molded factory hoses vs. bulk hose - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Discussions > Ford Focus & General Car Chat
Old 03-26-2013, 06:18 PM   #11
amc49
Fan#: 96610
Points 3,381, Level 36
Points: 3,381, Level: 36 Points: 3,381, Level: 36 Points: 3,381, Level: 36
Level Up 21% Completed
Forum Activity 55%
Yes, you must provide for absolutely no kinking, meaning you must sometimes figure out a new method of retaining hose when it runs somewhere other than where it did before. My heater core hoses now run closer to back of block rather than at the firewall hence the need for a strap to hold them away from exhaust pipe.
I use ATX cooler line for the smaller OD hoses which lead to another problem of cost. The hose is almost as high as the custom hoses are. I started patching in pieces of 5/16 or 3/8 steel brake line to make up much of the length then use the expensive cooler hose in 4-6 inch lengths at the ends to keep the cost down. The steel brake line can easily be bent to change direction too, and much cheaper than copper. Done correctly and retained with plastic wireties it looks good and neat, not trashy, just immediately evident it's not stock. I don't hesitate to drill another hole here or there in the upper radiator support for another tie strategically placed.
I use copper where I need it, the three way plastic manifold at top of radiator has been replaced with a copper part I soldered up, 3 of them running now on three cars and 100% trouble free. I also have soldered bigger copper to smaller to make hose reducers for when Ford changes hose sizes on the ends, I really hate that crap. The Contour has a 5/8 hose for part of the run, reducer, then 3/4 rest of the way. I do the same on Focus passenger side lower rad hose to reservoir, space it at the power steering supply hose coupler and it looks factory.
I've found on Focus It's helpful to have rubber only the last 2 feet from the plastic reservoir, that allows you to unbolt reservoir and flip it upside down on top of the PS unit, it makes plenty of room around the pass motor mount for alt and cam belt changing.
This stuff takes the place of my building the race cars in the '70s, easy and allows my creative urge some outlet. Nowadays I get as much out of doing it as cheap as I can, but solid as a rock and never breaks, it takes the place of 600 HP street cars.
amc49 is offline
Old 03-27-2013, 12:33 PM   #12
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,622, Level 31
Points: 2,622, Level: 31 Points: 2,622, Level: 31 Points: 2,622, Level: 31
Level Up 15% Completed
Forum Activity 2%
bent hardline tubing is one of my favorites for replacing hose
Used to TiG together neat coolant piping and such on customers' cars
elsolo is offline
Old 03-27-2013, 11:29 PM   #13
Sniper Focus
Sniper Focus's Avatar
Fan#: 84221
What I Drive: '03 SVT EAP "Eurotrish"
Points 2,133, Level 27
Points: 2,133, Level: 27 Points: 2,133, Level: 27 Points: 2,133, Level: 27
Level Up 89% Completed
Level up: 89% Level up: 89% Level up: 89%
Forum Activity 21%
Activity: 21% Activity: 21% Activity: 21%
FF Reputation: 22 Sniper Focus Great Standing Member
Buy-Sell-Trade Rating: (13)
Gates makes a "Unicoil" that makes straight hose bendable without kinking. Just throwing it out there.
Sniper Focus is online now
Old 04-01-2013, 03:35 AM   #14
amc49
Fan#: 96610
Forum Activity 55%
That unicoil would be great except for the absolutely stupid ridiculous price per piece, they have pretty much priced themselves out of sales as far as my concern. I can solder up a copper L or T for virtually same price or less and indestructible.
You can curve bulk hose to an extent by shaping it the first time it has hot fluid going through it, any slight kink disappears when pressure fills out the hose shape, once formed it will tend to stay that way. I've done it many times.
amc49 is offline
Old 04-01-2013, 04:07 AM   #15
emsvitil
Fan#: 50210
What I Drive: 2000 SE Wagon
Points 3,117, Level 34
Points: 3,117, Level: 34 Points: 3,117, Level: 34 Points: 3,117, Level: 34
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
Forum Activity 4%
FF Reputation: 9 emsvitil Good Standing Member
Another trick (after using the natural curve of the hose) is to put a twist on the hose to get it to do what you want it to do......
Along with the copper elbows, look at the PEX brass fittings (you can also solder the copper to the pex pieces to get what you need)
Ed
emsvitil is offline
