custom power steering lines? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-21-2013, 11:57 AM   #1
o_so_slo
Drunkinmonkey
o_so_slo's Avatar
Fan#: 55470
What I Drive: 00' Turbo zx3, 12' Optima LX+
Points 19,687, Level 88
Points: 19,687, Level: 88 Points: 19,687, Level: 88 Points: 19,687, Level: 88
Level Up 68% Completed
FF Reputation: 67 o_so_slo Excellent Standing Member
hey guys
i ripped out my old power sterring system rack pump lines everything
im rplacing with a new rack and a new pump but want to make custom lines and have them going to an oil cooler in between my rad and intercooler
has anyone ever made a custom braided lines for the power steering? if so how did you do it?
my main problem is the tube ends that go into the rack are o-right type push in held by a bolt and plate. while the ones to the pump are threaded so that part is easy.
im thinking of cutting the lines going to the rack from the rack just before the rubber hose and braising on a fitting to convert to -AN. or flaring the other end and doing it that way.
Zetec Crew # 260
TURBO
October 2013 & 2014 ROTM
Instagram @o_so_slo
Formerly drunkinmonkey
o_so_slo is offline
Old 03-21-2013, 01:16 PM   #2
Bogey
Bogey's Avatar
Fan#: 104241
What I Drive: 2012, Ingot Silver SE
Points 1,696, Level 23
Points: 1,696, Level: 23 Points: 1,696, Level: 23 Points: 1,696, Level: 23
Level Up 96% Completed
FF Reputation: 1 Bogey Good Standing Member
Go to a plumbing supplier, i think i know what you are saying, and allmost anything is possible with the right tools /supplies they should be able to.show you options or possibly different products to use (connections) ive done hydronics which is the same theory of heat transfer, and the options are endless(sort of) never done what are saying though :-). GL
Bogey is offline
Old 03-21-2013, 03:07 PM   #3
gondorian
gondorian's Avatar
Fan#: 105695
What I Drive: 2002 wgn (Selling) 2004 2.3 wgn 5sp
Points 1,547, Level 22
Points: 1,547, Level: 22 Points: 1,547, Level: 22 Points: 1,547, Level: 22
Level Up 47% Completed
FF Reputation: 7 gondorian Good Standing Member
My car has a metal custom line that was put in by the previous owner, you could try bending one yourself.
gondorian is offline
Old 03-21-2013, 09:58 PM   #4
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,868, Level 87
Points: 18,868, Level: 87 Points: 18,868, Level: 87 Points: 18,868, Level: 87
Level Up 4% Completed
Forum Activity 13%
Buy-Sell-Trade Rating: (4)
http://focus.c-f-m.com/newitemcfmpow...svtheader.aspx
Maybe?
iminhell is offline
Old 03-22-2013, 03:16 PM   #5
S0C0nFused
S0C0nFused's Avatar
Fan#: 39405
What I Drive: 2007 TorD-Red ZX5 SES
Points 12,348, Level 72
Points: 12,348, Level: 72 Points: 12,348, Level: 72 Points: 12,348, Level: 72
Level Up 75% Completed
FF Reputation: 77 S0C0nFused Excellent Standing Member
Ummm! Think this through a bit. Power steering = hydraulics. Means you have a 'high' pressure side and a low pressure side. The 'cooler' would have to be on the low pressure side, where it would do nothing (other than impede flow back to the pump). The 'high' pressure side fittings need to be formed pipe (you found that) OR high pressure hydraulic hose WITH proper end fittings JOINED with a multi-ton 'band' gizmo. Recommend you don't purchase any hose or what not until you find a shop that has the machines to make small diameter hydraulic hoses as they prob won't guarantee the piece unless they use there own stuff. Low pressure side you can just use screw type band clamps.
Luck!
Steeda SRI w/CAI intake. Trubendz SS 2.5" . FR Susp/Struts. Tune by Tom (FocusPower). Rota Grids. SAP rear spoiler. Custom front air dam, rocker panel bits and Rear valance.
Last of the Hatches #28
S0C0nFused is offline
Old 03-23-2013, 01:30 PM   #6
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 13%
Luck!
How does an engine oil cooler work?
How does a transmission oil cooler work?
How does a engine coolant radiator work?
ALL are on the return side.
He knows the cooler is on the low side and never said he wanted to route the high side through it ...
iminhell is offline
Old 03-23-2013, 02:49 PM   #7
S0C0nFused
S0C0nFused's Avatar
Fan#: 39405
Back at ya!
Your thinking 'heat' without considering the source of the heat. Engine/transmission heat is due primarily to thermatic(?)/frictional inefficiency. hydraulic heat is due to pressure. An easily seen example are the fined air lines coming out of an air compressor (to cool the air before it goes into the tank). All the heat gets released by the high pressure side line and ram. That being said, I would question also why the OP is concerned about heat in this regard. Automotive pumps are the smallest of the small. They don't make much heat to begin with.
Old 03-23-2013, 02:53 PM   #8
macdiesel
I used to drive this
macdiesel's Avatar
Fan#: 31579
What I Drive: 2010 red mazdaspeed3 w/tech package
Points 4,234, Level 41
Points: 4,234, Level: 41 Points: 4,234, Level: 41 Points: 4,234, Level: 41
Level Up 43% Completed
Forum Activity 4%
FF Reputation: 22 macdiesel Great Standing Member
Buy-Sell-Trade Rating: (17)
Check out dominanteng.com the guy has made custom ps fittings for the rack so you can add your own lines. This guy makes a lot of custom parts for the focus.
I now drive a Japanese Ford.
macdiesel is offline
Old 03-25-2013, 11:25 AM   #9
o_so_slo
Drunkinmonkey
o_so_slo's Avatar
Fan#: 55470
reason for the lines and the cooler is i had to remove all the lines in fron for my intercooler. that and its also a "show car" so i want to clean up all the ugly black rubber hoses that were rotting away anyway. i will still be having hard lines come off the rack and where those "ugly" lines were i am replacing with braded hose. i work at a performance shop we have the hydraluic crimper and everything for custom lines. we make custom brake lines ,fuel lines, clutch lines daily.
Zetec Crew # 260
TURBO
Instagram @o_so_slo
o_so_slo is offline
Old 03-25-2013, 08:47 PM   #10
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 13%
I have his fitting.
Personally, I'd look for something else. It weeps. Might just need a new o-ring though. That and the wait for parts ...
iminhell is offline
