How to diagnose cruise control problems. - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-27-2014, 11:19 AM   #11
09 focus fan
Fan#: 136945
What I Drive: 2009, black, se
FF Reputation: 1 09 focus fan Good Standing Member
Got cruise problems
Thank you for the detailed info. I tried it on my 2009 Focus SE and didn't get any results. No lights blinking or anything. My cruise control doesn't work at all. Any suggestions?
09 focus fan is offline
Old 02-01-2014, 02:52 PM   #12
09 focus fan
Fan#: 136945
Originally Posted by 6SPD_soul View Post
I just had some issues with my CC and have sorted that out, but I found there is a really slick self diagnostic procedure for the cruise control. You don't need a diagnostic scanner to do this either, just the car. From what you describe I think the cruise control servo (motor with a spool of cable that controls the throttle body for CC) is bad, but this test will tell you for sure where the problem lies. This self diagnostic test will work on all Foci from 00-05, in addition to many other Ford models in those years.
The test is basically this: you're going to be turning the ignition key on and off repeatedly and then hitting the cruise control buttons quickly in a specific sequence, and then the cruise control light will blink repeatedly, and the number of blinks tells you where the fault is. It's easy to do once you get it sorted in your head and you won't mess anything up if you don't get it right the first time.
If it's a manual, don't depress the clutch. If it's an automatic leave it in park. First, turn the ignition to the accessory/run position but don't start it. Press and hold the CC off switch and then repeatedly turn the ignition from run to off and back to run again, you should do this 3 or 4 times. End this sequence with the ignition in the run position and then let go of the off switch, and you should see your CC light blink once, which means it's ready to run the self diagnostic. If it flashes 5 times at this point then it's a faulty speed control module, which is that servo I mentioned above. Quickly after the light blinks (like a second after), you then need to hit the other cruise control buttons in this order, and you will need to hit them fairly quickly for the test to proceed:
1. On
2. Resume
3. Coast
4. Set/accel
The CC light should blink once after each button you hit. Kind of take your time hitting the buttons and it's easier to keep track of the flashes, which is important at the end because you need to count the number of flashes that come after you hit "set". There won't be an immediate flash after you hit "set", there will be a slight delay, and then will come another short series of flashes. This next part is all verbatim (except for the parenthesis) from the Ford guide I'm translating here.
0 Flashes (no flash after last button is pushed): suspect circuitry or speed control steering wheel switches.
1 Flash: Static test passed (cruise control should work)
2 Flashes: BPP (brake pedal position) switch is damaged, circuit is damaged, or the brake or clutch pedal was applied during test.
3 Flashes: Brake deactivation switch is open or circuit is damaged.
4 Flashes: Indicates the speed signal circuit is open or damaged (wheel speed sensors, ETC)
5 Flashes: Suspect circuitry or module.
So I guess try to run the test. It's pretty quick and easy once your thumbs get the button sequence down. Then you should at least have a better idea where the problem is coming from. Post back here with results, I'm curious where the problem is for you. Mine was the brake deactivation switch which I'm putting in soon.
Hi!
Tried your diagnostic on my 09 Focus and nothing. No light came on or anything else. The cruise doesn't come on at all. Checked for a fuse or relay and didn't see the cruise control listed. Could it be under another fuse?
Anything to help would be great.
Old 04-13-2014, 01:20 PM   #13
pruietjr
Fan#: 89985
What I Drive: 2007, red, SE
Points 22, Level 1
Points: 22, Level: 1 Points: 22, Level: 1 Points: 22, Level: 1
Level Up 43% Completed
FF Reputation: 1 pruietjr Good Standing Member
Tried Cruise Control Test ... Inclonclusive Results
Thanks much for this helpful info. I tried the test and it seemed to work for my '02 SE Wagon. The cruise light flashed once after I pressed each button (including the set/accel button). Then I heard some part of the CC system activated under the hood. The CC light did not flash again.
The problem I am having is that the CC light does not "light up" when I press the "On" button. I also noticed that the rear upper/center brake light does not work (all other lights work). I thought I read somewhere that these might be related ... but I can't find the posting.
Any help would be greatly appreciated.
pruietjr is offline
Old 04-13-2014, 02:12 PM   #14
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,078, Level 27
Points: 2,078, Level: 27 Points: 2,078, Level: 27 Points: 2,078, Level: 27
Level Up 52% Completed
Fix the center rear brake light first. Cruise will not work without functioning rear brake lights.
BC_ZX3 is offline
Old 04-13-2014, 03:38 PM   #15
pruietjr
Fan#: 89985
Points 22, Level 1
Thanks much!!! I just fixed a broken wire in the harness to the upper/middle brake light and wallah ... the light works and the Cruise Control works!
pruietjr is offline
Old 04-27-2014, 10:01 AM   #16
RussellSVT
Fan#: 152354
What I Drive: 2004 Focus SVT
Points 342, Level 6
Points: 342, Level: 6 Points: 342, Level: 6 Points: 342, Level: 6
Level Up 84% Completed
Forum Activity 2%
FF Reputation: 1 RussellSVT Good Standing Member
Does anyone know why this diagnostic wouldn't work? I've done it as per the instructions several times with no luck at all; CC light never came on. I have an 04 SVT and want my CC for long drives...help! lol
RussellSVT is offline
Old 05-17-2014, 08:33 PM   #17
eotsis1
Fan#: 163162
What I Drive: 2009, ice blue, sel
Points 50, Level 1
Points: 50, Level: 1 Points: 50, Level: 1 Points: 50, Level: 1
Level Up 50% Completed
FF Reputation: 1 eotsis1 Good Standing Member
Originally Posted by driver36@mts.net View Post
thanks for that but ford just diagnosed the throttle body as the problem any one else have a throttle body problem
About three years ago ford dealer replaced throttlebody under warranty.
Symtoms were. at hwy speed w/ cc on, car would begin to surge on/off til at some point the cc quit. While I was still rolling, I could stop and restart the car then resume using cc again. The wrench light would also come on but reset after the restart. Dealer got it to act up and prompted the replacement TB.
eotsis1 is offline
Old 05-29-2014, 08:19 PM   #18
Dreadhead420
Fan#: 166194
What I Drive: 2002 Silver ZX5
Points 84, Level 1
Points: 84, Level: 1 Points: 84, Level: 1 Points: 84, Level: 1
Level Up 68% Completed
FF Reputation: 1 Dreadhead420 Good Standing Member
Could any one tell me the location of the brake deactivation switch on a 2002 focus ZX5 .
Dreadhead420 is offline
Old 06-16-2014, 09:39 AM   #19
X-Rated
X-Rated's Avatar
Fan#: 55237
What I Drive: 03 Tan ZTW
Points 2,707, Level 31
Points: 2,707, Level: 31 Points: 2,707, Level: 31 Points: 2,707, Level: 31
Level Up 72% Completed
Forum Activity 3%
FF Reputation: 4 X-Rated Good Standing Member
Buy-Sell-Trade Rating: (12)
This was my problem as well. Rewired the 3rd brake light and works fine.
This would be the 1st thing I would check before anything else.
2003 ZTW - 2.0L 16v Zetec: 9mm Racing plug wires, long style CAI, shorty header w/down pipe, glasspack for a resonator & raptor muffler
Drive it like you stole it!!
X-Rated is offline
Old 11-16-2014, 03:41 PM   #20
audjobman
Fan#: 202881
Points 3, Level 1
Points: 3, Level: 1 Points: 3, Level: 1 Points: 3, Level: 1
Level Up 5% Completed
FF Reputation: 1 audjobman Good Standing Member
1. On
2. Resume
3. Coast
4. Set/accel
Thanks for the post!
I tried the sequence and get no flashing. That said, I recently purchased the car, used, and the CC was working fine. Now, when I activate it, the CC dash indicator light comes on but the speed is not regulated. If I let the gas pedal go, the speed decreases until the CC indicator light goes out.
Any ideas?
audjobman is offline
