#1 | ||||
Motor Blower Mystery
OK, so here's the situation:
I started experience noise from the blower motor which progressed to it not blowing much air, even in the #4 position. Soon thereafter, I started getting nothing at all(no noise, nothing) when I would turn the switch on. After replacing the blower motor, still nothing. I took it out and had it tested and it was fine. I also tested the wires and I got power..The connector to the blower motore registers .31 on the multimeter. I checked the fuses and they're fine. Then again, they would be if I have power at the wires. I changed the resistor and the fan blower switch and still nothing. I'm not at a loss for what the issue is...Any suggestions before I take it to the dealer????? |
Remove Advertisements |
Fan#: 1
#2 | ||||
"Elder"
Memory's not what it COULD be, but I THINK there was a fairly recent thread with a similar issue & the OP found there was LARGE fuse in the under hood fuse box he hadn't checked...
One quick check that comes to mind is checking for power with a test light instead of the multimeter. Meter can show power when there isn't enough current avail. to light a test light, so you can be "fooled" by that check sometimes.... Luck! |
#3 | ||||
When I first started having the noises with old motor, I could hear power and then after a few days, it stopped, altogether, so I know something blew. Could it be anything other than the wiring harness that connects directly to the motor and resistor? |
#4 | ||||
Captain TMI
Is the fan stuck?
Be eclectic. ---The Complete How-To Archive-- Moderating everything now, let me know if I can help.
#5 | ||||
#6 | ||||
DTC P0606
You looked specifically at fuse 64, right? In the underhood BJB but kind of away from the other fuse groups by itself (bettween the relays).
#7 | ||||
#8 | ||||
"Elder"
Shucks, hoped for an "easy" one after it happened to another member here... (under hood fuse)
How about that test light check? A "poor" connection somewhere would show power to the motor with a meter, while not carrying enough current to run it.... Proverbial "Ask me how I know" on that one... (grin) |
#9 | ||||
#10 | ||||
"Elder"
'Fraid not, without knowing where the leads are connected to & what setting on the meter (volts, ohms, range etc.)
| Thread Tools | |
| Display Modes | |
