Excess Front-end Vibration - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-27-2013, 12:22 PM   #11
brumar59
Fan#: 111714
What I Drive: 2006 Black ZX4
FF Reputation: 1 brumar59 Good Standing Member
Thank You sailor
brumar59 is offline
Old 03-27-2013, 12:27 PM   #12
brumar59
Fan#: 111714
Over the weekend, I was ripping around turns and going in circles in an open lot, forward and backward, trying to get my CV joint to click like it did in the past but I got nothing. The other thing I noticed when I was initially hand-checking the tire for wheel bearing play is that as I rotate my tire, the break pads drag on the rotor at a certain point as if the bearing isn't spinning true. I don't think the rotor is warped since it's still pretty thick and in good shape; relatively smooth and all. Could the wobble in my axle I noticed be caused by a wheel bearing if the bearing is somehow messed up or other wise not spinning true?
brumar59 is offline
Old 03-27-2013, 12:29 PM   #13
brumar59
Fan#: 111714
I'm still torn if the vibration is from the axle or the wheel bearing. I have yet to rotate my wheels to see if anything changes and hopefully rules out the tires themselves as causing the vibration, but if it were the tires, I would think they would make the car vibrate at all times (obviously more at higher speeds) but the vibration changes as I turn my wheels to the left or right.
brumar59 is offline
Old 03-27-2013, 12:32 PM   #14
brumar59
Fan#: 111714
I also have a lot of moaning and low-pitch creaking going on when I break, more when I nearly come to a stop. At first I thought it was just the front driver's side, but it's both sides. Again, my vibration is coming from the front passenger side but I have no idea of the break noise and vibrations are related or just happen to be two different issues. The break noises started some time after the vibrations, so I think they are separate issues (maybe I have cheap pads or excessive break dust?!).
brumar59 is offline
Old 03-27-2013, 12:54 PM   #15
bile0026
bile0026's Avatar
Fan#: 97349
What I Drive: 2009 Amber Gold Metalic Focus
Points 401, Level 8
Points: 401, Level: 8 Points: 401, Level: 8 Points: 401, Level: 8
Level Up 2% Completed
FF Reputation: 7 bile0026 Good Standing Member
Again, I would say its probably that axle and it has most likely taken out the bearing by now. I would start there with replacing the axle and bearing.
Groaning brakes can be a number of things including glazed pads (from overheating), improperly broken in brakes, uneven mating surfaces (grooved rotors or pads), and glazed/overheated/heatchecked rotors. Noise in brakes is almost always caused by a vibration. Usually the higher pitched the groan or squeal the faster the vibration. For example if your pads are slipping and grabbing they can groan because of the "vibration" from slipping and grabbing.
2009 Ford Focus Sedan SE--Amber Gold Metallic--FS Cool-flo intake, 17" Black Kazera Rims with Potenza S-04PP, Custom 2.5" Exhaust.
bile0026 is offline
Old 03-27-2013, 11:56 PM   #16
jvert
jvert's Avatar
Fan#: 80613
What I Drive: 2004 Red ZX5 SVT
Points 222, Level 4
Points: 222, Level: 4 Points: 222, Level: 4 Points: 222, Level: 4
Level Up 44% Completed
FF Reputation: 1 jvert Good Standing Member
I had a similar issue with my svt focus. It ended up being my front sway bar bushings. Replaced and now all vibrations are gone. I too changed my sway bar links.
2004 Red ZX5 SVT #132 of 1079
jvert is offline
Old 03-28-2013, 12:12 AM   #17
brumar59
Fan#: 111714
I'm definitely going to check the bushings on my sway bar. Thanks for the idea!
brumar59 is offline
Old 01-19-2015, 09:52 PM   #18
FordFocusPOSedition
Fan#: 215617
What I Drive: 2003 White EX
Points 4, Level 1
Points: 4, Level: 1 Points: 4, Level: 1 Points: 4, Level: 1
Level Up 7% Completed
FF Reputation: 1 FordFocusPOSedition Good Standing Member
I am having the exact same issue with my 03 Focus. I had recently removed my axle and replaced a rotted Inner CV boot. The bearings on the end of the axle seemed just fine. My issue is exactly identical, any luck discovering the solution?
FordFocusPOSedition is offline
