PS pump removal - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-19-2013, 07:58 PM   #1
Bruce Almighty
Fan#: 90526
What I Drive: 2007 charcoal ZXW
Points 47, Level 1
Points: 47, Level: 1 Points: 47, Level: 1 Points: 47, Level: 1
Level Up 94% Completed
FF Reputation: 1 Bruce Almighty Good Standing Member
PS pump removal
I need to know if there is a trick to remove the hard line from the PS pump so I can remove it from the engine bay and get to my t-stat housing (my main job).
To date I removed: belt, PS reservoir, light housing, sensor connector and 2 bolts of the PS pump. I put a small wrench on the nut of the hard line and pull has hard has I can, but it wont move.
Thanks for the help, I need to get this done so my wife can have her car back.
Bruce Almighty is offline
Old 03-19-2013, 09:21 PM   #2
VillageT
Fan#: 97061
What I Drive: 2005 Silver ZX3
Points 325, Level 6
Points: 325, Level: 6 Points: 325, Level: 6 Points: 325, Level: 6
Level Up 50% Completed
FF Reputation: 1 VillageT Good Standing Member
Here is manual on 2.3 dtec-should be the same
Removal and Installation
NOTE: The thermostat and thermostat housing are serviced as an assembly.
Drain the cooling system. For additional information, refer to Cooling System Draining, Filling and Bleeding in this section.
With the vehicle in NEUTRAL, position it on a hoist. For additional information, refer to Section 100-02 .
Remove the accessory drive belt. For additional information, refer to Section 303-05 .
NOTE: LH shown, RH similar
Remove the two power steering hose bracket retaining nuts and position the hose and brackets aside.
Remove the cooling fan motor and shroud. For additional information, refer to Cooling Fan Motor and Shroud—2.3L in this section.
Remove the four A/C compressor bolts and position the compressor aside.
Remove the hoses to the thermostat housing.
Release the spring-style clamps.
Twist and remove the coolant hoses from the thermostat housing.
Remove the bolts, the thermostat housing and the thermostat as an assembly.
NOTE: Lubricate the thermostat housing O-ring with clean engine coolant.
To install, reverse the removal procedure.
Fill and bleed the cooling system. For additional information, refer to Cooling System Draining, Filling and Bleeding in this section.
VillageT is offline
Old 03-20-2013, 12:28 AM   #3
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,595, Level 30
Points: 2,595, Level: 30 Points: 2,595, Level: 30 Points: 2,595, Level: 30
Level Up 97% Completed
Level up: 97% Level up: 97% Level up: 97%
That's a neat writeup for thermostat.....
Back to the power steering pump:
There is no trick to the hardline, other than make enough room for yourself and use a flare nut wrench. (6-point box end wrench with slot cut out).
elsolo is online now
Old 03-20-2013, 06:28 AM   #4
Bruce Almighty
Fan#: 90526
Points 47, Level 1
I can position a 6'' wescot wrench on it, but I'm afraid I'll break something when pulling. Guess I'll have to try harder and maybe find me a flare nut wrench (18mm)
I will use that t-stat writeup, but my engine is the 2.0, should be similar.
Thanks
Old 03-20-2013, 07:30 AM   #5
dustin102
Fan#: 74880
What I Drive: 2007, silver, zx5
Points 587, Level 11
Points: 587, Level: 11 Points: 587, Level: 11 Points: 587, Level: 11
Level Up 74% Completed
FF Reputation: 1 dustin102 Good Standing Member
Just an FYI... I just swapped out my thermostat last weekend. Remove the belt. The there a 4 bolts holding that p.s. Pump On. The one behind the line will be the last bolt to come off. I was able to get an open end wrench on that bolt and thread it off. With out removing the line. The oil reservoir will just pop off the pump when the top to bolts are off.... Just take it off and drain it to get it out of the way. This is a PITA I spent maybe an hour and half on that bolt getting it out then back in. but it is possible. :eek:
Sent from my Galaxy Nexus using FF Mobile
dustin102 is offline
Old 03-20-2013, 09:10 AM   #6
Bruce Almighty
Fan#: 90526
Points 47, Level 1
Thanks for the info, I was going to try that... but knowing it worked for you I will do it that way
