No pressure in clutch pedal - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-23-2013, 12:11 PM   #1
akram1027
akram1027's Avatar
Fan#: 101150
What I Drive: 2003 bronze red zx5
FF Reputation: 1 akram1027 Good Standing Member
I changed my master cylinder because it was leaking and I did lose some fluid and after everything was done I gravity bled the clutch and filled as it bled but now I have no pressure in my clutch starts fine but it won't engage when i shift gears spedo says I'm going ten in first with clutch let out completely no gas and its still running not sure whats wrong please help:confused:!
Sent from my PC36100 using FF Mobile
akram1027 is offline
Old 03-23-2013, 01:07 PM   #2
blanezx3
blanezx3's Avatar
Fan#: 764
What I Drive: 03 twi-blue zx3
Points 2,456, Level 30
Points: 2,456, Level: 30 Points: 2,456, Level: 30 Points: 2,456, Level: 30
Level Up 4% Completed
FF Reputation: 5 blanezx3 Good Standing Member
Buy-Sell-Trade Rating: (10)
Sounds like you may still have an air pocket that needs to be worked out. Do your wheels spin when the clutch is floored?
performance?
FR stg 2 cams, UR cam gears, FC 65mm TB, ported 2k manifold, 50lb injectors, FC race header, Bosal flex, Borla catback, Zex, Procharger, Xcal2
blanezx3 is online now
Old 03-23-2013, 01:47 PM   #3
akram1027
akram1027's Avatar
Fan#: 101150
No movement at all pumped my clutch for about fifteen minutes to no avail
Old 03-23-2013, 01:56 PM   #4
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2007 mazda 3 I sport, TURBO ZX3
Points 50,882, Level 100
Points: 50,882, Level: 100 Points: 50,882, Level: 100 Points: 50,882, Level: 100
Level Up 0% Completed
Forum Activity 4%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
have someone sit in the car pump the clutch five times then hold it in. then take a 11mm socket with long extention and loosen the nipple on the trans. see flui dleak out and close it, repeat this bout 5 times. I had to do this when I did my engine build. because when I went to first turn the key the car would take off with the turn of the key because of massive air pockets
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 03-23-2013, 02:15 PM   #5
akram1027
akram1027's Avatar
Fan#: 101150
Thanks I will try this and let you guys know
Old 03-23-2013, 02:17 PM   #6
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 4%
make sure to use motorcraft brake fluid to refill
FF MODERATOR
RIFF CREW
Old 03-23-2013, 03:37 PM   #7
akram1027
akram1027's Avatar
Fan#: 101150
I used autozone brand dot 3&4
Is that a no no? Should I drain it?
Old 03-25-2013, 08:26 PM   #8
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,038, Level 74
Points: 13,038, Level: 74 Points: 13,038, Level: 74 Points: 13,038, Level: 74
Level Up 47% Completed
Forum Activity 33%
Activity: 33% Activity: 33% Activity: 33%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (45)
Moved to "General Technical Chat".
zetecDon is offline
Old 03-25-2013, 10:16 PM   #9
jetrinka
jetrinka's Avatar
Fan#: 45622
What I Drive: 88 5-speed XR4TI
FF Reputation: 180 jetrinka Excellent Standing Member jetrinka Excellent Standing Member
Buy-Sell-Trade Rating: (6)
The generic brake fluid will work fine...
The only way i've found to properly bleed the clutches on these cars is a pressure bleeder. I believe FSwerks sells one. I've never had any luck with manual bleeding, gravity bleeding, or even vacuum bleeding.
jetrinka is offline
Old 03-28-2013, 09:31 AM   #10
akram1027
akram1027's Avatar
Fan#: 101150
Thanks jet
