No Start - No Codes - diagnosis help request - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-15-2013, 06:07 PM   #21
FocusRus
FocusRus's Avatar
Fan#: 109798
What I Drive: 2004 Silver Sedan SE
Points 356, Level 7
Points: 356, Level: 7 Points: 356, Level: 7 Points: 356, Level: 7
Level Up 12% Completed
FF Reputation: 3 FocusRus Good Standing Member
Buy-Sell-Trade Rating: (9)
Snowing...you can have that s....
SR#269 'I know where the 'zetec' kicks in....'
FocusRus is offline
Old 03-15-2013, 08:10 PM   #22
WrinkledCheese
Fan#: 94287
What I Drive: 2000 Silver ZTS
FF Reputation: 5 WrinkledCheese Good Standing Member
It's still snowing but the compression test complete. 175-180 PSI on all 4 cylinders performed twice on all cylinders. The compression tester made it easy. It has a pressure release button on the side of the dial.
Had to use a pair of needle nose pliers to grip the top of the adapter connector which let me back off the hose and let me carefully use the needle nose pliers to take out the adapter.
Can anyone tell me for sure that I'm supposed to get < 1v on the pigtail going to the ignition coil? I cut the pigtail out and spliced it back in after doing the test on the pins disconnected from the ignition coil. This gave me full access to check the voltage of the wires going to the ignition control module. I got a reading of 10v once, but I turned over the engine at least 100 times watching the multimeter and it was consistently the same range of voltages. It mostly ranged form 0.2v to 0.5v with "spikes" here and there ranging to 0.9
This car is kicking my ass.
WrinkledCheese is offline
Old 03-15-2013, 08:35 PM   #23
WrinkledCheese
Fan#: 94287
I may have mis-diagnosed the voltages to the coil. I was assuming the green - centre wire - is ground. Apparently this is the 12 volt wire I'm looking for and the other two are signaling wires.
I'm going to test it again. Each wire against the battery negative post.
http://easyautodiagnostics.com/ford_...cus_coil_1.php
Old 03-15-2013, 08:35 PM   #24
WrinkledCheese
Fan#: 94287
This is why you should be able to delete posts. Somehow I double posted.
Old 03-15-2013, 09:45 PM   #25
WrinkledCheese
Fan#: 94287
Yup, I was testing it wrong, that's what I get for assuming the green wire is ground.
The centre wire is getting 12v until I turn the key, then it's getting < 1v. Anyway, it sounded like one cylinder fired. I'm going to get someone to crank the engine over and smell the tail pipe. Looking for a gas smell. The rail is getting gas and I replaced the fuel relay twice with no results.
Old 03-15-2013, 09:48 PM   #26
WrinkledCheese
Fan#: 94287
So I tested the spark plugs the old fashioned way. Hooked up a wire to the negative battery terminal or other ground point - Cylinder 4 was grounded on the hood - and all 4 sparks were nice strong sparks. All 4 cylinders are smelling like gas, but the cam shaft cover creates a cavity the fumes form one cylinder can make another cylinder smell like gas...
...heat gun aimed down the cylinder to dry up any fluids. I did have fluids that seemed like they were running along the spark plug threads when I started diagnosing this issue. Only concern is the effect of the heat gun on the oil...should be fine.
Old 03-15-2013, 09:49 PM   #27
WrinkledCheese
Fan#: 94287
These forums are double posting everything I type. I get a please try again in 15 seconds for every post...if I wait and re-post you get the double post above.
[edit] for the record. I've tried almost everything holding the gas pedal down, which cuts off the gas supply. IIRC.
..except when trying to start the engine, obviously.
Old 03-15-2013, 11:35 PM   #28
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,078, Level 27
Points: 2,078, Level: 27 Points: 2,078, Level: 27 Points: 2,078, Level: 27
Level Up 52% Completed
This would be a problem. Investigate further.
BC_ZX3 is offline
Old 03-16-2013, 12:03 AM   #29
FocusRus
FocusRus's Avatar
Fan#: 109798
Points 356, Level 7
WC, make sure the ignition coil capacitor is connected.......it's on side the coil pack.
FocusRus is offline
Old 03-16-2013, 12:17 PM   #30
WrinkledCheese
Fan#: 94287
I tested the spark another way. I connected a wire to the battery negative post, hooked the battery up to the ignition wire outisde of the block. Hung it from the hood and watched it while I turned over the engine. Indeed there is spark.
I am checking fuel again after I dry out the cylinders. I am headed outside after I post this to check for the ignition coil capacitor.
I tried googling it but couldn't find a picture to make sure I was looking at the same thing and it's hard to trace the wires with all the plastic coverings.
