2013 Focus SE - Check Engine Light - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Technical Chat
Old 03-17-2013, 02:25 AM   #1
blainhershberger
Fan#: 111562
What I Drive: 2013 Race Red SE
FF Reputation: 1 blainhershberger Good Standing Member
Hi,
I had the K&N 69 Series Typhoon Intake System installed on my 2013 Ford Focus roughly a week ago and experienced no issues until last night after dinner when I returned to my car with that delightful Check Engine Light on (700 miles on the car)...Is it possible that improper installation of the intake has caused this? I have not noticed any abnormal driving experiences but I have noticed that my fuel mileage has not been the greatest. Is it possible that there is a leak (pulled code at Autozone. Error code P0456 indicates 4 different issues: loose fuel cap (car has no cap); EVAP canister broke, hose cracked, or not connected; Purge or vent solenoid defective; and the last and seeming to be most likely cause, Vacuum leak at engine. I do work at a Ford dealership but I was unable to get a mechanic to take a look at it today. I am extremely worried about it doing serious damage to my engine. Could this potentially cause a long term issue and also void the warranty to whatever it may damage?
Thanks
blainhershberger is offline
Old 03-17-2013, 05:52 AM   #2
wickedgreyzx3
Fan#: 34204
What I Drive: 2006 ZX3 Liquid Grey
FF Reputation: 17 wickedgreyzx3 Great Standing Member
Then put the stock intake in and see what happens
Modifying cars is retarded. Buy a bike instead.
wickedgreyzx3 is offline
Old 03-17-2013, 03:53 PM   #3
Bogey
Bogey's Avatar
Fan#: 104241
What I Drive: 2012, Ingot Silver SE
FF Reputation: 1 Bogey Good Standing Member
This is the first ive heard of a problem with the 69 series on this car, you sure you didnt pulled something while installing... Its not totally it might cause something, but the aftermarket engineers test this to make sure before hand.
Bogey is offline
Old 03-17-2013, 05:00 PM   #4
sailor
"Elder"
sailor's Avatar
Fan#: 57268
FF Reputation: 67 sailor Excellent Standing Member
With older models, results like this have typically been from installation issues. So letting the mechanics who installed it take a look would likely help!
Only other issues prev. seen were with cheap units that had the wrong size tube for the MAF (NOT k&N), MAF installed backwards, MAF dirty from installation or over oiled filter (not likely from pre-oiled unit).
Occasionally something isn't tightened up accidentally, or a hose comes off by accident - those are things you might see yourself with a quick look....
Luck!
P.S. - Nearby items may have been disturbed during installation, so look around the WHOLE area for possible issues. Intake tract connections in particular given the "code" you got!
sailor is offline
Old 03-17-2013, 09:47 PM   #5
ST8ofmind
Fan#: 106573
What I Drive: 2013 Performance Blue Focus ST
FF Reputation: 1 ST8ofmind Good Standing Member
your car is still new and it is possible you have a small vacuum leak and not notice it given if you did no install it correctly. Recheck all connections, clear the code and see if it comes back. Have one of the techs do an EVAP test using the IDS and see if they can isolate an issue with the EVAP system. I have encountered several new Foci (<5k miles) with EVAP concerns, I have replaced many Canister Purge Valves as they tend to stick slightly open and get stuck which causes a leak.
Ford, Lincoln & Mercury Certified Automotive Technician
'13 Focus ST
'12 Subaru Forester
'91 Mercedes 560SEL
ST8ofmind is offline
Old 03-18-2013, 02:11 PM   #6
FordService
Official Ford Rep
FordService's Avatar
Fan#: 79824
What I Drive: Ford Focus
Originally Posted by blainhershberger View Post
Hi,
Thanks
Hi blainhershberger,
Installing or using any aftermarket product will not necessarily void your warranty. However, if the product fails or causes a Ford part to fail, the cost of the repair and any related damage(s) are not covered by your warranty. Let me know what your dealer says; if you need my assistance, just let me know.
Crystal
FORD SERVICE
p: 800.392.FORD
FordService is offline
Old 03-19-2013, 10:38 AM   #7
blainhershberger
Fan#: 111562
Crystal
They cleared the code, didn't really look into it. Explained that it is most likely my capless fuel tank and that it sometimes takes some time to seal...light hasn't came back on yet, let's pray it doesn't!
Thanks!
Old 03-19-2013, 02:38 PM   #8
FordService
Official Ford Rep
Fan#: 79824
Thanks!
Thanks for updating us. If you need any assistance in the future, you know where to find me!
Crystal
FORD SERVICE
p: 800.392.FORD
