CV re-install after SPI engine drop and swap - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-15-2013, 12:09 AM   #31
trooper T/diesel
Fan#: 111147
What I Drive: fixing SOHC focus, DDer 86 D troper
Points 308, Level 6
Points: 308, Level: 6 Points: 308, Level: 6 Points: 308, Level: 6
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
FF Reputation: 1 trooper T/diesel Good Standing Member
OK the fun goes on,.......
got the shims put them in and....oh what a big suprize...valve still open "a LOT"
need more shims..or.????
do i need to put the head on the block for the HYD lifters to release or shrink after it cranks over with oil presser.?
also since ive got the pistons out i ordered rings from rockauto.com
they sent me rings for one piston.. ARG
im going to be very happy when this thing is GONE, LONG GONE
trooper T/diesel is offline
Old 04-15-2013, 09:13 PM   #32
trooper T/diesel
Fan#: 111147
Points 308, Level 6
got a hold of them..
they said take the HYD a-juster out and put in a vice, to remove oil presser.
i did this and the valve is now closed.
ill see about some photos.
they said im one of 3 people that this happened to.
after that they figured it out and started fixing the issue before shipping the head...
talk about drawing the the short straw.....
Old 04-16-2013, 02:53 AM   #33
amc49
Fan#: 96610
Points 3,381, Level 36
Points: 3,381, Level: 36 Points: 3,381, Level: 36 Points: 3,381, Level: 36
Level Up 21% Completed
Forum Activity 55%
I'd bet a million bucks there is nothing off with that rocker position at all, more likely the new valve seat put in too low, probably not a new head. Rocker stands are generally machined all at once. VERY odd for one to be off like that.
You can collapse a hydraulic lifter with a simple c-clamp. You ALWAYS collapse lifters going into an unknown quantity new rebuild, good way to bend some valves.
amc49 is offline
Old 05-15-2013, 10:17 PM   #34
trooper T/diesel
Fan#: 111147
Points 308, Level 6
well got the pan/head back on, compression tested it was all 150/180, started up.
seems to stumble at low rpms, better as revs go up.
my INNOVA 3140 scan tool "not the dash trick" shows no codes.
timing? senser?
to much difference in comps piston to piston making it shake a little?
think ill try and run it 15 min or so, see if it puts a code out after it heats up.
Old 05-16-2013, 01:07 AM   #35
trooper T/diesel
Fan#: 111147
Points 308, Level 6
pulled the timing cover found it off 0.25"
put it back one tooth and that makes it 0.25" the other way.
one way it runs smoother but the rpms are jumping up and down a few 100
the other way it stays fairly steady but its all most like its missing, revs better at higher rpms.
i thought timing marks are meant to line up????
any ideas? other then the Z one....
