Front LCA bushing - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-24-2013, 12:21 AM   #1
Neptune15
Neptune15's Avatar
Fan#: 91691
What I Drive: '07 ZX3
Points 1,032, Level 17
Points: 1,032, Level: 17 Points: 1,032, Level: 17 Points: 1,032, Level: 17
Level Up 32% Completed
FF Reputation: 1 Neptune15 Good Standing Member
Front LCA bushing
I've been hearing a popping noise lately and think it's the bushing on the rear of the front lower control arm. When I grab the arm there is a little bit of play in this area.
I've looked around and can only find people saying you need to take the entire arm out and need a machine to press the bushing out to replace it. Is this true, if I only want to replace this single bushing (car only has 70kms on it)? Are there any shortcuts to this job?
Thanks.
Neptune15 is offline
Old 03-24-2013, 09:40 AM   #2
don627
Fan#: 56863
What I Drive: 2014 Focus Hatchback
Points 208, Level 4
Points: 208, Level: 4 Points: 208, Level: 4 Points: 208, Level: 4
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
Forum Activity 2%
FF Reputation: 1 don627 Good Standing Member
I had the same problem and you are exactly right of the cause. Replace the entire LCA which is easy and you are golden! While your at it do the other side too. It isn't that expensive and it is easy to do. As a bonus you get all new bushings. You may need an alignment afterward.
don627 is offline
Old 03-24-2013, 10:33 AM   #3
Neptune15
Neptune15's Avatar
Fan#: 91691
To the dealer I go, to take advantage of my extended warranty (if it's covered).
Thanks don.
Old 03-24-2013, 05:27 PM   #4
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,345, Level 75
Points: 13,345, Level: 75 Points: 13,345, Level: 75 Points: 13,345, Level: 75
Level Up 24% Completed
Forum Activity 99%
Various diagnoses avail. for a "popping" noise, from ball joints to sway bar links depending on when it happens.
I'm going to move this over to "Wheels, Tires, Brakes & Suspension" area for more comments....
sailor is online now
Old 03-24-2013, 05:39 PM   #5
macdiesel
I used to drive this
macdiesel's Avatar
Fan#: 31579
What I Drive: 2010 red mazdaspeed3 w/tech package
Points 4,233, Level 41
Points: 4,233, Level: 41 Points: 4,233, Level: 41 Points: 4,233, Level: 41
Level Up 42% Completed
Forum Activity 4%
FF Reputation: 22 macdiesel Great Standing Member
Buy-Sell-Trade Rating: (17)
Little play might be alright. It is a rubber bushing. Is the bushing ripped or damaged? Gus it doesn't really matter since your bringing the car in for service.
I now drive a Japanese Ford.
macdiesel is offline
Old 03-24-2013, 07:15 PM   #6
forddorf
Fan#: 31248
What I Drive: 2001 malibu blue zx3 / turbo-2004
Points 925, Level 16
Points: 925, Level: 16 Points: 925, Level: 16 Points: 925, Level: 16
Level Up 25% Completed
Level up: 25% Level up: 25% Level up: 25%
FF Reputation: 3 forddorf Good Standing Member
Might be coming from the strut bearing.
forddorf is online now
Old 03-24-2013, 09:56 PM   #7
Neptune15
Neptune15's Avatar
Fan#: 91691
I'm 95% sure this is the cause. I already replaced the endlinks (it fixed a bit of noise). When I pull at the balljoints, strut etc there's no movement, except for that one part of the LCA. It makes the same exact noise when I'm pulling as I do driving over bumps.
Old 03-27-2013, 10:20 AM   #8
Neptune15
Neptune15's Avatar
Fan#: 91691
So the dealer quoted me $800 to replace both control arms.
Went down the street and got the one control arm for $100.
Just a quick question - are the bolts one-time use? Also, does the 2007 use a T50 Torx bolt too?
edit: Also which is the "inboard bracket nut" vs "outboard?"
