the sensor works. The sensor has a hot wire in it whose resistance increases or decreases depending on how much air is flowing past it thereby cooling it. The more air, the cooler the wire gets, and the resistance decreases. This is how the ECU determines how much air is actually being ingested by the engine.
If your car indeed is running lean, that aftermarket MAF tube is your problem.
jetrinka is offline
Old 03-27-2013, 11:05 PM   #15
Dukttape
Dukttape's Avatar
Fan#: 94135
The thing that is stumping me is this is an issue only when its really cold. I originally posted as a list of solutions for my issues hoping that they might help someone else and maybe get an answer to what is going on. The next thing on my list of stuff to check is the IAC. That's if I can find it . Any other part(s) I should check?
Dukttape is offline
Old 03-27-2013, 11:15 PM   #16
jetrinka
jetrinka's Avatar
Fan#: 45622
You need to see if there are any codes stored in the computer. You also need to ability to monitor different parameters the ECU sees, namely short and long term fuel trims, MAF values, ECT and IAT. If the long term values are really high, chances are you've got a vac leak or a MAF issue.
jetrinka is offline
Old 03-27-2013, 11:59 PM   #17
darkknight9
darkknight9's Avatar
Fan#: 109076
What I Drive: 1995 Green Escort LX
Points 75, Level 1
Points: 75, Level: 1 Points: 75, Level: 1 Points: 75, Level: 1
Level Up 50% Completed
FF Reputation: 2 darkknight9 Good Standing Member
However you want to, but if you don't cut off most of the airflow to the radiator its gonna take a loooooooooong time to warm up when its negative digit temps outside.
Rally Revolution #74 Drive er straight sideways lad!
Saving for a Focus wagon for a daily
History: 1975 Chev 1 ton Camper Special, 1977 LTD II (Best car I've ever owned), 1985 Toyota Corolla, 1995 Ford Escort LX (current)
darkknight9 is offline
