Help: engine rebuild - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-18-2013, 12:28 AM   #1
InfectedBulat
Fan#: 111618
What I Drive: 2005 Ford Focus ZX4 ST
FF Reputation: 1 InfectedBulat Good Standing Member
How can I install racing camshafts in my focus? do I need to hire a professional tuner?
I would also like to know what other engine upgrades I could do to my 2.3l duratec. I want to build this thing up from the bottom up.
InfectedBulat is offline
Old 03-18-2013, 12:59 AM   #2
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2012 Mazdaspeed 3, TURBO ZX3
Points 51,036, Level 100
Points: 51,036, Level: 100 Points: 51,036, Level: 100 Points: 51,036, Level: 100
Level Up 0% Completed
Forum Activity 2%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
what exactly are you trying to do here? you can install camshafts very easily to do since there DOHC. but the problem there is if you want to utilize them to their full potential you can get some valve springs as well. but you have to check the clearance of the lobes to match the specs in wich they usually don't. wich is why a machine shop can do the install and make your buckets match the specs. if you want to build the bottom end invest in some coswort rods, for the duratec not sure if je makes pistons for them. now a shop must take these for balancing and if you go with an overbore then the block needs to be bored and honed. also with the engine build are you going for boost? if so you have to check the piston ring gap as well. theres quite a bit to do with a bottom end rebuild with aftermarket parts. such also as checking clearances with plastigauge
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 03-18-2013, 01:08 AM   #3
InfectedBulat
Fan#: 111618
I'm looking for boosting it, just not yet.
I just want to have like a check list to what I need to buy once I buy it all I will find a way to install them.
Old 03-18-2013, 02:47 AM   #4
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,570, Level 100
Points: 52,570, Level: 100 Points: 52,570, Level: 100 Points: 52,570, Level: 100
Forum Activity 57%
Activity: 57% Activity: 57% Activity: 57%
Buy-Sell-Trade Rating: (28)
If your going to be boosting it you dont want racing cams
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 03-18-2013, 10:32 PM   #5
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 2%
right and remember to look for pistons of lower compression. id go with an overbore like I did that way a machine shop will bore your cylinder walls wich in turn basically makes your block like new
FF MODERATOR
RIFF CREW
