need help on 2001 ford focus se 2.0 16v tps - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-25-2013, 04:47 PM   #1
andrew4
Fan#: 112114
What I Drive: 2001 silver birch se
FF Reputation: 1 andrew4 Good Standing Member
i have a 2001 ford focus se 2.0 16v zetec dohc vin 3
i need to know the voltage for the tps sensor while its closed
any help would be greatly appreciated
andrew4 is offline
Old 03-25-2013, 05:06 PM   #2
amc49
Fan#: 96610
Points 3,360, Level 36
Points: 3,360, Level: 36 Points: 3,360, Level: 36 Points: 3,360, Level: 36
Level Up 7% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
No exact number, thinking the range from .98 idle to 4.84 wide open, idle must be slightly under one volt. The PCM makes up for any slight variance, if TPS put in correctly it should be right. PCM recreates the absolute start and stop volts if switch in right. More important is measuring volts through the swing and no drops or jumps there at all, only smooth increase or decrease of voltage. Look close at idle and just off idle, the switch contacts spend most of the time around there and vibration wears the resistor track more.
Meaning the pure idle setting could vary from switch to switch and still run fine.
amc49 is offline
Old 03-31-2013, 03:11 PM   #3
andrew4
Fan#: 112114
i need to know what a non adjustable tps sensor volt .9 1.1 v is
andrew4 is offline
Old 04-01-2013, 12:05 AM   #4
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,363, Level 75
Points: 13,363, Level: 75 Points: 13,363, Level: 75 Points: 13,363, Level: 75
Level Up 29% Completed
Level up: 29% Level up: 29% Level up: 29%
Forum Activity 99%
.9 1.1 v is - voltage range you should see at idle position, as described above in more detail.
sailor is online now
Old 04-01-2013, 01:19 AM   #5
amc49
Fan#: 96610
Forum Activity 40%
Thinking better to stay just under one volt, I hear one volt can be the cutoff limit, past that PCM assumes car is in off-idle mode and will be starting to change up A/F ratios from the pure idle one.
'non adjustable tps sensor volt .9 1.1 v'
That means normally you don't adjust it, it goes in where the screws tighten it down at, the voltage will be correct if right part used. Of course that means if you don't have the correct TPS (ATX vs. MTX) you will have a problem, they do not go in in the same position and voltage will be wrong if using the wrong part.
amc49 is offline
