06 Focus no start problem - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-17-2013, 03:32 PM   #1
rob73rushing
Fan#: 111207
What I Drive: 2006 Focus ZX4, 2007 Focus Wagon
Points 74, Level 1
Points: 74, Level: 1 Points: 74, Level: 1 Points: 74, Level: 1
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 1 rob73rushing Good Standing Member
My 2006 Focus ZX4 will not start.I have tried 3 different keys. Keys turn in ignition, but in start position, nothing happens. I have checked the starter, all fuses, starter and ignition relays, transmission gear indicator, battery and I have replaced the ingition switch. The starter will engage if I bypass the starter relay, but still no start. PATS light does not flash when trying to start. Code scanner cannot connect to PCM.
Any suggestions?
Robert on MS gulf coast
Sent from my GT-N8013 using FF Mobile
rob73rushing is online now
Old 03-17-2013, 03:44 PM   #2
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
ooooooo what does your odometer look like? Does it look like this [-------] with the key in the On position?
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 03-17-2013, 03:49 PM   #3
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 10%
Also, have you checked all the fuses? There is a fuse for the ECU in the fuse box under the hood of the car. The owner's manual has descriptions and location information for the fuses, so look there to guide yourself. I think it is a 10 amp fuse. If it is blown, before you replace it, you need to check something under the hood. On the front of the engine there is a small black box with one wire going to it, and one wire coming out and to a grounding location nearby. If the wire going into the box is frayed, loose, or disconnected and grounding out nearby it will blow that fuse. Then the car won't start. If this is the case, then tape the incoming wire up so it won't short out, replace the ECU fuse with a same size fuse, and then purchase a new Radio Interference Capacitor at your local Ford dealer.
Be eclectic.
Old 03-17-2013, 04:40 PM   #4
rob73rushing
Fan#: 111207
Points 74, Level 1
Rechecked underhood fuses, all still good. Odometer reads "-----"
Old 03-17-2013, 09:12 PM   #5
TiIngot
Fan#: 110130
What I Drive: 1996 Corvette LT4 Convertible
Points 181, Level 3
Points: 181, Level: 3 Points: 181, Level: 3 Points: 181, Level: 3
Level Up 62% Completed
FF Reputation: 3 TiIngot Good Standing Member
I don't know if the 06 is different from the 08. My daughters trouble was in the steering column. To diagnose it remove the starter switch from the steering column but leave the wires plugged into it. Put the key in the ignition switch and turn it to the "run" position.
Use a flat head screw driver and put it into the slot of the starter switch and turn it all the way as if you were using the key. If the car starts your trouble is in the steering column betweer the starter switch and the key ignition switch.
TiIngot is offline
Old 03-17-2013, 09:34 PM   #6
rob73rushing
Fan#: 111207
Points 74, Level 1
Tried screwdriver in electrical part of ignition switch. Still no start.
Robert
Old 03-17-2013, 10:15 PM   #7
FocusedSlayer
has a screw loose
FocusedSlayer's Avatar
Fan#: 59042
What I Drive: 2007 CD Silver Sedan SE w/Sap
Points 7,878, Level 59
Points: 7,878, Level: 59 Points: 7,878, Level: 59 Points: 7,878, Level: 59
Level Up 64% Completed
Forum Activity 14%
FF Reputation: 34 FocusedSlayer Great Standing Member
Buy-Sell-Trade Rating: (4)
When my odometer showed what yours is showing my Ecu had been erased. I had to have mine towed to the dealership and the Ecu reflashed. But mine was from a tuning issue. When I get home I can look in my Haynes manual and maybe give you an idea of what to look for.
Posted via FF Mobile
FocusedSlayer is offline
Old 03-18-2013, 11:01 AM   #8
FocusedSlayer
has a screw loose
Fan#: 59042
Forum Activity 14%
Sorry for the late response , I've been looking all over the Haynes manual and can not find anything related to your problem . The only thing that I can think of is that it has something to do with your PATS . Do you have an extra key just to try out and see if you get the same results?
Team Duratec #01,Sedan Revolution#4, Elder FocusedSlayer, Gump Crew 21
February 2012 Sedan of The Month
Old 03-18-2013, 04:51 PM   #9
rob73rushing
Fan#: 111207
Points 74, Level 1
PATS light does not flash when trying to start. I have tried three different keys.
I think tomorrow I'll remove PCM and see if it looks bad
Old 03-19-2013, 11:44 PM   #10
rob73rushing
Fan#: 111207
Points 74, Level 1
Removed PCM but couldn't tell if it is bad. Ordered a replacement with keys. Will update after installation.
