molded factory hoses vs. bulk hose - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Discussions > Ford Focus & General Car Chat
Old 03-26-2013, 04:19 AM   #1
amc49
Fan#: 96610
Points 3,387, Level 36
Points: 3,387, Level: 36 Points: 3,387, Level: 36 Points: 3,387, Level: 36
Level Up 25% Completed
Level up: 25% Level up: 25% Level up: 25%
Forum Activity 54%
Activity: 54% Activity: 54% Activity: 54%
Just redid all the cooling hoses on one of my Focus zetecs, I used bulk hose in place of the formed hoses normally sold over the counter. All rubber hoses changed except the big upper and lower radiator ones. Those custom hoses are getting downright astronomical to me, running parts prices at the O'Reilly website showed me saving roughly $140 using the bulk hose over the bent hoses and that using Gates pricing, Motorcraft gets even higher. Of course you have to custom cut and place the non-stock hose, but not too bad, main thing was to make a support strap to hold the heater hoses away from exhaust pipe heat. That may have cost another $2 in strip metal material. That savings also included a new rear PCV hose cobbled up to save buying the Ford rear hose. Mine cost maybe $7-$8.
This type mod already proved out on two other zetecs with same hoses, they last as long as the formed ones do and at $1.39 a foot cost way less than the average hose at $20 or so a pop. First time I ever closely laid a costing on it though I knew long ago the savings would be big.
Also recovered the plastic reservoir, it was badly stained to where I could not see inside fluid level at all. Used regular gasoline inside, let it sit for a couple days to soften the deposits and then threw some small grain aquarium gravel I had lying around to use it like a scrubber inside. Shake it hard for a few minutes at every imaginable angle, it cleans the areas inside the different compartments awesomely. A good rinse while turning it again at all angles gets all the gravel back out. When done tank looked like brand new except for slight yellowing of the plastic. Could see fluid level as easily as a new tank when done. Note the cap gasket will warp out of shape from the fuel, but I yanked mine (cut, about to fail) and changed it for a custom made one from hardware store that I paid $1.09 for to avoid the $7.99 cap price. I had to cut a correct ID in the rubber to make it work. If you still want to use your cap then let it sit for a day or two and the rubber will drop back down to correct shape, the fuel only swells it temporarily. Or you could buy an o-ring from hardware store for maybe a buck or two, it won't seal correctly on cap in actual use, but strip out your good seal to save and use the o-ring for the cleaning job only, then toss it. You still save money.
amc49 is online now
Old 03-26-2013, 04:30 AM   #2
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,700, Level 100
Points: 140,700, Level: 100 Points: 140,700, Level: 100 Points: 140,700, Level: 100
Level Up 0% Completed
Forum Activity 50%
Activity: 50% Activity: 50% Activity: 50%
FF Reputation: 50 sleepyboy Excellent Standing Member
Buy-Sell-Trade Rating: (11)
I got the molded lower radiator hose the good year brand and I had to cut quit a bit of it off to get it to fit as it wasn't really molded but just bulk hose with a t connector on it. So I'm sure you could make those hoses your self using the bulk hose for much much cheaper.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 03-26-2013, 04:31 AM   #3
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 50%
I also moved the thread to the MK1 section
Moderator for
Technical Chat
Old 03-26-2013, 05:46 AM   #4
amc49
Fan#: 96610
Forum Activity 54%
Fine by me....................
amc49 is online now
Old 03-26-2013, 05:56 AM   #5
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 50%
Ok, I kept thinking about it so now I moved to Ford Focus and General Car chat area. That way everyone can see it. I know it's for the zetec but this could go for the other models as well. Might as well spread the information around.
Moderator for
Technical Chat
Old 03-26-2013, 06:10 AM   #6
amc49
Fan#: 96610
Forum Activity 54%
That's true, I've done the same on Contour and two Tempos, I don't put the factory bent hose on anything that'll accept straight bulk hose. The savings were high but now getting unbelievable.
amc49 is online now
Old 03-26-2013, 06:19 AM   #7
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 50%
I believe that, you can imagine my dismay when I got that good year hose in and found it was just a mixed together mess of normal hoses.
Moderator for
Technical Chat
Old 03-26-2013, 10:44 AM   #8
wrc_fan
slow
wrc_fan's Avatar
Fan#: 11913
What I Drive: 03 ZX3 Duratec 08 WRX Hatch
Points 3,584, Level 37
Points: 3,584, Level: 37 Points: 3,584, Level: 37 Points: 3,584, Level: 37
Level Up 56% Completed
FF Reputation: 23 wrc_fan Great Standing Member
It doesn't help cost wise, that the zetec uses a bazillion coolant hoses.
Parking Lot Hero
2008 WRX daily driver
2003 ZX3 23D Autox Car 42 FSP
"Hella Functional - Raced, Not Hard Parked"
wrc_fan is offline
Old 03-26-2013, 01:33 PM   #9
emsvitil
Fan#: 50210
What I Drive: 2000 SE Wagon
Points 3,117, Level 34
Points: 3,117, Level: 34 Points: 3,117, Level: 34 Points: 3,117, Level: 34
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
Forum Activity 4%
FF Reputation: 9 emsvitil Good Standing Member
I did the same thing...
I just bought the upper and lower radiator hoses (one of which was a weird 3 way) plus 1 molded hose that was something like 7/8 on one end and 1/2 on the other....
Another trick is that I used copper and brass plumbing elbows and reducers for the tight turns or if the hose had 2 different sizes (there are 2 hoses on the back side that change size on back side coupled to each other, I changed it to one hose of constant size)
Ed
emsvitil is offline
Old 03-26-2013, 01:50 PM   #10
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,622, Level 31
Points: 2,622, Level: 31 Points: 2,622, Level: 31 Points: 2,622, Level: 31
Level Up 15% Completed
Forum Activity 2%
So long as the bends aren't so tight that the hose pinches closed.
elsolo is offline
