No Start - No Codes - diagnosis help request - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-14-2013, 09:43 PM   #1
WrinkledCheese
Fan#: 94287
What I Drive: 2000 Silver ZTS
FF Reputation: 5 WrinkledCheese Good Standing Member
Hello all. I have a no-start, no codes issue.
No-brainer right? I though so too. I've spent 4 hours trying to diagnose the issue and here is what I have come up with. 6 hours if you include time talking to people etc.
Any thoughts, suggestions, etc are welcome.
What I've Done. What I think. A little history.
It's a spark issue...I think.
I noticed a week ago that all of a sudden I lost performance. Literally the moment I went to the gas station and start the car back up it sounded funny and I had no performance.
Today on my way to work...it's always on the way to work...it wouldn't start.
First thing I did is check for the fuel pump sound, then for fuel. It's getting sufficient fuel to the rail. Let's assume the injectors are dispensing fuel as I don't have the skill set or tools to test beyond the rail getting fuel. I'm sure it's easy with the right tools.
I moved onto the spark. I don't have a lot of testing equipment for this so I relied on the multimeter and spare parts.
6 or 7 months ago, I got a sweet deal on the motorcraft coil pack, autolite wires and autolite iridium plugs and I was already ordering something and it came to ~$60. So I replaced working parts. Which is great because I had parts to test with.
First I checked the spark plugs. Cylinders 1 and 2 had what looked like battery corrosion all around them. There was also a little water around the top of the port where the plug goes in on both cylinders. I used a towel to clean up the water and then proceeded to take out the plugs. The plugs had wet white corrosion like substance along the threads half way down to the cylinder on Cyl. 1 and all the way down on Cyl. 2. I bought a new plumbers wire brush to clean up the threads, figuring the plugs weren't firing used shop towels to get as much as possible out. After two tries I was able to take the plugs out without any residue on them.
Next I moved onto the ignition coil pack. I just swapped it out for the old one that worked fine when I replaced it. It seemed to behave the same. So I tried replacing all components between the cylinder and the ignition coil pack - wires, plugs, coil - and it made no difference.
So I busted out the multimeter.
Using the lowest ohm setting - 200 ohm - I traced the pigtail back to the fuse/relay box in the engine bay. One wire went to one relay. One wire went to the relay next to it and the other wire I checked against the negative battery terminal. I had to bump my meter up to the 2k ohm setting since I had 250 ohms on one wire going to a relay and I had 600 ohm on one wire going to the other relay. The labels for the relays are 'gas pump' and 'check engine light'. I don't have any docs to find what these are but I assume they are spark and fuel delivery relays.
Next I checked voltages. I tried two methods of getting voltages. First I shaved part of the wire and poked my multimeter leads up to the exposed wire. The second method is I cut the pigtail off and spliced another one back in. Making it easy to hook my multimeter up to the wires. I didn't test voltages at the ports on the pigtail but I checked resistance so if there was any corrosion causing a voltage drop, I would see resistance.
I had the negative hooked up to the centre ground wire and I checked each of the other wires consecutively. I got a variable reading < 1vdc. Usually less than 0.5vdc. On one occasion, when the engine made an "I'm going to start....gotcah" sound - I assume one cylinder fired - I seemed to get 10vdc then it dropped down to 8 then 0.
I replaced the relays from another focus and that didn't change anything. I don't know where the wires go form there and I don't know what else to test.
Can anyone help me diagnose this issue?
2000 Ford Focus ZTS Zetec. 170,000 kms/100,000 miles. No check engine light, no codes.
WrinkledCheese is offline
Old 03-14-2013, 09:56 PM   #2
WrinkledCheese
Fan#: 94287
Googling around makes me think I want to check the Crankshaft Position Sensor. Does anyone know the specs for the volts or ohms for testing the sensor. Also, where is the sensor located?
Old 03-14-2013, 10:17 PM   #3
Bryan23ferra
Bryan23ferra's Avatar
Fan#: 98170
What I Drive: 2011 Blueflame SES
Points 654, Level 13
Points: 654, Level: 13 Points: 654, Level: 13 Points: 654, Level: 13
Level Up 8% Completed
FF Reputation: 1 Bryan23ferra Good Standing Member
The crank sensor works with the cam sensor, both would set codes. Even so, if I was the cps, you could possibly hear it fire at the wrong time. The crank sensor will be somewhere next to the harmonic balancer. Check your oil, what's it smell like? Next check coolant, to me, sounds like a head gasket. Get a compression tester and test all cylinders. Compare specs, they should be within a 15psi range of each other. You can rent one at your parts store. Also, what's your coolant smell like, does it look normal?
SES #054
Infra Red 2007 SES sedan. SOLD.
Blueflame Metalic 2011 SES. Sct Tuned, SLAMMED on DGR coils.
I have eibach sportlines for the 08-11 foci. Dont really need them anymore. $175
Bryan23ferra is offline
Old 03-14-2013, 10:18 PM   #4
Bryan23ferra
Fan#: 98170
Problems like this are when I wish I was there to help!
SES #054
Old 03-14-2013, 10:27 PM   #5
Bryan23ferra
Fan#: 98170
Also when it was running, was there a change in exhaust fumes? Oh and while at the coolant, check the level. Another thing, with the plug out, stick something down the cyl GENTLY!!! and see what kind of residue you get on the end.
SES #054
Old 03-14-2013, 10:30 PM   #6
Covmister
Covmister's Avatar
Fan#: 89659
What I Drive: 2001 white zx3
FF Reputation: 3 Covmister Good Standing Member
it could be possible that you skipped timing....... an oscilloscope would help but they are pricey
In all reality it isnt fast at all, it didnt ever cost 250k, and it wont blow your girls panties off. that being said i drive a ford focus
Covmister is offline
Old 03-14-2013, 10:49 PM   #7
FocusRus
FocusRus's Avatar
Fan#: 109798
What I Drive: 2004 Silver Sedan SE
Points 356, Level 7
Points: 356, Level: 7 Points: 356, Level: 7 Points: 356, Level: 7
Level Up 12% Completed
FF Reputation: 3 FocusRus Good Standing Member
Buy-Sell-Trade Rating: (9)
Does the cel come on with key on/ engine off?
SR#269 'I know where the 'zetec' kicks in....'
FocusRus is offline
Old 03-14-2013, 10:54 PM   #8
Bryan23ferra
Fan#: 98170
That's a great thought about the oscilloscope but don't forget about the simple things! Learn from my mistakes. Lol.
SES #054
Old 03-14-2013, 10:54 PM   #9
WrinkledCheese
Fan#: 94287
Wow! Thanks for all the prompt replies. Yeah, a sensor would raise an error code, wouldn't it. I don't understand why there isn't any voltage going to the coil pack...well <1v.
I just did an oil change within the past week. It was 5,000-10,000km since I did my last oil change and I figured it might help with the loss of power issue. When I took off the oil cap, I noticed the oil on the cap had some white stuff in it. It kind of looked like the gasoline effect in the oil, but instead of rainbow it was white. The oil that came out looked normal. I can still smell it, it's in the jug the new oil came in.
Would this be sufficient for testing compression? Canadian tire lets you "rent tools", but you pay full price for them and bring it back within 3 days. At $30 I might as well just buy one, plus it won't be used it I bought it.
http://www.canadiantire.ca/browse/pr...=1363315133224
If the link diesn't work, just go to canadiantire.ca and search for equus compression. Either kit should be sufficient.
Old 03-14-2013, 11:03 PM   #10
Bryan23ferra
Fan#: 98170
The coil pack is ground side switched, so the voltage reading won't be right, also to see voltage that quick you'll need as oscilloscope. Here in America you can rent the tools and they give you a full refund when returned within a spec time.
How's the coolant?
SES #054
