Need help asap! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-22-2013, 09:51 PM   #1
StreetSoldier60
Fan#: 18084
What I Drive: 2001 Yellow ZX3
FF Reputation: 1 StreetSoldier60 Good Standing Member
Need help asap!
ok so doing some work on the focus and I pulled out the wiring harness for the fuel injectors completely now I'm reinstalling everything and have one wire left to go and have no clue where it goes. It is is single wire with one connector its a black with orange stripe wire and like i said has only the one connector what does this plug into? need the help quick guys thanks in advance and i'm sure i'm just being retarded but been a long day and work and just can't get past this hump in reinstall. thanks in advance all!
StreetSoldier60 is offline
Old 03-22-2013, 11:51 PM   #2
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,621, Level 31
Points: 2,621, Level: 31 Points: 2,621, Level: 31 Points: 2,621, Level: 31
Level Up 14% Completed
Looking at diagram:
Black/orange wire goes to the coil on the rear of the cylinder head.
There is also an Org/blk wire fir the data link connector, not sure where it goes except "under left side of dash"
elsolo is offline
Old 03-23-2013, 06:19 AM   #3
StreetSoldier60
Fan#: 18084
ok yea because its just a single wire and i don't see its counter part anywhere it comes off the harness by the knock sensor but has more length to it and its just a single wire and I can't tell where it goes if its the data link cable that means it wouldn't connect to anything correct?
Old 03-23-2013, 01:01 PM   #4
elsolo
elsolo's Avatar
Fan#: 96835
If it is black with and orange stripe, look at the coil for a place to plug the connector in. You won't find anther black/org wire to plug it into.
elsolo is offline
Old 03-23-2013, 01:45 PM   #5
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,868, Level 87
Points: 18,868, Level: 87 Points: 18,868, Level: 87 Points: 18,868, Level: 87
Level Up 4% Completed
Forum Activity 13%
Buy-Sell-Trade Rating: (4)
There is no single wire connector in the F/I harness ... unless you're not talking about the F/I harness I know (which holds the connectors for the CHT, CPS, KS, FRPS, TPS, IAC and fuel injectors).
The wire for the Ignition Coil Resistor, comes out of the harness on the trans.
iminhell is offline
Old 03-23-2013, 07:16 PM   #6
Milton
Fan#: 89715
What I Drive: 2007 Black Focus SES 2.0 L4 4 Door
Points 328, Level 6
Points: 328, Level: 6 Points: 328, Level: 6 Points: 328, Level: 6
Level Up 56% Completed
FF Reputation: 10 Milton Great Standing Member
One of the things I like about digital cameras is it's so cheap to take pictures of every step during removal. It's saved my butt when it's time to reinstall. A cheap digital camera is one of the most useful tools in my tool box.
Milton is offline
Old 03-23-2013, 07:58 PM   #7
StreetSoldier60
Fan#: 18084
ok you have the main plug for the F/I harness, it branches off for the temp sensor in the head, knock sensor, the fuel injectors itself, the crank sensor and then there is just the single wire with a connector on the end of it that has a female end I'll check the back of the coil tonight. maybe its the Crank Sensor? i dunno but that wouldn't be a single wire would it? i bet its for the coil cuz it seems to be long enough to go that way
Old 03-23-2013, 09:26 PM   #8
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
It sounds like it goes to the radio interference capacitor. One side of the capacitor will be grounded, the other side will be a hot. If it blows, it will blow the ECU fuse. If it isn't connected, then you'll have VROOM in your speakers with the spark. It can also affect the operation of the ECU, and that's why it is grounded through the capacitor on that circuit.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 03-24-2013, 12:01 AM   #9
StreetSoldier60
Fan#: 18084
hmm see i have pics on my cell phone i can text people if you PM me your number sorry no way of posting pics right now. but this wire is in my F/I harness and it can't go past the 3rd injector coming FROM the timing belt side so no way for it to reach the back of my coil, that wire is there. I'm totally at a loss i don't see its counter part too hook up to anywhere...
Old 03-24-2013, 09:53 AM   #10
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 13%
Strike that,
It isn't Black/Orange, it's Black/Yellow but the Low Oil Pressure Switch is a single wire.
iminhell is offline
